Need help identifying capacitor
    Re: Need help identifying capacitor
    https://en.wikipedia.org/wiki/Inductor
    Quote: "An inductor typically consists of an insulated WIRE wound into a coil around a core."
    You'd (have to) be worried if your meter was saying "OL" (out of range) on the resistance (ohms) measurement of an inductor.
    Or what makes you think they're bad?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      Originally posted by vierdane View Post
      So I test both inductor 8019P 100L. . Reading 0.00 all three different holms meter including a Fluke. I think they bad? I can't find a place on line where to purchase them.
      Unless big quantities.
      Can someone help
      DCR reading of that inductor will show really low Ohms reading, Ohm reading will only tell you if the inductor has open circuit or not, you need meter that will read inductance.Why do you think it is bad?
        Can someone help
        They are NOT BAD! you are using your meter to measure the DC resistance of a piece of wire. YOU are NOT measuring the inductance of the coil.
          I do not think we are getting through.
            "No good deed goes unpunished"...
              Have exactly the same issue with a Pro 600. 2200uF cap on the amplifier board leaked. I think the L101 and L102 (8019P 100L) inductors are OK though. Also, u1 and surrounding diodes on the power supply board all burned.
              Did anyone get a schematic for this unit? If so, could you post or send?
              K
