Genius SW 5.1 DHT-510 - No sound?
  • zynix
    • Sep 2010
    • 27
    • The Old Continent
    INTRODUCTION
    You don't remember me, but I remember you... (nah, it's not the Grease song!)
    Okay, not really. Enough digressions! Some of you may remember me from the LCS-8038TX thread. As you might have noticed from my previous thread and this one too, I mostly mess with sub-$100 equipment. Most would say worthless stuff, or at least not worth the time or bothering. Well, the primary reason I'm trying to fix them is to (hopefully) gain some experience whilst not breaking something wildly expensive, but also because it's fun (for me) to see something working neatly again. So, if you don't feel like wasting time on such a thread, for your own sake, stop reading now!
    THE ACTUAL ISSUE
    Wow, you've decided to read on? Thanks!
    On to the issue. As the title says, this subwoofer I'm dealing with is having a problem with being partly mute. Of five terminals where you can connect a speaker, only one output works (plus the core subwoofer speaker). Perhaps I'm doing something wrong, but I get sound output only when plugging an external speaker in the rightmost terminal (take a look at the first picture in the attachments), regardless of being in the AC-3 or 2-ch mode.
    I took a photo of the main PCBs in case there's something I've overseen, as well as the service manual (downloaded from here), to clarify at least some of the doubts you might have while reading this post.
    Once again, thanks for your time and any provided feedback!
    • 31055
    Re: Genius SW 5.1 DHT-510 - No sound?
    before you fix the speaker, fix the light in the room!
      You can muting control pins DC voltage of the ICs.
      IC 1 (CENTER): PIN 11
      IC2 (SUB WOOFER, probably OK since you are getting sound): PIN 9, 10
      IC3 (FRONT LEFT, FRONT RIGHT): PIN 5
      IC4 (REAR LEFT, REAR RIGHT): PIN 5
      • zynix
        • Sep 2010
        • 27
        • The Old Continent
        I should have added "If you despise people who have basic or no electronics knowledge at all, the same applies." at the end of the introduction part . Anyway, if you don't mind my ignorance, what would be an appropriate (read: the most common way) to do so?
        Yeah, sorry mate. Pictures truly turned out crappy. Guess setting everything to auto doesn't always do the justice .
          master hoarder
          • May 2008
          • 12175
          On the 3rd picture you posted, if you look at the top-center position of the picture, you will see a bit of discoloration. On the reverse side (4th picture, lower-center position), it looks like this corresponds to resistors R11 and the resistor next to it as well as diodes D4 and D5(?). If yes, check them with a multimeter. Color bands on R11 appear to be gray, brown, black, gold - which doesn't return a valid E12/E24 series resistor. So perhaps it's white, brown, black, gold? If so, that would be 91 Ohms. If not, then maybe it is gray, red, black, gold? That would correspond to 82 Ohms. Either way, try measuring the resistance with a multimeter and let us know what results you get. The diodes (D4 and D5(?)) should be checked with diode test function both ways.
          I am assuming you know how to use a multimeter. If not, let us know so we can point you to some articles/videos on how to use one.
          Finally, there seems to be burn marks close to another resistor. The resistors is located next to the connector next to connector JP4 (4th picture, upper-left corner of the board).
          • zynix
            • Sep 2010
            • 27
            • The Old Continent
            Measured resistors R11 and R12. I have got values of about 820 ohms (808 Ω on R11 and 803 Ω on R12), as in the schematic on page 19. Hope I've read it properly. If it doesn't matter if the resistors are soldered on the board (thus measuring overall circuit resistance on these two spots), the values are matching and inside the ±5% tolerance. Seems okay?
            However, regarding those two Zener diodes D4 and D5, I've got about -543k ohms in anode-cathode direction when measuring resistance, and some insane (not readable) value in opposite direction, while in the diode test mode it starts with a -500 value and slowly raises to the value of 1000, regardless of the direction. Same applies for both diodes. Should I desolder them and repeat measurement?
            The connector next to JP4 is JP23 (CMIIW!). There is a resistor there. It's R89. Again, according to the schematic, it ought to be 180 ohms, and I get a reading of 175. Seems okay too.
              • 31055
              if you dont have a zener tester and they could cause a problem then just replace them.
              dont go making asumptions with a regular diode tester.
              • zynix
                • Sep 2010
                • 27
                • The Old Continent
                Indeed. Is there any way I can tell for sure if they're burned or not prior to seeking a replacement, something like this? I tried to follow the instructions from the linked page, but the DMM picture is way too low-res and I can't tell in which mode it is. It would help me a lot if it was a higher resolution picture as I have an identical DT-830B thingy. It's not the best thing on the world, but most of the time it does the job. Would desoldering make any difference regarding measurement results?
                  • 31055
                  i just posted a tester for ya.
                  https://www.badcaps.net/forum/showthread.php?t=38843
                    "However, regarding those two Zener diodes D4 and D5, I've got about -543k ohms in anode-cathode direction when measuring resistance, and some insane (not readable) value in opposite direction," So what dc voltage do you read across those two Zeners? They are 12V Zener so the voltage across them should be around 12VDC. Thses +/-12V are for the OPAMP's (4558's), and since one of the channel (Center Channel) and the SUB Woofer are working OK, then the OPAMP's must be getting the correct +/-12VDC feeding them.
                    • zynix
                      • Sep 2010
                      • 27
                      • The Old Continent
                      Aw, thanks mate! You shouldn't have bothered for such a newb like me .
                      @budm, forgot to measure the voltage. Will check and report back.
                      • zynix
                        • Sep 2010
                        • 27
                        • The Old Continent
                        Okay, measured voltage on Zeners. D4 reads 12.24V, and D5 12.57V.
                        P.S. I know it's kinda late, but congrats on the Badcaps.net 12th anniversary! Live long and prosper !
                          Those Zener diodes are fine. You still need to check those voltages on my post #3.
                          • zynix
                            • Sep 2010
                            • 27
                            • The Old Continent
                            There's no reason why wouldn't I do that, but how? By desoldering leads?
                              "There's no reason why wouldn't I do that, but how? By desoldering leads?" I do not understand?
                              • zynix
                                • Sep 2010
                                • 27
                                • The Old Continent
                                Oh, pardon my ignorance. I was just wildly speculating. What I wanted to know was how can I mute those control pins?
                                  If you look up the spec of those IC, there is the control pin (which I have listed) the spec will tell you if HIGH = mute or LOW = MUTE. But I do not understand by you will want to mute the circuit, right now I have you check the voltages on those pin to see if the ICs are stuck in mute mode or not which may explain why you are not getting the sound form some of the channel.
                                  • zynix
                                    • Sep 2010
                                    • 27
                                    • The Old Continent
                                    It's my fault. You said "You can muting control pins DC voltage of the ICs." I thought I was to mute stuff somehow. Sorry. Will check.
                                      Sorry, It is my fault too, it should be "You CAN CHECK muting control pins DC Voltages of the ICs", sorry about that.
                                      • zynix
                                        • Sep 2010
                                        • 27
                                        • The Old Continent
                                        Long time no see! I was occupied by other stuff, projects, day-to-day obligations, etc. This absence was not a manifestation of a loss of interest, just lack of time at the moment ... and ... I made a boo-boo. There were some perceived deviations in IC1 values below so I wanted to redo the measurement, but I burned the TDA7360 chip by accidentally shorting pins 8 and 10 during runtime. It just went mute. Damnit!
                                        Prior to that stupid mistake this were the results of my measurements. I have measured the voltages using my generic DT-830B multimeter. Labels (test points) on the left were connected with the positive (red) test lead, while ones on the right side with black (negative) lead.
                                        IC1 - ST TDA7360 (datasheet here)
                                        STAND-BY (pin 11) > +Vs (pin 9) = -0.57 V
                                        STAND-BY > chassis = 15.50 V
                                        STAND-BY > P-GND (pin 6) = 15.50 V
                                        STAND-BY > S-GND (pin 3) = 15.50 V
                                        IC2 - ST TDA7296 (datasheet here)
                                        MUTE (pin 10) > chassis = 11.65 V
                                        MUTE > -Vs (POWER) (pin 15) = 39.80 V
                                        MUTE > -Vs (SIGNAL) (pin 8) = -3.71 V
                                        STAND-BY (pin 9) > chassis = 13.15 V
                                        STAND-BY > STAND-BY GND (pin 1) = 13.15 V
                                        STAND-BY > -Vs (POWER) (pin 15) = 41.70 V
                                        STAND-BY > -Vs (SIGNAL) (pin 8) = 41.70 V
                                        IC3 - ST TDA7269A (datasheet here)
                                        MUTE (pin 5) > chassis = 3.93 V
                                        MUTE > GND (pin 9) = 3.93 V
                                        MUTE > +Vs (pin 3) = 1.42 V
                                        IC4 - another ST TDA7269A
                                        MUTE > chassis = 3.75 V
                                        MUTE > GND = 3.75 V
                                        MUTE > +Vs = 1.22 V
                                        So, if such a malpractice caused such results, could it be that ICs 3 and 4 faced the same fate by someone other, perhaps by shorting output cables by mistake? Also, could something die along with the TDA7360? What should I check?
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • redoxy
                                          NHT SW10 Subwoofer no sound
                                          by redoxy
                                          Unit was working then one day no sound with the unit humming when the power switch is in the off position. When I move the switch to the Auto or ON position, nothing happens, the humming stops but no sign of life (power LED was off). I opened the amplifier and noticed one of the main power 6800uF capacitors was bulging. I replaced both 6800uF capacitors and also replace the large resistors (R41 and R140) since they looked burned. The humming when power switch is in the off position was still present but the unit will power on now. Tried connecting signal to it but then no sound. When I move the...
                                          06-22-2023, 02:01 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • nobbnobb1
                                          Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
                                          by nobbnobb1
                                          I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
                                          - 1x 3.14 A @ 250V main circuit fuse
                                          - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
                                          - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
                                          11-16-2024, 09:56 PM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
