Headphones SHURE AONIC 50
  • ut-norm
    • Nov 2019
    • 70
    • italia
    Hi, I have these AONIC 50 headphones that no longer connect. They have been unused for about 2 years. The battery has been replaced and when turned on the LED only flashes blue continuously. Connected to the power supply they recharge. Connected to the PC you can hear the recognition signal but they are not recognized by the Shure Update Utility program (they do not connect) that I downloaded to try to install the firmware. I do not know how to proceed. It is a good product, even if expensive, that I would not like to put aside. It is out of warranty, unfortunately. Do you have any ideas on how to proceed?
    Thanks​
    RCA WHP141 wireless headphones wired up
    by momaka
    OK, this one dates back to 2015! I thought I had posted this, but realized I didn’t when I posted a picture of something else. So here it goes…
    Back in 2015, I bought a pair of RCA WHP141 wireless headphones at Micro Center for $2. I even mentioned it in the best cheap/free scores thread right here. Just forgot to follow up with that.
    As mentioned back then, these are (were) 900 MHz FM wireless headphones. No modern day Blutooth or anything like that. I knew they wouldn’t be great headphones or even that good… but the price was right! So let’s take...
    02-22-2023, 06:28 PM
  • KYBOSH
    Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
    by KYBOSH
    I picked this one up today.
    Previous owner says no signs of life.
    TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
    Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
    The TV model is QN65LS03BAFXZA - version: CB06
    The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
    I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
    Will keep you all...
    04-05-2025, 08:32 PM
  • An-klamm
    Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
    by An-klamm
    Hello!
    I have a TV that I can't get any further with.
    It is a Samsung UE 55HU8590 with one connect box.
    When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
    As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
    Since the TV works without ocb, I assume that it can't be the PSU?!
    I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
    Is there...
    12-04-2023, 01:35 AM
  • obelix24
    Macbook Pro 14" A2442 820-02098-a
    by obelix24
    I have this macbook pro that is not turning on.
    taking 5V 0,05a on USB-C meter.
    PPBUS_AON - stable 12,33V
    PP3V8_AON - stable 3,8V
    Strange thing is that when battery is connected and i connect USB-C charger it shows 5V then when i disconnect and reconnect it' doesn't turn on USB-C meter at all (i have to disconnect and connect battery)
    I've checked and PPBUS_AON or PPVBAT_AON_CHRG_REG are not shorted to ground.
    any idea how to proceed ?
    12-06-2024, 08:38 AM
  • JTaylor
    Allen and Heath Xone S2
    by JTaylor
    Hello everyone.
    I am trying to repair an Allen and Heath Xone S2 mixer but need a schematic. I found the service manual on line but it is missing 4 pages.
    When an input is connected to one of the four line / phono input channels I can hear the music in the cue / headphones but there is no output on the master, the input faders are doing nothing. I can connect the sound input to the mic / line inputs or the external input boards and there is sound on the master output. One of the 74HC4053D Multiplexer/Demultiplexer had blown on the slave PCB so I changed this, I also changed two of...
    05-02-2025, 08:08 AM
