Peavey KB100 popping and thumping with humidity
  • macjedimatt
    • May 2012
    • 21
    I have a Peavey KB100 keyboard amp that works great most of the time. However, for the past couple years, when things get humid, it pops and thumps periodically until it warms up. I have taken it to a musicians repair shop at the suggestion of my musical director but they can't find anything wrong with it. I'm wondering if I should just go ahead and re-cap it. Does this sound like something that could be caused by bad caps? It is at least 20 years old so I suppose it is possible that even high quality caps could be wearing out. Any other thoughts?
  • Sparks88
    • Sep 2011
    • 110
    Re: Peavey KB100 popping and thumping with humidity
    humidity introduces moisture, I would check for dry joints especially in power supply section and output stages, even if the solder looks good I would redo them anyway using original leaded solder.
      I would also inspect the board real close for any contamination and clean the board real well.
        • 31087
        they forgot to ask for foto's
        • macjedimatt
          • May 2012
          • 21
          Well, it is still at the church. I hope to get it home this weekend and take a look at it myself. The shop that looked at it claims to have already re-soldered a bunch of it. We'll see about that.
          I was able to get the schematic and the Peavey parts department has sent me a list of all the capacitors with part numbers and pricing. I doubt I will have to replace all of them. There are about 20 100pF and 0.1uF caps in there. I'm thinking that maybe the power filter caps (2200uF/50V) could be having a problem. But without actually looking at it, this is a big guess.
          Being a meteorologist (not on TV!), I understand that humidity does have effects on capacitors and electronics in general. In fact, some instruments depend on this. One thing to note is that it seems to go away after it has been on for an hour or two. My theory is the heat is effectively drying it out. So it could be board damage as well.
          Will definitely have to put this under the magnifying glass.
          • SteveNielsen
            Retired Tech
            • 2327
            I agree solder joints are certainly suspect. Not just those on the board either. Bad solder joints can hide really well on ground points soldered directly to the chassis.
            One very elusive pop, crackle, thump problem I had in a guitar amp wound up being the reverb tank drive transformer that had an intermittent winding short so check that puppy too. You may not be able to measure an intermittent short in it but heating it up when cold and having the noise with a hair dryer could expose it.
            Since this is a 90s amp you have it's probably a good idea to replace the electrolytics, or a least check them. I wouldn't worry about the small signal caps. If they are ceramic they could be microphonic but that would present itself differently, with ringing or oscillation at certain frequencies, not pops and thumps.
              • 31087
              when i think of churches - i think of cold damp buildings.
              something you probably dont know - flux obsorbs moisture.
              make sure it's not got loads of flux all over it.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                I agree with STJ.
                Is this a tube amp?
                Also, the extra moisture may be causing a resistor or capacitor to break-down.
                Yes, you should do a preventative re-cap of the electrolytics.
                Muh-soggy-knee
                  It is solid state amp.
                  Diagram
                  • macjedimatt
                    • May 2012
                    • 21
                    budm, That is the "newer" version of it. I have the 1984 which is slightly different. Hoping to get it apart and post some pictures Tuesday night.
                    • Marko7
                      • Jun 2014
                      • 8
                      Carefully resolder all low-level audio stages, clean the P.C. board in the preamp area, dry it COMPLETELY and then try spraying some clear non-conductive sealent over both sides of the board.
                      The goal is to make any connections which are in close proximity with each other [in the preamp or output driver I.C. area] from having moisture [beads] conducting spurious D.C. currents around, like between pin 3 (+ In) & 4 (-Vcc) on a dual (or single) op amp I.C. That should help.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        any evil brown glue?
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4978
                          • New Zealand
                          I fixed a friend's subwoofer\amp that was thumping when the cable was moved, at first I thought it was the plug\cable, but it turned out to be broken PCB traces for the jack.
                          -David VanHorn
                          • macjedimatt
                            • May 2012
                            • 21
                            I've finally got it and taken it apart. I've gone ahead and pulled all the electrolytic caps. I'm going to start with replacing them and I plan on inspecting the solder joints while I put them in.
                            Some observations:
                            - The COMP. light is always very faintly lit.
                            - The power light isn't particularly bright.
                            - It thumps when turned on the first time.
                            - The PCB is a very cool design.
                            Pictures attached. Any other questions or recommendations welcome.
                            • goontron
                              5000!
                              • Dec 2011
                              • 4108
                              • US
                              number 5 looks like it could be a wallpaper, what camera are you using?
                              Follow the white rabbit.
                              • macjedimatt
                                • May 2012
                                • 21
                                A Canon EOS 20D. That one was using a fixed 50mm lens.
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4978
                                  • New Zealand
                                  Originally posted by macjedimatt
                                  Some observations:
                                  Could be indicative of a fault, like a leaky component. What is that LED connected to? I can't see it on the schematic.
                                  The LED might just be old and worn, R198 might have increased in resistance, or there's a poor connection somewhere.
                                  - It thumps when turned on the first time..
                                  That might not be a fault. Some amps do not have de-thump circuitry (especially old ones) and all amps thump at power up to some extent. If it's not very loud it might be normal.
                                  That would have been 'taped out' by hand.
                                  -David VanHorn
                                  • macjedimatt
                                    • May 2012
                                    • 21
                                    The attached PDF is the closest I could fine to my version of the amp. The COMP LED is connected to a 4558 amp on the lower left of the schematic.
                                    Right. I think on this one it would be R111. I'll check it out tonight.
                                    Thanks!
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4978
                                      • New Zealand
                                      That one makes more sense. R111 would be it.
                                      What does the 'COMP' LED actually indicate?
                                      -David VanHorn
                                      • macjedimatt
                                        • May 2012
                                        • 21
                                        I think the COMP led is "Compression" it lights up whenever it thumps on power on, or when it pops/thumps due to whatever is causing it to do that. I can't find a manual for this particular version. The one in the Peavey archive is for the newer version that has the XLR jack on channel 1, and no COMP light.
                                        • unimatrix93
                                          Egg incubator humidity sensor replacement
                                          by unimatrix93
                                          My egg incubator humidity sensor kicked the bucket, I read open circuit on it with DMM even in the MOhm range.
                                          So I started identifying this piece of crap and look for a replacement part.
                                          This thing has 6 turns or black lines, while the one I found similar has more turns and has 33kOhm. ​
                                          Based on the number of black lines, this one looks like the 23kOhm version of this thing, but I cannot find anything with this value on the local distributors.
                                          I assume the 33kOhm wont work?
                                          What do you guys recommend?...
                                          05-15-2025, 08:10 AM
                                        • otoluk
                                          Auriol weather station humidity sensor
                                          by otoluk
                                          I have two Lidl LD6273 Auriol units with DCF77 radio for time update.
                                          I really like the idea but the cheap moisture sensor(guess HR202L) inaccuracies make the device unreliable. Also not clear why indoor and outdoor unit sensors being same type doesn't match. For example I place both units on same table and indoor unit shows 23% humidity while outdoor sensor shows 39%. What I found out is that I get better readings if cleaning the solder points of sensor inside with isopropyl alcohol.
                                          Looking for replacement sensor which I could solder in place of HR202L resistive sensor but need...
                                          11-06-2024, 07:57 AM
                                        • diazald
                                          Searching for a Peavey XRs schematic
                                          by diazald
                                          Searching for a Peavey XRs Schematic. A SMD capacitor with no values cracked on me. I have searched off and on for months with no luck.
                                          Any help would be greatly appreciated
                                          11-24-2023, 02:49 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • roman-hartwig
                                          Onkyo TX-NR828 - popping sound every 5 min
                                          by roman-hartwig
                                          Object: Onkyo TX-NR828
                                          Problem: Popping noises in the right surround channel every ~5min
                                          Service manual: available
                                          After I was able to bring my beloved Onkyo back to life (total failure of the power amplifiers) and it has now been doing its job for some time without any problems, it is now ailing with a new problem. It still works fully, but after about 5min it "pops" in the right surround speaker for about 0.5 sec very loud (100% volume). I am almost scared to death - sounded like a battery exploding or something. It sounds like something is discharging - a...
                                          07-29-2023, 08:08 AM
