Peavey KB100 popping and thumping with humidity
    replied
    Re: Peavey KB100 popping and thumping with humidity
    Glad you found the and narrow it down to that section where U5 and U6 are. What is the designator of the cap? C??
  • macjedimatt
    replied
    Finally got it all fixed! Last night I discovered that one of the small NP caps in the EQ circuit was the culprit. It had a bad solder joint. I found it by poking the board with a marker while listening to it through headphones.
    Thank you for all of the suggestions!
    replied
    At least you are getting close.
  • macjedimatt
    replied
    Originally posted by budm
    So now we have to start tracing backward from U6B output pin 7 back to U5A (since you use J2 and it still thump). So you replaced all those lytics caps C18, 19, 24, 39 in the signal path?
    Yes. I'm going to have to get back to this tomorrow. 4AM comes awful fast. Thanks for the help so far!
    replied
    Might as well resolder all the connections and use good flux.
    Check the DC offset at the pin 1, 7 of U5, 6 also.
    BTW, the thump is really loud? and only when you it on, otherwise the amp sounds fine?
  • macjedimatt
    replied
    Ok, just discovered that flexing the pan that the board is attached to is causing it... So it probably has a bad joint or damaged trace somewhere that I missed.
  • macjedimatt
    replied
    Insert the blank phone jack into the Power amp in J4 (this will disconnect the line out signal from feeding into the power amp input section), then connect a Powered speaker line input to the J5 line out and see you do hear a thump from that line out, and see if still hear the thump from the internal speaker.
    It sounds to me the thump is from the preamp section.
    Confirmed. Signal patched in, headphones on the pre out, and a blank jack plugged into the pwr amp in. Thumped in the headphones. I think my neighbors like this test better :-) Now the question is, what the heck would cause this?
  • macjedimatt
    replied
    Just put the meter on the 15v lines. -15 was -15.2 and pretty rock steady. +15 was 14.8 and also steady. Not sure if my meter just wasn't picking up the spikes though.
    replied
  • macjedimatt
    replied
    I did some more testing tonight:
    • Going straight into the PWR AMP IN = Clean with a couple faint clicks that could have been line noise.
    • Headphones on the PRE OUT = Heard thump in headphones and speaker
    • PRE EQ Patch in only = thumped, seemed to do it a few times also when messing with the EQ knobs.
    • Bypassing the reverb coil = still thumped.
    I've attached an annotated schematic with what I have tested so far. At this point, I feel like the main power amp is probably fine. I'm not sure if it is something in the EQ or maybe the +/-15V lines of the power supply. I have a DMM with a peak hold. Should I put that on the +/-15V lines and look for spikes? Could the transformer be going bad?
  • ben7
    replied
    I wonder if there is a bad transistor or IC somewhere.
  • macjedimatt
    replied
    So I have finally replaced all the capacitors and it doesn't seem to have gotten any better. It thumped a few times in the first minute or so of turning on. I hooked some tunes up to it and caught it in action on video: http://youtu.be/zjHkZr2dD54
    No combination of turning/pushing/pulling on the knobs seems to replicate it reliably. Also does it with no source connected.
    replied
    It is the compression indicator to show that the compression circuit (U1A/B, U7B, U2(87478 is an OTA (Operational transconductance amplifier): https://cdn.badcaps-static.com/pdfs/...323fc6188c.pdf, ) has kick in if the signal feeding the power amp section is too high.
  • macjedimatt
    replied
    I think the COMP led is "Compression" it lights up whenever it thumps on power on, or when it pops/thumps due to whatever is causing it to do that. I can't find a manual for this particular version. The one in the Peavey archive is for the newer version that has the XLR jack on channel 1, and no COMP light.
  • Agent24
    replied
    That one makes more sense. R111 would be it.
    What does the 'COMP' LED actually indicate?
  • macjedimatt
    replied
    Could be indicative of a fault, like a leaky component. What is that LED connected to? I can't see it on the schematic.
    The attached PDF is the closest I could fine to my version of the amp. The COMP LED is connected to a 4558 amp on the lower left of the schematic.
    The LED might just be old and worn, R198 might have increased in resistance, or there's a poor connection somewhere.
    Right. I think on this one it would be R111. I'll check it out tonight.
    Thanks!
  • Agent24
    replied
    Originally posted by macjedimatt
    Some observations:
    - The COMP. light is always very faintly lit.
    - The power light isn't particularly bright.
    - It thumps when turned on the first time..
    That might not be a fault. Some amps do not have de-thump circuitry (especially old ones) and all amps thump at power up to some extent. If it's not very loud it might be normal.
    - The PCB is a very cool design.
    That would have been 'taped out' by hand.
  • macjedimatt
    replied
    Originally posted by goontron
    number 5 looks like it could be a wallpaper, what camera are you using?
    A Canon EOS 20D. That one was using a fixed 50mm lens.
  • goontron
    replied
  • macjedimatt
    replied
    I've finally got it and taken it apart. I've gone ahead and pulled all the electrolytic caps. I'm going to start with replacing them and I plan on inspecting the solder joints while I put them in.
    Some observations:
    Pictures attached. Any other questions or recommendations welcome.
  • unimatrix93
    Egg incubator humidity sensor replacement
    by unimatrix93
    My egg incubator humidity sensor kicked the bucket, I read open circuit on it with DMM even in the MOhm range.
    So I started identifying this piece of crap and look for a replacement part.
    This thing has 6 turns or black lines, while the one I found similar has more turns and has 33kOhm. ​
    Based on the number of black lines, this one looks like the 23kOhm version of this thing, but I cannot find anything with this value on the local distributors.
    I assume the 33kOhm wont work?
    What do you guys recommend?...
    05-15-2025, 08:10 AM
  • otoluk
    Auriol weather station humidity sensor
    by otoluk
    I have two Lidl LD6273 Auriol units with DCF77 radio for time update.
    I really like the idea but the cheap moisture sensor(guess HR202L) inaccuracies make the device unreliable. Also not clear why indoor and outdoor unit sensors being same type doesn't match. For example I place both units on same table and indoor unit shows 23% humidity while outdoor sensor shows 39%. What I found out is that I get better readings if cleaning the solder points of sensor inside with isopropyl alcohol.
    Looking for replacement sensor which I could solder in place of HR202L resistive sensor but need...
    11-06-2024, 07:57 AM
  • diazald
    Searching for a Peavey XRs schematic
    by diazald
    Searching for a Peavey XRs Schematic. A SMD capacitor with no values cracked on me. I have searched off and on for months with no luck.
    Any help would be greatly appreciated
    11-24-2023, 02:49 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    Opened it up and discovered the power supply is making a faint clicking or ticking sound.
    I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
  • roman-hartwig
    Onkyo TX-NR828 - popping sound every 5 min
    by roman-hartwig
    Object: Onkyo TX-NR828
    Problem: Popping noises in the right surround channel every ~5min
    Service manual: available
    After I was able to bring my beloved Onkyo back to life (total failure of the power amplifiers) and it has now been doing its job for some time without any problems, it is now ailing with a new problem. It still works fully, but after about 5min it "pops" in the right surround speaker for about 0.5 sec very loud (100% volume). I am almost scared to death - sounded like a battery exploding or something. It sounds like something is discharging - a...
    07-29-2023, 08:08 AM
