InterM PA Amp PAM-360 Protection Problem
  • DjKrish
    • Oct 2012
    • 354
    • SG
    As stated, i have this PA system amplifier that im trying to fix for sometime. It is having a clip and protection light on. When i disassemble the entire unit, i manage to find that a lot of components thats burned on the amp pcb. Power amplifier transistors, resistors, normal transistors etc. I manage to check all the components and replace all the faulty ones. Now the clip light no longer lit but the protection light is still on after turning on. I even replaced the protection IC. But im still having the protection light on. Any guru's may kindly help me with this? I have attached the necessary SM and amp SD. I have replaced all the faulty components already. I just dont know where else to look at. Any help will be highly appreciated. Hoping to fix this a.s.a.p
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Re: InterM PA Amp PAM-360 Protection Problem
    PS: The relay on the Amp PCB doesn't click either when turned on
    • redwire
      • 3910
      The protection circuit can trip for a few reasons:
      1. DC voltage at either channel amp's output (measure at L201, L301) - (most likely, as one channel was blown)
      2. Overtemp circuit (thermistor PO301)
      I would guess your power amp still has a problem, resulting in too much DC at one channel's output. Measure the voltages at the inductors or output relays.
      • audiobrad
        • Mar 2014
        • 3
        • South Africa
        Hey tech's
        Check the resistors around the sub driver transistors if i remember correct its a 22 ohm and 47kilo-ohm resistor on both side of the board . make sure that your output transistors are idling correct if not the protection stage will kick in even if there is no dc on output .
        • DjKrish
          • Oct 2012
          • 354
          • SG
          How do i check the thermistor? Theres 2 and both also showing different reading in cold temperature with no power plugged in. One is high reading and another is low reading
          • DjKrish
            • Oct 2012
            • 354
            • SG
            Originally posted by audiobrad
            Hey tech's
            The resistor was blown before and i have replaced with same value. Now the resistors u mentioned is perfectly fine.
            • redwire
              • 3910
              On the protection IC TA7317P, if there is any DC on pin 2 or pin 3, above around +/-1V it will trip the protect latch. You should measure close to 0V on those pins.
              • DjKrish
                • Oct 2012
                • 354
                • SG
                My bad assuming one row of the transistor are heating up thinking one channel will work, i plugged in a small speaker and a loud humming sound came out from the speaker assuming its blown already, resistor blown again and the power fuse blown too. I guess some of the power transistors burned again. Big mistake.
                Could the transformer be faulty too since the power fuse blowing up? How can i measure the transformer based on the schematic diagram? I have multimeter and digital multimeter too. How can i measure the transformer just to make sure its working fine? How do i measure those wires from the transformer?
                • DjKrish
                  • Oct 2012
                  • 354
                  • SG
                  Pictures of the unit
                  • DjKrish
                    • Oct 2012
                    • 354
                    • SG
                    Ok, replaced all the caps, output transistors, bias transistors and resistors. Amp board is as good as new now. Luckily i plugged it via the light bulb limiter, turned on, its dim but not very and not bright either. The protection light is still ON. The relay on the amp pcb is not working either. Only the relay on the power pcb and the relay on the main pcb is working when turn on. Amp pcb relay seems to be off. Checked the relay with 30v power supply, its working fine and clicking. Where else should i be checking? Please help meeeeeeeeeeeeeeeeeeeeeeeeeeeee ............................
                    • redwire
                      • 3910
                      Like I said, measure the protection IC TA7317P, pin 2 and pin 3...
                      • DjKrish
                        • Oct 2012
                        • 354
                        • SG
                        Yes there's DC voltages present on pin 2 and 3 upon turning on with the light bulb limiter. Around 5 to 7 volts.
                        • redwire
                          • 3910
                          Check your light-bulb limiter is not interfering with things too much. Measure the amp power supply voltage (I use multimeter on the collector/tab of the output transistors), and the +/-26V rail voltages.
                          DC voltage on TA7317P pins 2 and 3 means there is DC at the power amp's output in both channels, and the protection circuit has tripped. Did you have both channels blown? I am guessing there is still a problem with the power amp section but it could be elsewhere, as it is odd to have both channels doing the same thing.
                          What you are troubleshooting is very hard to do. Power amps are difficult to fix with power on. Patience....
                          • DjKrish
                            • Oct 2012
                            • 354
                            • SG
                            If u noticed, there's 2 sections of output transistors. Current drive one side and voltage drive one side as u see in the block diagram.
                            • redwire
                              • 3910
                              "Current drive" refers to the power amp output stage i.e Q217/218, Q219/220, Q221/222 and "Voltage drive" refers the voltage gain stage before.
                              The protection circuit is doing the right thing because it is seeing DC voltage on the amp's output, which should be 0V.
                              Did you check the eight 0.47R emitter resistors for open circuit.
                              Measure your power supply rails and the output voltage.
                                Something is not making sense here:
                                https://www.badcaps.net/forum/showthread.php?t=36954
                                You have indicated that you see 0V at the output.
                                • DjKrish
                                  • Oct 2012
                                  • 354
                                  • SG
                                  New progress : Now i know why the relay didn't click on the amp pcb. I popped it out, short with 24vdc psu, it still didnt click either. Opened up the relay, noticed its burned. And also c4001 transistor is short. Gonna change this both today and see how it goes and make more measurement and update in here.
                                  • DjKrish
                                    • Oct 2012
                                    • 354
                                    • SG
                                    That is after i replaced all the output transistors, before that had some dc voltages
                                    Now the voltage is absolutely zero on all the speaker outputs. The relay is working perfectly fine on the amp board. It clicks after turning on the power immediately. No DC voltages on pin 2 and 3 on the protection IC TA7317P. So i guess im getting closer to solving the issue. Where else should i be checking now? I appreciate everyone's help in here. Very informative and helpful.
                                    • DjKrish
                                      • Oct 2012
                                      • 354
                                      • SG
                                      Edit : I see 0V on pin 3 but i see -0.02V on pin 2 of TA7317P Protection IC. Is that bad?
                                      • DjKrish
                                        • Oct 2012
                                        • 354
                                        • SG
                                        There is 2 piece of 260 Ohms resistors near both variable resistors. One resistor shows around 74ohms and another shows near 98ohms. I find this too low for the original value.
                                        R233 and R333 on the amp circuit.
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • multimesut
                                          Dell 2007FPB Yellow Light Problem
                                          by multimesut
                                          Hello friends,
                                          A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....
                                          11-13-2024, 07:00 AM
                                        • Tom_x
                                          HP Omen15 dc0001nh keyboard light problem
                                          by Tom_x
                                          Hi
                                          I have this HP laptop, board: DA0G3DMBCE0 rev:E
                                          The keyboard light only work, when i connect ac power supply(without battery), until the screen come with cmos checksum error. After this point light can't switch on. The first 5-6 seconds i can switch on/off light with FN+F4. When booing on, i can't switch on.
                                          Keyb light controller Y59116, i think working, because receive i2c commands the firsr 5 seconds
                                          I know schematic doesn't exist for this board
                                          Someone know similar board, that use this rgb keyboard light controller?
                                          regards
                                          04-05-2023, 10:32 AM
                                        • andy smith
                                          interm m1000 clip lights
                                          by andy smith
                                          Hi all my name is andy
                                          I have a interm m1000 amp that has both clip lights on. I have checked DC on speaker outputs and is 0 volts , can anyone offer any advice
                                          thanks andy
                                          01-23-2025, 02:22 PM
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
