interm m1000 clip lights
  • andy smith
    • Jan 2021
    • 6
    • uk
    Hi all my name is andy
    I have a interm m1000 amp that has both clip lights on. I have checked DC on speaker outputs and is 0 volts , can anyone offer any advice
    thanks andy
  • lotas
    • Jan 2016
    • 4589
    • Russia
    You see 0v at the output because the relay did not work due to protection.
    • Delicieuxz
      I replaced all electrolytics in subwoofer, still get a hum in speakers - audio clip
      by Delicieuxz
      I get a faint, low hum through my PC speakers, which connect to the subwoofer in a 2.1 speaker system. The hum drives me crazy and makes me stressed. When I turn off the subwoofer, everything is quiet and I start to relax, lol.
      Here's an audio clip of the sound coming from my speakers:
      https://vocaroo.com/16HaryHwTx78
      I recorded with my phone's mic right next to the speaker, and the mic picked up a lot of speaker noise over top of the hum. But I don't hear that noise in the room, I just hear the lower-pitched hum that's buried beneath all the other...
      11-15-2023, 09:50 PM
    • Francesc V.
      Christmas lights - Something I am doing wrong
      by Francesc V.
      Hi:
      i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
      I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
      If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
      Could...
      03-11-2023, 07:38 AM
    • ChaosLegionnaire
      correct way to connect bare speaker wires into spring clip terminals?
      by ChaosLegionnaire
      i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
      however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
      i googled...
      10-27-2022, 06:19 AM
    • bialag
      Lenovo ThinkPad E14 Gen 5 - Not Powering On - 3 Blinking Lights - 20 volts 0.224 amps
      by bialag
      I have a Lenovo here that does not want to power on. The motherboard appears to be clean, no sign of corrosion or obvious fried components. When plugged in, I see 3 blinking lights and then off. It would cycle the 3 blinking lights every 10 seconds or so as long as I have the adapter plugged in. Amp meter shows 20 volts, 0.224 amps, no fan spin, red light indicator near the charge port.
      Thermal camera shows a section of the motherboard that is warmer than the rest. It is near the connector labels JRTC1 (CMOS battery). Diode measurement to ground for pin 1 = OL,...
      03-25-2025, 05:56 PM
    • gabrielA7
      IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
      by gabrielA7
      Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
      I saw that the room LED lights up only when the screen is connected, so quiet.
      We have all the power supplies, even processor, 1.8V
      One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
      I suspect that there may be some leak in the processor.
      Anyway, when I press the power, it...
      10-29-2024, 06:48 AM
