Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
This topic has been answered.
  • Omron
    • Mar 2023
    • 49
    • Serbia
    Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
    My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
    - Tried to unplug radio and plug it back in into power,
    - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
    - Tried to hold 3,6 while turning it back on and then pressing 1,2 , nothing happened still in demo mode asking to press volume knot.
    - I opened front radio panel and cleaned all contact with alcohol brush, still same. I sprayed WD Spray onto volume knot button while its opened still same.
    - I retouched soldering points of volume knot button if it had cold connection to resolder it back on, still it doesn't work,
    - Tried resoldering other buttons too, in case some was stuck or something it didn't improve at all.. Still asking me to press volume knot button.
    Anyone has any idea what can I do? Tried other radio, it works perfectly so its not my installation. Thank you everyone for reading this and specially to those who are willing to help me out! 😊
  • Answer selected by Omron at 05-26-2024, 02:38 AM.
    Omron
    • Mar 2023
    • 49
    • Serbia
    Looked into buttons today, buttons on side have 4 pins each, two are parallel in continuity and two across should be only in continuity when button is pressed. They have around 1200mOhm resistance and when pressed 0 resistance.
    Found out the power button was basically always pressed in permanently, thus nothing was working correctly. What I did was cut small rubber tube and put it onto button, then spray with WD and with small screwdriver started to click it so WD ingredients go inside button and lube it up and clean it up.
    After doing this for 20-30 seconds I checked with Multimeter and it was working like charm, not even needed to de-solder - solder new one, saved me a lot of time and hustle especially since i didn't have spare button.
    Below I will put links that helped me so people who have same trouble can help themselves as well
    FM radio diagnosis and repair:
    https://www.youtube.com/watch?v=LsM5qRLHH2Q
    Button repair:
    https://www.youtube.com/watch?v=Bb90lXgp3MI
    • CapLeaker
      Leaking Member
      • 8184
      I think you have to press the function button first, before you press the volume
      • R_J
        • 9551
        See Page 6
        • Omron
          • Mar 2023
          • 49
          • Serbia
          It doesn't respond to any buttons, Before it worked now not anymore
          • Omron
            • Mar 2023
            • 49
            • Serbia
            Additional info, not even power button is reponding when you want to turn it off
            • Omron
              • Mar 2023
              • 49
              • Serbia
              https://www.youtube.com/watch?v=LsM5qRLHH2Q I found this video basically person is looking if some button is not working and he finds one and takes it out and then it starts working, I need to check this out tomorrow on my unit
              • Omron
                • Mar 2023
                • 49
                • Serbia
                Button repair:
                • praveenramavath
                  Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                  by praveenramavath
                  Hello All,
                  I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                  https://www.hifivision.com/threads/m...-screen.98243/
                  Troubleshooting Summary: Majority Internet Radio - Flash Chip
                  04-26-2025, 09:08 AM
                • shelby5041
                  clock radio / radio lifespan?
                  by shelby5041
                  hi
                  ive got a modern digital clock radio approx 15yrs old
                  my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                  since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                  the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                  it uses very little power just a few watts i would imagine that may have something...
                  09-14-2024, 03:30 AM
                • UserXP
                  Vintage SONY Digital Clock Radio ICF-C12W no audio
                  by UserXP
                  Dear all,
                  I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                  i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                  My question is, do you know of this brand of capacitors and how bad are...
                  07-21-2025, 08:35 AM
                • FlashFireSix
                  LG xboom PN5 stuck in demo mode(?). Looking for retail firmware.
                  by FlashFireSix
                  I took an ebay gamble on an LG xboom pn5 speaker which was listed as having battery issues (turning on then off).
                  I got it earlier today and concluded it's in a demo mode because of the following:
                  • When it's plugged in, it'll turn on and the power button will not turn it off
                  • Battery is healthy, reading 4.2v and not swollen, charges according to the xboom app
                  • the play/pause and volume buttons don't work
                  • You can pair to it and play music fine, as long as it's connected to power
                  • The bluetooth connection is disconnected after 5 seconds of audio pausing
                  • The DTS setting is defaulted
                  06-26-2024, 09:35 AM
                  HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                  This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                  09-12-2024, 02:00 PM
