Car amplifier(Polk Audio PA660) question
  • jakdedert
    • Jun 2010
    • 19
    Re: Car amplifier(Polk Audio PA660) question
    I've opened a few of these now that I had marked as defective back when. Also got a few more that were in the batch and overlooked; two PA330s and another 880 and 660.
    I've limited myself so far to testing outputs, drivers and smps MOSFETS with a meter. I ordered a quantity of each, as each of the four amps I've looked at so far has a problem with one or more of the above. Until I get some new parts, I'm going to swap some parts around and see how many I can get going that way; then replace the defectives when new parts arrive.
    This is getting fun...may even get lucrative.
    • tibimakai
      • Jan 2012
      • 3680
      The PA660 failed again.
      Found a final transistor 2SB668, shorted. After I have removed it, and powered it up, the Red LED turned on, for like 7 seconds and then went off. I'm wondering what that means? The Blue LED(power) does not turn on at all. It could be, that one of the transistors is missing and the amp is not ready?
      It is hard to work on these things, without a SM.
      • Piotr07
        • Oct 2015
        • 17
        • Poland
        #43
        How you want to run the amplifier without one final transistor, you should unsolder both final transistor to check the amp. What about the DC voltage at the power outputs ?
        • tibimakai
          • Jan 2012
          • 3680
          Makes sense, thanks.
          Hopefully, today I will pick up some transistors. I will replace both and I will report back, with the result.
          • tibimakai
            • Jan 2012
            • 3680
            OK, I have replaced both transistors and the protection LED is off. But the blue LED is not on either.
            I measure -27V, but only +1.4V on the other rail, if I measure it the right way.
            It is hard without a schematic.
            I would appreciate any help. I can't listen to my stereo in my car, because this amp supplies my door speakers. I drive over an hour each way to work and without it, it is very bad.
            • R_J
              • 9536
              There are liklely two large caps for the + and - supplies, see if they are correct, if they are, then check for bad/open component supplying that side, If there is no positive voltage on the cap, search components toward the power supply
              • tibimakai
                • Jan 2012
                • 3680
                There are actually 4 big capacitors.
                I believe, that I have the proper voltages, I'm just not measuring, from the right ground.
                I'm having a hard time, to find the proper grounds to measure. I'm in a hurry and I'm not able to think clearly.
                Here are some pictures taken, with my phone.
                • R_J
                  • 9536
                  This should be the ground and plus minus marked.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I may have made a mistake, when I have removed the two double diodes. I thought that they are the same, but the last three letters makes them different and I did not pay attention to that.
                    1FB2CCA /1FB2CAI
                    • R_J
                      • 9536
                      One would be common cathode, one would be common anode, those are strange numbers
                      • tibimakai
                        • Jan 2012
                        • 3680
                        The amps is powered by + GND - power supply, right?
                        Why I'm getting only - at both amps? It seems like one of the rails is way to low(-1.3V)
                        What would happen, if I would revers these double diodes?
                        • R_J
                          • 9536
                          Check the connections on that dual diode, also did you check it to make sure you did'nt blow it when you reversed it
                          If you reverse the diodes you will blow up the amp. What do you think happens if you put negative voltage to the positive of a capacitor... pufff
                          You likely damaged a trace taking them out
                          • tibimakai
                            • Jan 2012
                            • 3680
                            R_J, you are awesome. Thank you very much!!!!
                            To me it did not seem like there is any bad soldering there(maybe, the center pin on the left double diode, it was a bit suspect), but I went over all 6 joints and the blue led has turned on.
                            The Red LED turns on, for like two seconds and then turns off. Than the Blue LED turns on.
                            Now I have +27V as well.
                            YEAHHH!!!
                            • R_J
                              • 9536
                              Check that the voltage at the speakers is near zero volts, run it for a while checking the temperature of the transistors to make sure one or two are not over heating
                              • andy_nz
                                • Jul 2019
                                Another attempt to dredge up an old thread.
                                I also have a PA660 amp - it was working, but experiencing very bad noise when installed in the car. I checked all earth points in the car, to no avail, and one day the left rear channel 'popped' and stopped working. All other channels had around 27v, the left rear had around 1.5v.
                                I since replaced the amp with a new one, and all noise etc has gone - and I am now attempting to repair this amp.
                                No components appear to be blown up - there is no visible signs of damage...but if anyone could point me in the right directions as to where to start looking that'd be great.
                                I am going to replace all the caps initially on the power supply (C30, C31, C1 and C4) followed by the larger caps (C18, C19, C28, C29)
                                • mark97564
                                  • Aug 2023
                                  • 3
                                  Prolly bad transistor on that channel, my pa660 has issues with that same channel. Since it was new it would sound shorted with the car was cold in winter, bumps in the road would affect it also, but after warning up it would work fine for years that way. But now that channel sounds like it's shorting out, no bass, no volume compared to the other 3 channels.. its been running this way for a few months and hasn't gone into protection mode at all, one of these days I'm going to pull it out of the car and see what I see with a scope, busy since the amp works fine besides that channel and it's not going into protection, im thinking there is a bad transistor or solder joint.. post back if you get yours fixed, be nice to have a starting point with my amp.
                                  • samson7point1@yahoo.com
                                    Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                    by samson7point1@yahoo.com
                                    The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                    The player processes the audio signal using two different reference frequencies. The "R"...
                                    04-30-2024, 11:22 AM
                                  • i_am_patch
                                    Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                                    by i_am_patch
                                    Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                                    04-30-2024, 08:20 PM
                                  • MOSSEP
                                    Monitor Audio RSW12 - Green light but no audio
                                    by MOSSEP
                                    Hi
                                    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                    I have already tried replacing all of the...
                                    01-26-2025, 08:18 AM
                                  • grimacelord
                                    MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
                                    by grimacelord
                                    I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
                                    12-11-2023, 11:13 AM
                                  • Piaskos
                                    Dell Vostro 5490 - no sound, no audio device
                                    by Piaskos
                                    Hi, i've got problem with Dell Vostro 5490.
                                    Board - Mantis CML 18788-1
                                    Windows says "no audio device detected". The other functions work properly.
                                    What i've done:
                                    1. I checked motherboard
                                    2. I changed audio codec (ALC3204)
                                    3. I reflashed bios with clear ME
                                    4. Audio is enable in bios
                                    5. Both speakers are good
                                    6. After installing the drivers from the Dell website, the devices visible in the manager:
                                    - Audio for intel displays
                                    - Intel Smart Sound Technology...
                                    01-30-2023, 02:58 AM
