Onkyo TX-NR616 won't stay powered on
  • mmartell
    replied
    Re: Onkyo TX-NR616 won't stay powered on
    Hmm.. just applied for this for a TX-NR609. I am NOT the original purchaser and don't have a receipt but it hasn't been asked for yet lol. The thing is junk so may as well see if they'll cover it.
  • R_J
    replied
    just a note:
    It may not apply here but some of these Onkyo Receivers can be repaired no charge under Onkyo's Special Service Program http://www.onkyousa.com/Support/ Check your model/serial to see if it qualifies.
    08/19/2014 Loss of Audio/Network Connection Customer Care Program
  • cheebster
    replied
    Um. I'm looking for more info on this, i have a failed tx-nr808. stj, do you have access to the service bulletin from onkyo ? I'd like to buy that small board, and have the proper instructions on how to install it...
    I wonder, if that board with a proper reball would do the job.
    replied
    that small board is an ajustable output voltage regulator from dealextreme.
  • Alphas
    replied
    burnt chips?
  • tibimakai
    replied
    Here is the picture.
  • tibimakai
    replied
    I have received the HDMI board today.
    At first glance, I can notice a mini daughter board installed on top of a processor and two wires soldered to the board.
    I took some pictures, I will upload them tomorrow and I will compare them with the previous photos, that I have took before I sent it out.
    The receiver works as it should, awesome service from the Ebay repairman. He is not to far from me, in Garden Grove CA. I have received the board very fast too.
    Thank you again for helping me.
    Now, I need to get back to the Pioneer receiver.
  • tibimakai
    replied
    I have decided to send the board to the Ebay tech. He is charging me $85 for the repair.
    It seems that there is a service bulletin on how to repair these board. He may add a small daughter board to it and it may even replace the DSP chip. These are assumptions from reading from the net.
    I will take some pictures, before and after the repair and I will compare them, to see what is the difference. It should take from 5-7 days the repair. He has 100% feedback on Ebay with over 300 repairs done already.
  • tibimakai
    replied
    I don't remember the exact firmware right now(1130908??00), but definetly it has two question marks in it.
    I haven't tried the network yet. I haven't even tried the second HDMI output.
    Tomorrow I will try that output.
    I'm thinking that I should re-flow the DSP chip.
    Here is another forum with a similar receiver, where they mention that by re-flowing the DSP chip should fix the HDMI problem. The chip is below the Ethernet port(the one with the sticker on it).
    http://www.bgamods.com/forum/viewtopic.php?f=61&t=1713
  • rievax_60
    replied
    Originally posted by tibimakai
    How would I know if the quartz is the problem?
    Which tracks are you referring too?
    I'm wondering about the Ebay tech, what could he repair on these boards?
    It seems, like he repairs any model of these HDMI boards.
    Only with an oscilloscope. Its also useful to measure the DC voltage at each end.
    Corroded tracks look dark but need to be open circuit to cause a problem.
    I used to see this problem on some Yamaha models that had the System PCB mounted with the copper side up
    and placed just under the top vent slots.
  • artois7
    replied
    Which firmware(s) haven't you got? USB & network issues are always HDMI PCB. The DSP chip goes faulty and needs to be replaced. Reflowing may help temporarily. A faulty DSP chip will show up as "??????????" on the firmware list.
  • tibimakai
    replied
  • rievax_60
    replied
    From the small experience I have, a high proportion of faults would be a faulty crystal, always 25Mhz. And also corrosion of upward facing PCB tracks.
  • tibimakai
    replied
    What I have noticed that if I check the firmware version, in that series of numbers, two of them are question marks. I'm thinking communication error.
    I have found on another forum something about DSP communication errors can cause question marks in firmware versions among other issues.
    I have noticed that two days ago, I could do the firmware update through the front USB port and yesterday the USB stick wasn't recognized by the port. It worked only through the rear port, unsuccessfully of course.
    It's a different receiver, but the solution may be the same:
    http://www.avsforum.com/t/1431671/po...-unit-to-onkyo
    replied
    Usually linear reg or bad cap -- you can just go around checking reg voltages.
  • tibimakai
    replied
    It seems that the HDMI board is toast.
    I'm reading about these issues on other forums, but I can't be sure which issue I have.
    On a slightly older models seems like capacitors needed replacing on these boards. On more recent receivers I have seen some are re-flowing there boards.
    Anybody has experience with these issues and how to repair them?
    Somebody is repairing these boards on Ebay for $65. Not sure on my board's price yet, since he doesn't have one posted for my model, but he confirmed that he can repair it. Still waiting on his price.
    I have a feeling that it needs re-flowing a BGA chip(s).
  • tibimakai
    replied
    No luck. I have tried different ways to do the update, but it doesn't work.
    Always ends up with error code 3-68. I don't know what that means.
  • tibimakai
    replied
    No luck yet.
    I'm keep getting an error 3-68 when is all done.
    I will keep trying different ways, but if it won't work, then I don't know whaty else can I do.
    This is a well known issue, with these and other model Onkyos, that they loose the video or even the audio too. On mine I still have audio, but no video.
    I can't get video at all, on any of the video outputs. I have tried composite, component too, no luck.
  • tibimakai
    replied
    Finally I have managed to get to that screen and managed to start the firmware update.
    I'm doing it as I write this.
    I have high hopes, that it will start since the frmware suppose to address no video problem.
  • mmartell
    replied
    I think you can access the menu through the display. Check all Video options.
    Have you done a Reset ?
  • Hannibal_Hector
    Samsung UN39EH5003FXZA won't stay powered off
    by Hannibal_Hector
    Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
    03-02-2021, 07:57 PM
  • cmlewis89
    LG 47LB5DF blown power supply board
    by cmlewis89
    Hi folks,
    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
    09-03-2024, 07:50 PM
  • beetle1303
    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
    by beetle1303
    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
    01-13-2025, 08:49 PM
  • drscoot
    HP X360 convertible battery blown fuse error, not charging
    by drscoot
    HP Modelnumber: 14-dh0061nb​
    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
    All these 3 batteries are charging...
    12-15-2023, 05:54 AM
  • swerg
    Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
    by swerg
    Hey everyone,
    I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
    I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
    I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
    06-06-2024, 03:39 PM
