Onkyo TX-NR616 won't stay powered on
  • tibimakai
    replied
    Re: Onkyo TX-NR616 won't stay powered on
    I'm trying to repair a 609, with no sound issue as well.
    I have replaced the DSP, with a D version one and I still have at DSP Netthe ???????
    It seems like communication, (or most likely lack of it) between ICs could also be the problem.
    I have got a new nand flash, found a bin file firmware and flashed it, but there is still no change.
    I don't have audio, USB and network. USB and network are grayed out.
    At avsforum:
    http://www.avsforum.com/forum/showth...4#post54833294
    TJMotter seems like he knows what is talking about.
  • srt1
    replied
    HI, I got onkyo tx sr616 , it also have same issue no sound. i checked the firmware version its showings D??????????? and A????????????. is it dsp chip failure or its power supply? USB also not recognizing, i have doubt if its dsp failure sound should come pure direct mode right? i am not getting any sound in pure direct mode also
  • spalkeris
    replied
    please find attached Onkyo TX NR 616 (also TX NR 414 515 HT-RC470 DTR-30.4 )service manual.
    Does anybody has REPAIR GUIDE?
    I have 616 which oacatinally won't stay powered on or does not switch on at all.
    Also theres no sound , but FM tuner and dislay works,
    I just repaired burnt AMP part, so going further
  • tibimakai
    replied
    The 609 schematic, is available at elektrotanya.
  • selldoor
    replied
    Originally posted by Rupke
    Hello There,
    I'm new here but I am searching for the service manual for the Onkyo TX-NR616 can anyone help me with that?
    Thanks for your help!!
    Did you try the one in post 4 - anything like?
  • Rupke
    replied
    Hello There,
  • tibimakai
    replied
    Mistake
  • selldoor
    replied
    try reading posts 4 and 5
  • nuevonuevonuevo
    replied
    Hi,working on a TX-NR616..and we are looking for id of Q5416 (K149),,also,if we can get copy of the service manual..Thanks...Blessings !!!
  • tibimakai
    replied
    Yes.
    You may have to force it slightly, but it will work. I have it this way on the 616 and 626.
  • mmartell
    replied
    Where is this other plug, on the same board ?
  • tibimakai
    replied
    Good news.
    Switch over the fan plug, to the empty one, to run constantly.
  • mmartell
    replied
    Unit has been returned to me. Has not been tested with speakers but the speaker icons light up where they didn't before.
    Looking through the vent I can see the hdmi board has been replaced, not repaired.
  • tibimakai
    replied
    But that is a BGA no and I can't see the pins.
    replied
    you should be able to tell from the soldering.
  • tibimakai
    replied
    I'm wondering, if the Ebay repairman replaced that dsp, or just added that daughterboard board.
  • mmartell
    replied
    My understanding is that the TI dsp actually fails, possibly heat related and that it has been superceded by a newer design which may or may not still need the daughterboard. If they are kind enough to return mine I will update.
    replied
    i suspect there is a regulator circuit on the board that cant handle the current.
    i say this because that fix-foto shows an added switching regulator board added.
    maybe start on a faulty one by checking the voltages on the chips starting wih the hdmi chip - as we know they can use a lot.
  • tibimakai
    replied
    Update us with the results.
    I'm wondering what is exactly this issue?
    I know that when devices are connected to the receiver, they won't get out audio or video at the HDMI output.
    This is an another issue?
  • mmartell
    replied
    Prepaid postage box on the way
  • Hannibal_Hector
    Samsung UN39EH5003FXZA won't stay powered off
    by Hannibal_Hector
    Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
    03-02-2021, 07:57 PM
  • cmlewis89
    LG 47LB5DF blown power supply board
    by cmlewis89
    Hi folks,
    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
    09-03-2024, 07:50 PM
  • beetle1303
    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
    by beetle1303
    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
    01-13-2025, 08:49 PM
  • drscoot
    HP X360 convertible battery blown fuse error, not charging
    by drscoot
    HP Modelnumber: 14-dh0061nb​
    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
    All these 3 batteries are charging...
    12-15-2023, 05:54 AM
  • swerg
    Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
    by swerg
    Hey everyone,
    I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
    I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
    I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
    06-06-2024, 03:39 PM
