Onkyo TX-NR616 won't stay powered on
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this receiver today.
    When I turn it on it powers up shows Volume 30 and then turns off.
    I took it apart and right away I have noticed the two final transistors were blown. 2SC4468/2SA1695 pair had there plastic body completely blown off.
    There is another vertically mounted board which I believe is the pre-amp section of the amp. There is a 22uF/50V capacitor, which it was completely blown out of the board. The aluminum housing it was blown off and some kind of "hair" like stuff it was all over that area and some film pieces from the capacitor too.
    I can't find the SM for this unit, but there is available the TX-NR609 at elektrotanya(it's over 17MB). It seems like both are using the same amp, at least at a first glance. I will have to compare them. Amp section is on pages 8 & 9.
    It seems that only one channel had a short(Surround rear), the other ones not showing any short.
    The 2SA1930 and 2SC5171 pair seems fine. 0.22ohm(dual resistor) resistor seems fine also.
    I'm wondering what else could be damaged? I will test all the transistors at that channel, just to be sure, even the resistors.
  • JimmysTGP
    • May 2012
    • 45
    • US
    Re: Onkyo TX-NR616 won't stay powered on
    I would change out the whole preamp if you can. I played around with a carver receiver that was very similiar. hopefully all that happen was the cap blew which took out the output, but if your luck is like mine the whole preamp took a dump. good luck.
      The cap often blows on these. I powered on one with the protect circuit inhibited (foolishly!) and the cap went "pop" quite violently! What happens is the 22u/50V cap gets about 100V across it when there's a fault, and it doesn't really like that. You get a few seconds hissing as warning.
      I would suggest you replace all the transistors in the pre-driver section at the same time as the main outputs and avoid using transistors from China if you can, many are fakes.
      • tibimakai
        • Jan 2012
        • 3680
        The problem is, that there are 14 transistors including the finals.
        Q5416, Q5066 and Q5076 show weird readings. I will have to remove them and measure them outside of the circuitry.
        The capacitor that blew up is the C5446 and it's between the two "final" transistors of this board, Q5256 and Q5266.
        The TX-NR609 schematic, seems like it matches with the 616.
        • tibimakai
          • Jan 2012
          • 3680
          Found the bad components and they are:
          Q6056= 2SC4468(2SC5242)-I don't understand why there is a second part #
          Q6066= 2SA1695(2SA1962)-same here
          Q5416= 2SC1740S
          Q5446= 2SA949Y
          Q5436= 2SC2229Y
          R5476= 82 Ohm
          R5366= 18 Ohm
          C5446= 22uF/50V
          The final transistors I have found at Digikey, but how do I know how matched they are?
          The rest of the transistors, I have found only on Ebay. Do you guys I could use some equivalents?
            Transistors from Digikey will be fine. They should be matched OK.
            Which ones can't you get from Digikey? Maybe some subs/alternatives can be located. As said previously, a great deal of transistors from eBay are fakes. I wouldn't feel right about selling an amp with fake transistors in it. Could just go bad a few days later...
            • tibimakai
              • Jan 2012
              • 3680
              I have found only the two finals at Digikey.
              I have checked Mouser, Newark. They don't carry these.
                Q6056,Q6066 are the finals? The different parts will be subs for each other. But if you use 4468, you must use it with 1695.
                  They are complimentary pair (NPN/PNP) output power transistors, so you need to use them in pair as Tom has suggested.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Yes Tom, those are the finals. That small schematic's parts can be found on the main PCB and the other is a vertically mounted PCB plugged in, in a couple of connectors found on the main PCB.
                    The finals can be found at Digikey. The others are not.
                    I'm picking up a Yamaha HTR-4065 too.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Any input on the rest of the transistors? What do you guys think about NTE equivalents?
                      • tibimakai
                        • Jan 2012
                        • 3680
                        I have ended up using NTE transistors.
                        Replaced all the above mentioned transistors, the two resistors and that 22uf capacitor.
                        The receiver turned on and stayed on like 15-20 seconds and then something smoked from the same channel and turned on. I have turned it on gain and it showed Check speaker wires.
                        I have checked the transistors that I have replaced and they seem OK.
                        The 0.22ohm resistor still looks OK. It looks like only the finals are completely shorted each way I'm measuring.
                        What do you think that I have missed? There are two transistors on the main board and they also look good. Back of the transistors are not touching the heatsink.
                        I will have to take some pictures.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Replaced the two final transistors on the mainboard.
                          Did not find anything else blown, on the mainboard.
                          On the pre-amp board, the two previously found R5356(18 ohm) and R5476(82 ohm) were blown again.
                          But this time, it didn't seem like the transistors were effected.
                          That is possible that only the resistors are blown and the transistors are not affected?
                          I can't find a bad transistor on that board. The only difference I'm noticing if I use the transistor checker is between the collector and emitter of the Q5416 compared to other channels. At other channels, shows around 1-1.1mv and this one beeps and it shows 0.75mv. I'm using a NTE85 in it's place of C3198.
                          I wouldn't like to blow it up again. Any help would be appreciated. If I cut the final transistor's legs, the receiver it's working. I haven't seen any HDMI signal on a TV yet, but I will deal with that later on. Hopefully there are no issues there too.
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            Measure the voltage between C and E of Q5416.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I haven't installed back the pre-amp board. I'm afraid that I will blow it up if I would install it and turn it on.
                              Should I remove the the final transistors and then turn it on?
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                Yes, remove or disconnect the output transistors first.
                                We also need to close the feedback loop to enable the amp to balance itself. I need to think about this a bit more,
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  Connect NFSBR 9 to the - of C5446.
                                  Short C to E of Q5416.
                                  Replace the burnt resistors you noticed earlier and check all 4 driver transistors for shorts.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    All the burned components are already replaced. I will have to remove the finals then.
                                    What we are trying to accomplish with these modifications?
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      First we want to see that the output will balance to zero volts.
                                      If all looks ok without the same resistors burning out again, we can then have a closer look at the bias circuit for problems.
                                      The short between C and E on Q5416 makes the bias circuit safe for now.
                                      The idea is to be certain that all is ok including the bias circuit before the finals are connected.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        So, I did those connections and nothing blew up.
                                        Where should I measure the output, at +BSBR23 AND +BSBR22?
                                        If yes, then at those points I'm measuring -.001V/-.003V.
                                        • Hannibal_Hector
                                          Samsung UN39EH5003FXZA won't stay powered off
                                          by Hannibal_Hector
                                          Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
                                          03-02-2021, 07:57 PM
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
                                        • EvazX
                                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                          by EvazX
                                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                          However, after some time, the replacement motherboard...
                                          08-25-2025, 06:09 PM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
