Onkyo TX-NR616 won't stay powered on
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Onkyo TX-NR616 won't stay powered on
    Originally posted by tibimakai
    So, I did those connections and nothing blew up.
    Where should I measure the output, at +BSBR23 AND +BSBR22?
    If yes, then at those points I'm measuring -.001V/-.003V.
    They are the correct places to measure for zero volts balance.
    Next, I would like to see what the voltage amp stage's bias current is. Can you measure the voltage drop across R5166 and R5226?
    Should be about 0.8v if my did my sums right.
    • tibimakai
      • Jan 2012
      • 3680
      I just have to place both meter leads across each resistor?
      • rievax_60
        • May 2012
        • 897
        • australia
        yes
        • tibimakai
          • Jan 2012
          • 3680
          Yeah, it's around there. Slowly it's creeping up though.
          Tomorrow I will continue.
          Thank you very much for today. I appreciate it a lot.
          • tibimakai
            • Jan 2012
            • 3680
            What would be the next step?
            My next receiver will be a Yamaha HTR-4065. There is only a blinking power LED when turned on.
            • rievax_60
              • May 2012
              • 897
              • australia
              #26
              Check the bias circuit next by removing the short across Q5416.
              The bias circuit is supposed to control the voltage difference between the bases of Q5436 and Q5446 to some precise voltage of around 2v.
              Its when this voltage goes too high that all the transistors turn on heavily and cause damage.
              Put a 5.6v zenner doide or a 1K resistor from C to E on Q5416 and take some voltage measurements.
              The finals must not be fitted yet.
              • tibimakai
                • Jan 2012
                • 3680
                So at the bases of those two transistors should be 2V?
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  #28
                  The voltage measured between the Bases should be about 2v. If the amplifier stays on, you can carefully measure this voltage in the good channel.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    So not from the ground to the bases. Between bases right?
                    From ground I'm getting ~23V and ~24V slowly rising to these voltages.
                    The amplifier stays on.
                    There is no room to measure, I'm soldering wires those the points that I have to measure.
                    "you can carefully measure this voltage in the good channel", if I understand correctly, I have to measure between bases on a good working channel, for comparison right?
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Between bases at the bad channel, I'm getting 2.4V
                      The good channel, I have to measure tomorrow.
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #31
                        I didnt expect the Common Mode voltage at the Bases to rise that much. Take readings at +BSBR23 and -BSBR22 also.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have to measure from the ground to each base? The voltage rises slowly.
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            #33
                            The measurements you took last week indicated that the amp was balanced. It seems to be unbalanced now. Did you leave the link from C5446- to NFSBR9 ?
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #34
                              When measuring voltage on transistor Bases in an output stage, its useful to measure the difference voltage and the Common Mode voltage wrt Ground.
                              The difference voltage has a large affect on the idle current through the final transistors.
                              The common mode voltage affects the output DC which we want to be within 50mv of zero volts.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Yes, I have removed it and soldered in that 1K resistor.
                                Should I solder back that link?
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  #36
                                  I got you to fit two links originally. What have you done since?
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    What we have discussed here.
                                    Today I had a little bit of time and I did what you have told me. Removed the link and added a 1k resistor.
                                    I wasn't sure about the other link, so I have removed it. Should I put it back?
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #38
                                      Yes, you should have left the other link in.
                                      • rievax_60
                                        • May 2012
                                        • 897
                                        • australia
                                        #39
                                        If the voltages at the bases of Q5446 and Q5436 look ok. The next thing to measure are the voltages that would be applied to the bases of the finals.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          OK, at the Q5436 base I have 1.8V and the other only 0.64V.
                                          I'm not sure how to measure another channel? As is, or I have to place the same link with the resistor there also?
                                          • Hannibal_Hector
                                            Samsung UN39EH5003FXZA won't stay powered off
                                            by Hannibal_Hector
                                            Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
                                            03-02-2021, 07:57 PM
                                          • cmlewis89
                                            LG 47LB5DF blown power supply board
                                            by cmlewis89
                                            Hi folks,
                                            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                            09-03-2024, 07:50 PM
                                          • EvazX
                                            ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                            by EvazX
                                            I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                            Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                            For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                            However, after some time, the replacement motherboard...
                                            08-25-2025, 06:09 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                          • drscoot
                                            HP X360 convertible battery blown fuse error, not charging
                                            by drscoot
                                            HP Modelnumber: 14-dh0061nb​
                                            This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                            The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                            I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                            And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                            All these 3 batteries are charging...
                                            12-15-2023, 05:54 AM
