Onkyo HT-R591 keeps clicking
  • tibimakai
    • Jan 2012
    • 3680
    Picked up this receiver from Ebay.
    It's in new condition, came with all accessories except for the setup mic. All for $75. This is the receiver from the Onkyo HT-S5500 package.
    As I plug it in, it begins clicking on and off. Nothing shows on the display.
    There is a small power supply board, where the 110V cord goes too, from this board a harness goes to the main transformer and other places as the HDMI board, etc.
    On this board there is a small transformer looking relay, which is the one that clicks.
    I have measured with an ohm meter the final transistors and I didn't find any of them shorted. Most of the values were over 330k, and some of them around 70k.
    There are two rectifier bridges, they look OK too. I have noticed three fuses and they are also OK.
    Voltage toward the transformer looks pretty solid, it not getting turned on and off.
    Any advice would be appreciated.
    Anybody has a service manual by any chance?
  • tibimakai
    • Jan 2012
    • 3680
    Re: Onkyo HT-R591 keeps clicking
    Found a HT-R590B service manual.
    I will have to compare it with my boards though, to see how close are to each other.
      That is probably the power relay that supplies the 120V to the primary side of the Main power transformer, that is the typical setup. I will download the service manual and see. It should have big filter caps for the power supply. Do you see any DC voltages on the caps?
      On page19 bottom right, you can see small board with small transformer and where the MAIN AC comes in and feed the standby power supply transfromer, the AC output is through the power relay to feed the transformer (TRANS IN).
      • tibimakai
        • Jan 2012
        • 3680
        It's my first time working on a receiver of this type, so I have to find where are all the components of the power supply. I don't understand why there are two rectifiers, for example.
        I have removed the back cover to see better what is where. Which capacitors should I measure, there are two big ones on the main board(amp)?
        I haven't measured much yet.
        I have worked on three Harman Kardon AVR1700 receivers a little while ago, but those use the same power supply type as the LCD TVs.
        (this is why I haven't had much time measuring on the Sony TV)
        Thank you for helping.
        • tibimakai
          • Jan 2012
          • 3680
          Some pictures with the receiver, front and back view.
          It's pretty new and nice receiver.
          I own two other models, TX-NR515 and TX-NR609.
            There should be one big power rectifier D6901 that supplies +/- voltages for the power amp section, then there should be more rectifier for other lower voltage power supplies. There are 4 secondary windings of the power transformer. There are 9 relays on the main board! see page 7.
            • rievax_60
              • May 2012
              • 897
              • australia
              I would check the thermal fuse next. It is built into the large mains transformer in series with the primary winding.
              • tibimakai
                • Jan 2012
                • 3680
                Found all those in the schematics, now I just have to get home to find them on the board/transformer and measure them.
                Thermal fuse how it should show, if it's bad?
                  Like a normal blown fuse - open circuit.
                  • newbiesat
                    • Dec 2012
                    • 25
                    • usa
                    It may be a "BLOWN AMP" that causing. Do you check those output transistors to find if anything shorted?
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Yes, I have checked. The lowest resistance that I have measured it was 73 Kohm.
                        Just check the main power transformer to see if the primary is open, or if it is getting 120Vac. The Thermal fuse is inside the transformer, the transformer temp will have to get about 110~120C before tripping the fuse. By the way, does the front panel light up at all?
                        Also this amp uses STK Power amp modules.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I remember that, I have unplugged the transformer from that little power supply board and it was still clicking on and off.
                            The relay on that standby power supply board as shown in post 12 diagram is the one that is clicking?
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Yes, at least that I have felt. It looks like a small transformer.
                              I will have to look at it much closer. Late last night I have took the back plate off. I haven't powered it up since. It may be a relay next to that transformer that is clicking and the vibration may transmit over to the transformer.
                                The only function for that relay is to supply the 120V to the primary side of the Main power transformer. The power on signal is from the main board that send the signal to turn on the relay (just like PS_ON sIgnal for TV, in this case it is the relay driver), this signal should not be pulsing so you need to monitor that signal pin to see if it is steady or not. If you connect pin 1 and pin 4 of the connector as shown in post 12, the relay will be forced on. You can also connect a small 7Watts night lamp at the main power transformer connector to monitor the action of the relay and use it as an indicator.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  It's getting the 120V at the connector.
                                  Front panel doesn't light up at all.
                                  The finals are transistors. This SM may not be for this exact model.
                                    Have you checked you're getting an output from the transformer? If the thermal fuse is blown you'll have to disassemble the transformer to get to it. To test, volts AC across one coil. For a 50V split supply amp (+/-50V) approx 35VAC should be observed across each main power coil going to the amplifier section.
                                      Can we see the inside of the unit?
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Here are some pictures:
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
