Onkyo HT-R591 keeps clicking
  • tibimakai
    • Jan 2012
    • 3680
    Re: Onkyo HT-R591 keeps clicking
    On page 11 there is the power supply schematic. Do you have those voltages: 10V, 12V? What do you measure on the other pins?
    • r3ap3r911
      • May 2014
      • 14
      Thought I had the proper service manual but I guess it's for a HT-R591 not a 591.. any chance you have it to share?
      • r3ap3r911
        • May 2014
        • 14
        I have HT-R590 manual not 591
        • tibimakai
          • Jan 2012
          • 3680
          I have the same thing.
          May not be much of difference between them.
          Maybe the 590, it's a European version of the 591.
          Did you compared the schematic with he actual pcb designation, if the parts designation match, then you can use it.
          • r3ap3r911
            • May 2014
            • 14
            On P911 I see 32.5v on one side and 13.4v on the other side
            • tibimakai
              • Jan 2012
              • 3680
              Do you have those on your Onkyo?
              • r3ap3r911
                • May 2014
                • 14
                That's what I was reading right off the pins but noticed I had a bad ground.. off the main transformer output I'm seeing 23.5v off each pin. Not sure what it should be though
                • r3ap3r911
                  • May 2014
                  • 14
                  Can i check the main transformers thermal fuse with it still connected?
                  • r3ap3r911
                    • May 2014
                    • 14
                    Originally posted by chozo4
                    I would closely inspect every possible joint - at least around the fets/transistors. If a joint is suspect simply reflow the solder and continue inspecting the others.
                    Examples of such joints:
                    Earlier I took out all the boards and checked all the joints and re flowed a couple that looked iffy but nothing was clearly broken.. put it all back together with same results.. amp is clicking (relay on ps board before main trans).. everything seems to be getting power when metered 23.6v or so.. When I unplug the P911 from ps board to main trans it stops clicking.. not real sure what else to check. All the final transistors and ceramic resistors are ok. /shrug
                    • r3ap3r911
                      • May 2014
                      • 14
                      Anyone?
                      • artois7
                        • Mar 2011
                        • 159
                        #91
                        Still need help with this?
                        • IDoSeaDoo
                          • Jul 2015
                          • 10
                          I have the same problem. I noticed that the joins coming out of the PCB on the rear side of the transformer had some golden glazing all over them. I used the needle of my ohm-meter and scraped that crud off from between the joints(with it unplugged). Turned back on and so far so good... I think that stuff was causing some current to be leaking across the joints. I hope this fixes it. I was about to buy a new receiver.
                          • IDoSeaDoo
                            • Jul 2015
                            • 10
                            well, my excitement was short lived. i turned on some tunes and was just broke the good news to my wife when it cut off and started doing its stupid relay dance again looks like I have to figure out how to test that thermal fuse...
                            • IDoSeaDoo
                              • Jul 2015
                              • 10
                              Can I remove the thermal fuse and just test the unit by bridging that connection with a jumper? I plan to unsolder just one end of it. I can't find one like it. Only higher amperage or higher temp ones.
                              • IDoSeaDoo
                                • Jul 2015
                                • 10
                                @tibimakai did you use a 3A fuse or one of the many 10A available on ebay? I can't find anything that's close to 145C and 3A. I feel like I can use a higher amperage one and just get close enough temperature...
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I have used a 150C/10A/250V one.
                                  • IDoSeaDoo
                                    • Jul 2015
                                    • 10
                                    Can I test my fuse by putting a jumper across those terminals where the fuse solders in?
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I'm not an expert, but I would do it, maybe using a fuse just in case.
                                      • IDoSeaDoo
                                        • Jul 2015
                                        • 10
                                        Good call, I don't have any non-automotive fuses laying around (I don't think). I'll go try to find one and use it. I'll let you guys know. @r3ap3r911, any luck figuring out your problem?
                                        • IDoSeaDoo
                                          • Jul 2015
                                          • 10
                                          Well, it turned out I did have some 250V 5A fuses laying around. I put one between two test leads and bridged the connection between the yellow wire and the center pin on the transformer and was sucessfully able to watch an uninterrupted hour of comedy with the wife and friend. Looks like that thermal fuse is my culprit as well. I am not sure how you got it out of there by just removing the plastic pieces, but I am about to try it myself. I looked very carefully under the plastic and can't see the fuse under there. Will dig into it tonight probably. Oh and I found a 142C 10A 250V fuse at a local Radio Shack. I figure 3C isn't too much a difference. Going to try it.
                                          What was the importance of wrapping it in heatshrink tubing?
                                          • Sisko
                                            Onkyo-593 No power and now clicking sound
                                            by Sisko
                                            Hi all!!
                                            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                            10-03-2025, 02:18 PM
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
                                          • learnmore
                                            Help choosing replacement transformer for Levoit 600S SMPS
                                            by learnmore
                                            Hello Community,
                                            I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                            Peace
                                            LM...
                                            11-04-2025, 09:35 AM
                                          • ohren
                                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                            by ohren
                                            Hello!
                                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                            Measured voltages with no load:
                                            After rectifier diodes
                                            12V: 6.17 V
                                            5V: 5.67 V
                                            Secondary transformer pins AC measurement (really don't know if this says anything)
                                            12V: 2-2.5 V
                                            5V: 1.04 V
                                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                            03-18-2023, 10:33 AM
                                          • mikey5791
                                            Is it possible for transformer substitution?
                                            by mikey5791
                                            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                            My questions are
                                            1. How do i test to see if the transformer is in good working condition?
                                            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                            Hope you guys understand what i was asking. My intention is...
                                            11-03-2022, 02:11 AM
