Onkyo HT-R591 keeps clicking
  • tibimakai
    • Jan 2012
    • 3680
    Re: Onkyo HT-R591 keeps clicking
    Here this video will help:
    https://www.youtube.com/watch?v=1xIlqe-P1CM
    • IDoSeaDoo
      • Jul 2015
      • 10
      So I found this to be strange: I had my alligator clips/fuse connecting the two pins that the thermal fuse is connected to, and it still did the power flicker thing. I even cut one of the thermal fuse leads and had just the fuse link in there, and still had the same issue. Are those leads coated with something to prevent a good contact? The ohm meter said there was no resistance in the leads or the thermal fuse. I tested all the transistors, no shorts there. I tested all the ceramic resistors and those all seemed to measure 0 ohms. Because they were all the same, I guess they are okay.
      I'm starting to wonder if the issue is not somewhere in the first little transformer near where the power plugs in.
      • IDoSeaDoo
        • Jul 2015
        • 10
        I replaced the thermal fuse, and am still having the issues. Sometimes, the whole receiver will shut off and not power back on for days. When it does come back on, it'll stay on, but occassionally (and with no time-based pattern I can discern) will flicker on/off. I popped the relay cover off on the relay next to the incoming transformer (where the power plugs in) to see if it's burned out or flawed, but it looks perfect. When it works, that relay clicks on and off with no big spark, but when the power flickers on/off, there is a huge blue spark at that relay when it shuts off. It was doing this with no speakers plugged in. All the transistors and their respective resistors (on what I think is the amplifier board) tested fine (not shorted). Where should I look next?
        • IDoSeaDoo
          • Jul 2015
          • 10
          is there such thing as "Checking for a ground" in the world of AC electronics? I have a mechanical background and that is a common issue with DC marine electronics.
          • ElricX
            • Aug 2015
            Thanks you for this service manual, it's the only place on the web I found it!
            • elunltd
              • Aug 2012
              I have the same problem, any chance I can obtain that service manual for the HT-R591? It seems the HT-R590 is very different. Thanks
              • Sisko
                Onkyo-593 No power and now clicking sound
                by Sisko
                Hi all!!
                Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                10-03-2025, 02:18 PM
              • CDNBrewer
                Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                by CDNBrewer
                Hello Everyone,
                I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                Symptoms:
                • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                • I swapped the Left and Right surround
                08-05-2025, 09:29 PM
              • learnmore
                Help choosing replacement transformer for Levoit 600S SMPS
                by learnmore
                Hello Community,
                I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                Peace
                LM...
                11-04-2025, 09:35 AM
              • ohren
                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                by ohren
                Hello!
                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                Measured voltages with no load:
                After rectifier diodes
                12V: 6.17 V
                5V: 5.67 V
                Secondary transformer pins AC measurement (really don't know if this says anything)
                12V: 2-2.5 V
                5V: 1.04 V
                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                03-18-2023, 10:33 AM
              • mikey5791
                Is it possible for transformer substitution?
                by mikey5791
                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                My questions are
                1. How do i test to see if the transformer is in good working condition?
                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                Hope you guys understand what i was asking. My intention is...
                11-03-2022, 02:11 AM
