Kenwood DNX6990HD service manual needed
  • 68pishta
    • Jan 2012
    • 29
    #61
    Re: Kenwood DNX6990HD service manual needed
    Originally posted by mixmansc
    More possible info here - https://www.badcaps.net/forum/showthread.php?p=935350
    I found a Kenwood updater that is not their normal firmware update. It reloads everything on a few models including the 570HD.
    I need that uploader! can you repost the link? Mine lost a bunch of icons (image not found) and I think a reload would fill in all those pesky "image not found" placeholders. As for the voltage, I was running it off a UPS battery 12.2V and it was very laggy. Im wondering if the 13+ voltage is really needed as it sure works better off a fresh charge than a 11.8V reading. My test batteries are old so they work for about an hour before the thing starts to boot loop at 11.5V. I have a 690 on the way with a no power issue, hope its a reflow fixer or else Ill just harvest the onboard uSD card on the GPS board or even the whole thing. Mine works but the nav is wonky.
    • tibimakai
      • Jan 2012
      • 3680
      What has to be reflowed?
      I have a 570, that won't boot up anymore, but the fan is running and the red triangular LED is on.
      • 68pishta
        • Jan 2012
        • 29
        #63
        I understand the GPS card can take a reflow and fix a red power with no display. 240C at 80s to reflow lead free solder.
        • tibimakai
          • Jan 2012
          • 3680
          Which component has to be reheated?
          • tibimakai
            • Jan 2012
            • 3680
            OK, I have reflowed the main CPU on the GPS daughterboard, and it came to life. Yeahh!!
            I have added some thermal pads between the DVD drive and the Aluminum heat sink, to transfer some heat. Hopefully will last longer.
            • Marlonmo
              • May 2022
              • Brasil
              #66
              Hello, I live in Brazil, I can't find a place to repair my DNN9710BT, that is similar to the DNN991HD.
              Same Service Manual that I don't have!
              I't don't start. Only show the red light, turn on a black screen, fan always on and anything I've tryed is working.
              I't don't power the USB light of my USB Flash Drive , them, I think that it's impossible to reinstal the firmware.
              Sorry to ask you, but I really need Help.
              I've just have finished to pay for it.
              • Cliffton
                • Jun 2024
                Thought I had lost this service manual but came across it today.
                • DrDos
                  Unit runs but no speaker output kenwood KR-6030
                  by DrDos
                  I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                  09-14-2025, 09:57 PM
                • stefoulis
                  blaupunkt mca service manual needed
                  by stefoulis
                  i am looking for a Blaupunkt MCA service manual.
                  Thanks in advance.
                  Stefanos
                  Yesterday, 08:17 AM
                • Mark R
                  The Overseas Only Kenwood Model KR 790
                  by Mark R
                  I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
                  The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
                  09-23-2025, 08:27 PM
                • iR0ck
                  LG 38gl950g Service Manual needed
                  by iR0ck
                  Hello everyone. Could anyone please share the service manual for the LG 38GL950G monitor? I have been using it for four years and just noticed that the PCB fan has never worked. The self-test also shows an error. It would be great if I could repair it somehow.
                  12-01-2024, 07:20 PM
                • domix
                  LG Air Conditioner AC unit bypass
                  by domix
                  i have Lg AC indoor unit connected to heatpump warm water. To flow thru unit. I have it to heating up garage. I have previus old indoor ac unit. It was only connected to power supply and is was woking.
                  Now i have new one which has a problem, it needs outdoor unit. It has error, 5 blinks which means that outdoor unit is not connected.
                  how can i bypass this :/
                  I need only to turn on and i need only fan to blow, and adjust speed od fan. To blow over a warm pipes....
                  11-25-2025, 02:54 PM
