Kenwood DNX570HD No boot Red Triangle Lit - Characteristic Fault?
  • ac4aq
    • 5
    I'm hoping to find the answer to a no boot, red triangle illuminates fault in a Kenwood DNX570HD. I have two of these double-DIN head units and they both have the same failure mode, which makes me think it may be a characteristic fault, but so far I haven't been able to unearth any intel on this.
    The symptomology for both is: when power applied to red/yellow leads, the red triangle illuminates for about 40 seconds and the fan starts. After this time passes, fan stops and the triangle goes dark. Pressing the red triangle reset causes the same sequence to repeat.
    I have the service data on this unit and checked the voltage regulator module, IC200 (syscon IC) reset and clock oscillators. I cannot say for certain if IC200 is not seeing a monitoring input it needs or if its firmware is corrupt or if it has failure to communicate with one of the sub-micro's, such as the front panel controller.
    Unfortunately mum's the word from Kenwood on this, so if the nature of this fault is know, please give us the golden key.
    Thanks, Jeff de AC4AQ
  • tibimakai
    • Jan 2012
    • 3680
    Re: Kenwood DNX570HD No boot Red Triangle Lit - Characteristic Fault?
    I have one of these as well, with the same symptom. I haven't really looked into it yet. We have just purchased another one.
    I have seen a few on Ebay, with the same symptom.
    • mixmansc
      • Apr 2014
      • 4
      I've seen over a dozen Kenwoods with the same issue. It seems to affect multiple double din models and years from the DNN and DNX 4 digit models to the newer 3 digit models. Right now I have at least 4 of them sitting on a shelf hoping I can find a fix.
      A separate issue is the nav software gets corrupted on them and will cause a blank screen or a garbled screen if nav is selected. I can fix that - there is a micro-sd card inside the unit. Has a funky partition scheme but I can copy it. You can also put the card in the external slot leaving it out of the internal one as well and even put updated maps on it. I know this part pertains to the 2013, 2014, and 2015 models (example, DNX690HD, DNX691HD, DNX692).
      On the 2016 models Kenwood changed them from running WindowsCE to Linux and the nav software is on a flash chip on the daughter board instead of a micro sd card. The 2016 and newer are also a lot faster but a few other differences - nag screen is on system boot instead of when launching the nav. Multiple hidden menus can be accessed by tapping the screen in particular spots and a particular order. I've also seen at least one 2016 model that has the same "death" where you just get the red triangle.
      From what I've been able to figure on all of them is there is not a hardware problem. The main system firmware on an on-board nand chip has become corrupted in some way. I think the key to fixing them will be getting a chip dump from a working unit and somehow flashing that onto the chip in the dead unit either in-place or by replacing the actual chip (still would require the correct firmware).
      I've not had time to poke enough yet but what I've been hoping for is to potentially locate a serial or lower power TTL serial set of contacts on the main board. If that could be located then its quite possible one might find a bootloader and be able to reload software via a serial console which would be much easier (for me anyways).
      Some other info in this thread - https://www.badcaps.net/forum/showthread.php?t=30525
      Now - specifically for the DNX5080EX, DNX570HD, DNX690HD, and DNX890HD I have a factory "dealer" updater that will likely fix the 570 units you have. It fully loads ALL software including the Garmin software and it will be at an old version but you can update it afterward. I wish I could get ahold of this type of an updater for later models too. I have a couple of 691's, a 572, a 692, and a 693 around that are all pseudo-dead.
      I have uploaded the "dealer" updater for the 570HD here - take a look and let me know if it fixes yours. I have used this to recover several 570HD units.
      https://drive.google.com/open?id=1mi...gRKq1zY_1vgWgH
      • tibimakai
        • Jan 2012
        • 3680
        Thanks for all that.
        I will try it out, and let you know about the outcome.
        • tibimakai
          • Jan 2012
          • 3680
          The USB has to be formatted in FAT? I have tried FAT32 and nothing happened.
          On mine, the backlight turns on, but nothing else.
          • tibimakai
            • Jan 2012
            • 3680
            Just to be clear, mine does not show any kind of image since it is started. The only thing that comes on, other than the red triangular LEd, is the backlight.
            I can turn it off, by the button, so something is working alright.
            Most likely, my issue is different than yours. Yours has a corrupt Garmin software.
            • ac4aq
              • 5
              I tried the dealer firmware reload but so far I can't initiate the upload. The instruction in the .pdf at Step 4 is ambiguous: it says connect the USB memory device to the USB terminal, not to the I-pod terminal then turn ON. The only USB on the DNX-570HD is the one on the extension cord, the only I-pod connection is by Bluetooth, I believe. (I don't have an I-pod.) I can't turn the unit ON, when I connect 13 VDC to the Main and Backup terminals, the red triangle illuminates, the fan starts and both stop after about 40 seconds.
              I suspect the data on IC500 likely is corrupt, but I can't figure how to reload it. The only choice may be to buy the NAND E2PROM from PacParts before they go NLA, the PCBA is already. If I go to that much effort and expense, I will read the IC before I solder it on, so I'll have a "pure" fileset, for the next time it croaks.
              Thanks for the help, Jeff/jHh
              • mixmansc
                • Apr 2014
                • 4
                Yeah on both that sounds like the main system is corrupted. There is a way to reprogram them but ONLY if you can get ahold of the correct and specific files that it needs. The internal daughterboard has a connector that can be used for USB debugging and firmware loading via Telechips FWDN utility. You have to remove the disc drive, tie a USB cable into three pins, then short a couple of pads while powering it up and it will show up in Windows Device Manager (also need the FWDN drivers and it only works on Windows 7 and older) and the FWDN utility can then connect and start uploading the firmware. If FWDN does not make a connection after about 20 seconds the unit shuts back down. There is a guy with an electronics service business in Johannesburg South Africa (he is legit) that can get the software as well as provide instructions on how to connect, where the pads, etc are and then will walk you through the process. I think he charges $100. https://www.facebook.com/karstensaudio
                I cannot vouch for him myself as I've not used his service but someone I know and trust referred me to him.
                • tibimakai
                  • Jan 2012
                  • 3680
                  Do you mean the Micom is corrupted?
                  I had this issue in the past with another unit, and Kenwood has replaced the Micom.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    System Mi-Con IC206.
                    • jrenaudier
                      • Feb 2020
                      • 3
                      • Argentina
                      Hi guys, I new on the forum, I have a DNX890HD that I´m sure that use the same software that 570HD Unit. I have removed the IC 500 (NAND Flash Memory) from the daughter board, because I think that the software on it is corrupted.
                      I think that we can create a image bank for it Flash Memory and others units to fix this recurrent issue on Kenwood car radios. I would appreciate if anyone can share a valid dump of the DNX570, 5700, 690,5230, 5330 etc.to try load on my flash memory. If someone are interested, I have a dump of the DNX9980HD, just let me know and I will share this file.
                      Thanks in advance.
                      Geo
                      LU1CHD.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        That would be nice to have dumps, but I don't think, that there are to many that have one.
                        Which reader did you use, to read the dump?
                        The 9980 has a different IC, the newer ones, I believe use a Toshiba IC and requires a more expensive reader.
                        • jrenaudier
                          • Feb 2020
                          • 3
                          • Argentina
                          I know that not all people have possibility to take a dump of the his car radio, but could be good idea to make a repository since the flash memmory is not cheap to buy one every time that we need to repair a unit. Personally, I´m using a RT809H eprom programmer.
                          The 9980HD, uses the same 2Gb flash memmory like the 570HD with different software inside.
                          Sorry if my english is not clear.
                          Regards.
                          Geo
                          LU1CHD.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I have only a TL866, which I don't think can read the IC.
                            I agree with you, it would be great, but not to many people repairing Kenwoods.
                            Once, I have purchased the IC for a DNX6990 and I have fixed it, it was around $60. Not cheap at all.
                            • lafester
                              • Apr 2021
                              • us
                              My dnx570 has the corrupt gamin issue. Everything else still works fine but navigation only works for a couple minutes before it goes haywire. A reset fixes it, but only for a couple minutes again.
                              I see you mention the internal sd but do not say what needs to be done here. I imagine my data is fine, but the sd is just not able to keep up anymore.
                              I would also try flashing the entire firmware but your link is no longer valid.
                              If anyone has any info on either of these possible fixes I would love to try them. I am removing the unit but it really works fine outside of navigation.
                              • redwire
                                • 3907
                                I have DNX Ver. 1.6.0 firmware 78MB, which has a bunch of Garmin files as well as other ROMs. Here is a pic of the files in it. PM if you have a big mailbox for it.
                                There's a separate load for DAB V3.18.11.0.2, but IDK about it.
                                These Kenwoods are really finicky about power on/off and I find that scrambles things if they are not finished booting and you key off or start with a weak car battery.
                                • Jedailey
                                  • May 2021
                                  I'm curious about that "dealer" software you have linked in your post, but the link doesn't seem to work. I very much doubt it will help me any, but I'm just wondering if there's anyway that you can repost it, send me the link etc... I don't mean to be a bother and just happened to stumble across this site today after hours of Google searches and finding tons of people with the exact same issue. Plus I'm a cheapskate and don't want to deal with sending in my unit to Kenwood.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    I have just fixed mine. I have reflowed the main CPU on the GPS daughterboard and it is working now. Others have resoldered the Toshiba IC, on the same board, but in my opinion, the BGA solder balls are cracking most likely.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Thanks, but as I mentioned on the previous post, that I have reflowed the main CPU on the daughter board and it turned on. It is already sold.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Try reflowing the BGA chip on the daughter board.
                                        • privato89
                                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                          by privato89
                                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                          Let's begin:
                                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                          03-26-2024, 06:37 AM
                                        • hinisa
                                          Xiaomi router freezes at boot after re-capping
                                          by hinisa
                                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                          07-08-2023, 05:58 AM
                                        • Luke Anders
                                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                          by Luke Anders
                                          A few details about the laptop itself:
                                          Name: Lenovo Legion 5
                                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                          BIOS Version: GKCN60WW
                                          EC Version: GKEC65WW
                                          Serial Number: PF39AQ7Z
                                          Board Model: NM-D562 Rev 3.0
                                          RAM: 16GB Installed, DDR4 (brand new)
                                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                          I bought this laptop recently from eBay as a faulty device....
                                          10-12-2024, 05:13 AM
                                        • NolesFan
                                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                          by NolesFan
                                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                          10-24-2024, 06:36 PM
                                        • torchzack
                                          Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                          by torchzack
                                          Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                          I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                          Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                          08-28-2023, 07:42 AM
