Kenwood DNX6990HD service manual needed
    Re: Kenwood DNX6990HD service manual needed
    What are you powering the unit from?
    • tibimakai
      • Jan 2012
      • 3680
      From my 30V/5A adjustable power supply. It consumes ~1.7 A.
      By the way, all three HK receivers are sold. Picked up another refurbished Onkyo, but this time is a TX-NR515.
      I'm thinking about that maybe I should pick up some of these or even TX-NR616 from Ebay.
        You powering it @ 14.4V? Or at least 13.8V?
        • tibimakai
          • Jan 2012
          • 3680
          Yes.
            Hmm, check all the voltages along the amp chip. Especially the outputs supposed to be 7.1V each. No communication on this chip.
            • tibimakai
              • Jan 2012
              • 3680
              The problem is that when it starts up, it won't stay on for long and then shuts off and then I'm not getting almost any voltage, except the IC positive supply.
              At the power supply IC I'm also getting the BU5V(4.94V), which I don't know which one is that.
              It's almost as in a TV, when you have a 2 seconds to black and then only the standby voltage is present. It's very similar situation. I have to wait a long time when I can boot it up again.
              I will have to re-solder the amp IC and take some measurements. It's too hot to work in the garage(96 F).
              • tibimakai
                • Jan 2012
                • 3680
                I had to give the DNX570HD to the Kenwood repair service and they found the MI COM IC defective. W10-0853-08, can be found at pacparts for $50.
                Found the removed IC(M16C/R5F3651NDFC) a lot cheaper at Digikey:
                http://www.digikey.com/product-detai...3U0-ND/2299682
                  That is a microcontroller, it has a set program, you need the program for the micro to work.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I was thinking about that. So I guess pacparts sells one with the program on it.
                    The 570HD is working well now.
                    I still have to get a DVD drive($158+S&H+tax) for the 6990HD and I don't know if the old drive's parameters will work with the new drive. If not, then I will have to give it to Kenwood to do a calibration on it. Luckily they are pretty close to me.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I'm wondering about these guys, which part are they replacing to fix the rebooting issue?
                      http://www.salectronics.com/shopexd.asp?id=1745
                      It seems, like it would be a cheap fix. If they had to replace a board or something of that nature, the repair it would be much more expensive.
                      What would cause, a reboot of these units, corrupted EEPROM?
                      There are so many broken units out there, it would be nice to find a fix for these issue.
                      In one of the forums, somebody claimed that he had two burned USB sticks and the whole USB line it was dead. It could be a 5V regulator?
                      • tibimakai
                        • Jan 2012
                        • 3680
                        I have done some more testing with the unit and I have noticed that if the car is running, then it's fine.
                        As soon as I turn off the car, it starts rebooting.
                        It seems like it doesn't like lower voltages. What could that be? There it could be a bad voltage regulator?
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have connected it directly to the battery, so I guess when the engine is running, the battery gets charged and the receiver works fine.
                          When the engine stops, the battery it's not charged anymore and I guess the voltage drops toward 12V, which it seems like it's not enough for this receiver.
                          I will power it up again from my lab power supply and drop the voltage to see when it's starts acting up.
                          In the service manual(not exactly for the same receiver, but it should be pretty close), there are some charts with all the IC pin voltages, which I could compare with, but I would like to narrow it down as much as possible.
                          Any help would be appreciated.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            This could be an EEPROM fault too, or it's a voltage issue, what do you think?
                            Somebody on Ebay, can fix this issue for $99. I'm wondering what they are doing to them?
                            In some forums, people are saying that Kenwood replaces the ROM chip.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I have sent it out to that shop on Ebay and they have replaced a Toshiba 2GB memory and now it's working great.
                              I have just purchased another one from Ebay, for $172 shipped with all the accessories.
                              The part number is Toshiba TC58NVG1S3ETA10.
                              Do you think, that this part can be replaced by me? Does a memory chip needs any software? The pin's pitch is very small, I'm not even sure, if I'm able to do it myself.
                              • elettr
                                • Jul 2017
                                • Italia
                                #35
                                Hi, I just signed up. How did it fix the problem? Did you figure out if you were just wound up the new flash to fix the car stereo?
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I have done one myself. I have purchased the pre programmed nand(~$65 pacparts.com, or kenwoodparts) and I have replaced it myself. It did not start right away. By touching the touchscreen, it started up. I don't know the reason for this, but that is how I have managed to turn it on.
                                  You may be fine, by just reprogramming the same nand, or a new one, I don't know.
                                  I have asked Flashcat and they said, that this nand would work with it.
                                  • javierulo
                                    • Oct 2017
                                    • Venezuela
                                    #37
                                    hi i need service manual kenwood dnx6990hd or the part number ic31 is dc-dc converter
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I'm at work right now. I have it on DVD. I have purchased it, from pacparts.com.
                                      • army_wang
                                        • Oct 2017
                                        • china
                                        #39
                                        Kenwood DNX6980 service manua
                                        • army_wang
                                          • Oct 2017
                                          • china
                                          #40
                                          Kenwood DNX6980 service manual
                                          • DrDos
                                            Unit runs but no speaker output kenwood KR-6030
                                            by DrDos
                                            I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
                                            09-14-2025, 09:57 PM
                                          • stefoulis
                                            blaupunkt mca service manual needed
                                            by stefoulis
                                            i am looking for a Blaupunkt MCA service manual.
                                            Thanks in advance.
                                            Stefanos
                                            Yesterday, 08:17 AM
                                          • Mark R
                                            The Overseas Only Kenwood Model KR 790
                                            by Mark R
                                            I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
                                            The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
                                            09-23-2025, 08:27 PM
                                          • iR0ck
                                            LG 38gl950g Service Manual needed
                                            by iR0ck
                                            Hello everyone. Could anyone please share the service manual for the LG 38GL950G monitor? I have been using it for four years and just noticed that the PCB fan has never worked. The self-test also shows an error. It would be great if I could repair it somehow.
                                            12-01-2024, 07:20 PM
                                          • domix
                                            LG Air Conditioner AC unit bypass
                                            by domix
                                            i have Lg AC indoor unit connected to heatpump warm water. To flow thru unit. I have it to heating up garage. I have previus old indoor ac unit. It was only connected to power supply and is was woking.
                                            Now i have new one which has a problem, it needs outdoor unit. It has error, 5 blinks which means that outdoor unit is not connected.
                                            how can i bypass this :/
                                            I need only to turn on and i need only fan to blow, and adjust speed od fan. To blow over a warm pipes....
                                            11-25-2025, 02:54 PM
