I have a set of typical late 90's basic PC speakers (Juster AC-691N, made around 1997), they do their job, no problem with them but not very powerful but that doesn't matter much.
Now I want to experiment things a little, is there a way to improve the sound quality and remove the buzzing sound that can be heard when something is plugged to the jack, or even when I just touch the jack (bad grounding maybe ? Lack of shield between the transformer and the amp ?) ?
A sticker on the back says "The unit is double insulated an earth connection is not required".
Will replacing caps with newer good caps change things (caps are CrapXons, and two small unknown brand ones) ?
Speakers themselves are small rectangular shaped, branded WSI FE5090 4, they are 4 ohms and output 2W to 3W max. Very small indeed, can I replace them with more powerful ones with damaging the amp ?
That's only a matter of learning and experimenting things.
Thanks !
Thanks !
