I want to improve some headphone amplifiers that I have. One is based on an MS6308 (a TDA1308 clone), and the other uses an APA3541.
I have two MS6308 chips. One is used as the headphone amp in my computer, and the other is on a motherboard that I have been taking parts from. In the computer, I just need to reduce the gain to match the output of the speaker amp. Replacing the 20K ohm feedback resistors with 15K ohm resistors should work.
For the second chip, I might try to remove it and use it. I would like to know why all of the TDA1308 circuits I see use the inverting input and place resistors in series with the input. Is there a fault with the chip that makes the non-inverting input not work properly? In the computer, the inverting input was used, but the audio signal it receives is inverted by a TL064.
The APA3541 sounds horrible. It is the worst excuse for an amplifier I have ever heard. I also have two of these chips, and they both sound the same. I am currently using the circuit board from a CD-ROM drive that had the chip already installed. I modified the circuit to match the application circuit, but with a 20K ohm potentiometer on the input and a ferrite bead on the output (it was already on the board). The high frequencies are extremely loud and distorted, but the rest of the audio range sounds normal. I think I need to add a low-pass filter. It sounds okay with a 0.22uF cap from the input to ground or a 47uF cap from the output to ground, but those aren't ideal filters.
I would like to make the APA3541 usable (if it is possible) and use the non-inverting input of the TDA1308.
ing.
The capacitance is now 247uF, and there is some weird low-frequency noise on the output that I couldn't hear before. The new feedback resistors aren't soldered on very well because I didn't want to remove the motherboard. The second MS6308 (if I can remove it from the board) will be a standalone headphone amp for some future project.
