Technics SA-301 Right Channel problems
  • flinx
    • Aug 2010
    • 132
    I picked up the above unit from a thrift store for $20, cosmetically it is in good condition. Connected it to a set of 40w Panasonic speakers. It powered up and worked fine for a bit and sounded great. Then the right channel started to get scratchy and dropped out. After some trouble shooting I found part of the problem was a bad connection on the speaker end. I fixed that but the problem persisted. I verified it was not the speakers anymore by attaching the left channel speakers to the right channel as well as another set of speakers.
    I opened the unit up and first thing I did was pop out the 2 large caps and test them, they are supposed to be 6800uf at 45v, but both of them measured around 5400uf and 5300uf. I swapped them with each other and then checked the circuit board for bad/cold solder joints. I did not see any obvious cracked solder joints, but ALL the soldering was grey not silver. I traced out the right channel and reheated/added solder/resoldered anything that did not look perfect.
    There were some key components that had a large amount of flux built up around them and re-soldered those. I tested the unit and it seemed to be fine. I listened to it for a while then buttoned it up. Listened some more and mentioned to my wife that I may have fixed it and yes not 10 seconds later the right channel dropped out.
    I turned the unit off and back on immediately and the right channel was back. I do notice that when the volume is turned up that the right channel power meter shows slightly less then the left.
    I read on another forum on another site that the DC offset voltage should be less then 15mv for each channel. The left channel on mine measured about 13mv and the right measured around 17mv. Currently Both channels are working but if I increase the volume 1/3 to 1/2 way up sometimes the right channel drops out again. bouncing the power switch brings it back.
    One other thing, this unit has marking that say it should be used with 16ohm speakers. mine are 8ohm.
    Any Ideas?
    "...off the record, unnamed government sources
    alluded to unsubstantiated innuendos about
    alleged indiscretions and insinuated that they
    are rumored not to be without basis for further
    speculation..."
    Re: Technics SA-301 Right Channel problems
    Those two caps are for the filters for the Bi-polar power supply to supply the +/- for both power amps so that cannot be the cause of one channel drop out, this receiver uses direct-couple output circuits. 17mV offset is not a problem at all, the speaker protection relay will disconnect the speaker when it detects more than 2VDC at the speaker terminals.
    Did you do any cleaning of the switches yet, especially the TAPE Monitor and the Muting switches? Just toggle the switches a bunch of times may clean out the oxide built up on the switch contacts. You should also look real close at the solder joints, especially on any transistors that are mounted on the heatsink, look for small ring around the solder joints, it will look like small cracks, use high magnifying glass.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      The switches can be a major pain in the ass on old equipment. Before you get into the electronics, toggle the switches like budm said, it may be just that. Some contact cleaner spray would be helpful, too.
      A working TV? How boring!
        You are using 8 ohm speakers with a 16 ohm amp? Maybe it's just current limiting.
        • abrsvc
          • Aug 2012
          If the channel is stopping with a volume increase, it is no likely to be the typical relay problem. A power sequence "fixing" the problem suggests that the spike is temporarily cleaning a connection or something like this. I would initially look for poor solder connections. Once that is completed, use freeze spray to see if a temp change can either cause or fix the probem.
          Post your progress here.
          Thanks,
          Dan
          • 999999999
            • Sep 2006
            • 774
            Since it starts out working then drops out presumably from heating, I vote for cracked solder joints on the output transistors like budm mentioned and would reflow those even if they look ok... using extra flux since these described gray-not-silver joints may be harder to solder well, likely some oxide buildup is present on the transistor leads.
            If that alone isn't enough or doesn't help, I'd investigate replacing those after tracing the audio signal with a multimeter to see if it is still present right before those transistors and if it isn't, you just keep following the circuit backwards till you find the fault, or if it is present then replace the transistors.
            • eccerr0r
              old X58 triple channel board... memtest86 memory speed?
              by eccerr0r
              Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
              Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
              Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
              06-28-2025, 09:06 AM
            • spleenharvester
              Reverse engineering of 18650 4-channel tester
              by spleenharvester
              Hi friends
              I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
              05-04-2025, 02:43 AM
            • CDNBrewer
              Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
              by CDNBrewer
              Hello Everyone,
              I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
              Symptoms:
              • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
              • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
              • I swapped the Left and Right surround
              Yesterday, 09:29 PM
            • Hondaman
              Single-channel antenna?
              by Hondaman
              Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
              I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
              Years ago I made a "T"...
              11-18-2024, 01:14 AM
            • dicky96
              American Audio VLP1500 Distorting on one channel
              by dicky96
              Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
              Protection and Clip LED are off
              There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
              I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
              The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
              07-13-2022, 05:25 AM
