Philips FCD565 midi system ~1987 - Transformer buzz
  • quattro alex
    • Mar 2012
    • 92
    Model: Philips FCD565 midi system (1987 ish)
    Faults: Transformer buzzing occurs with no load after 10 minutes or so. Also tuner display does not light up
    Observations:
    1. Diode wires 6527 & 6528 are broken these have a 4 8 T designation
    2. One of the bulbs for the crystal display appears burnt out
    Testing so far:
    1a. All caps on the top circuit board tested with esr meter - 7 found to be out of tolerance:
    Position on board
    2594 - 25v 100uf (74.10uf & 0.46 esr)
    2698 - 10v 100uf (30.98uf & 1.29 esr)
    2521 - 10v 220uf (141uf & 0.49 esr)
    2522 - 10v 100uf (33.86uf & 1.11 esr)
    2655 - 63v 10uf (6.62uf & 3.0 esr)
    2523 - 63v 2.2uf (open / low cap)
    2525 - 10v 47uf ('leaky' & 11.6 esr)
    2a. - Diodes - these tested fine
    3a. - Resistors - values matched almost perfectly - except 2 which I will ask about in a moment.
    Questions:
    A) Are the orange components film capacitors or resistors? ( some have 0.27k and one has 0.1k on the top)
    B) The resistor at 2534 measures at 100k but the one underneath shows no continuity and shows as open when testing resistance - is this because of the component in between the two of them?
    C) I make the resistor at location 2600 a 100ohm resistor (brown/black/brown/silver) but it is testing at 2ohms - have I interpreted the original value correctly?
    D) Is the original soldering of the transistors acceptable, or should I redo these? (marked in red)
    Any other suggestions or observations greatly welcomed!
    Fixed so far: GNR TS902W monitor, Sony Game Gear, Philips FCD565, Arcam Alpha 10, Memorex SA 404amp
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Philips FCD565 midi system ~1987 - Transformer buzz
    They look like capacitors.
    If you get suspicious readings, remove them and retest out of circuit.
    In circuit readings are not 100% reliable as they could be affected by other components.
    --- begin sig file ---
    --- end sig file ---
    • 999999999
      • Sep 2006
      • 774
      Yes the orange components are film caps, 0.1uF and 0.27uF
      I'm not so sure those 2534 and the one below it (2612?) are resistors. They look more like fuses or inductors to me, or even capacitors more than resistors.
      • quattro alex
        • Mar 2012
        • 92
        Do film caps degrade in the same way as normal caps do, or do they have a longer / more stable lifespan? Also if I use my peak esr70 meter will the esr reading be worthwhile or are these film caps too small in capacitance terms?
        As per retiredcaps - I will test the others out of circuit.
        • 999999999
          • Sep 2006
          • 774
          Film caps do not degrade like electrolytic caps, they're generally good for decades except those on AC mains circuits which are subject to voltage spikes. There's very little chance those caps are the problem unless you see some physical evidence looking at them. I doubt any of the capacitors are the source of the problem since the 10 minute period makes a difference, though certainly it'd be good to replace any electrolytics that are out of spec or for longer future use - but I'd wait till the primary problem is found and fixed.
          If I had to make a random guess, you have a transistor that's getting leaky when it warms up. I'd measure voltages on their pins before and after it starts buzzing. You could try reflowing the solder points you circled but they look no worse to me than others in the picture. If you're going to be ordering parts you might consider ordering some equivalent transistors too since they're probably only a few cents each.
          • quattro alex
            • Mar 2012
            • 92
            With regard to measuring voltages is this a live test (dc volts?) and which pins should I test?
            The original transistors have the following identification:
            F199
            F245B
            BB112
            I've checked farnell, rs and mouser and it appears these are no longer available or well over 2-3 months wait. Can these be substituted with another version?
            • selldoor
              Slow Learner
              • 7870
              Hi - Yes Voltage measurements have to be done live - otherwise there would be no voltage? or very little once the caps had discharged
              If you have a data sheet for the Transistors you will be able to see what
              voltages are expected and set up the meter accordingly. If Auto ranging then you are ok.
              If you havent got the data sheet to be safe start at 600dc and work down.
              • vinceroger69
                • Mar 2012
                • 6714
                answer to c yes 100 ohms maybe unsolder one leg and retest and double check on the colour bands
                • Longbow
                  • Jun 2011
                  • 623
                  Good photos. Are you referring to 60 cycle mechanical buzzing in the transformer? Mechanical buzzing happens because the core plates are physically vibrating in step with the magnetic field. There is little you can do short of finding another transformer. Sometimes mounting the transformer on rubber feet, etc will cut the noise down a bit.
                  Is it plugged in?
                  • selldoor
                    Slow Learner
                    • 7870
                    If it was that would injecting it with superglue help?
                    • 999999999
                      • Sep 2006
                      • 774
                      IMO, that's not a very common fault but you could desolder the transformer, submerge in hot lacquer, cure and resolder it.
                      • 999999999
                        • Sep 2006
                        • 774
                        F199
                        F245B
                        BB112
                        Yes live, DC volts, they'll probably be under 36VDC and likely much less. Measure all pins and record the values measured then compare to values after the noise starts.
                        Yes there's bound to be substitute transistors, after the originals are identified and spec sheets found, or something the critical parameter can depend on the circuit around it and you have to trace that circuit to see how it's used.
                        F245B appears to be BF45B n-channel FET, 30V, 15mA to 25mA max drain current, 10 mA gate current. I didn't find the other two and am not really following the circuit.
                        Upon searching for Philips FCD565, I get hits for a bookshelf stereo system. Is it a bookshelf stereo system or is it an electronic music synthesizer? I take back my guess about transistors - it could be a leaky transistor but I did not realize this is a junky integrated stereo system not a MIDI synthesizer, you're only showing a little bit of the entire integrated stereo system including an NJM4558 opamp, TA2030 power amp IC, and other parts we don't see.
                        You'll need to probe around other places too and measure signal levels before and after the opamp, power amp IC, and elsewhere as well as considering other components we can't see pictured. Personally, I'd just throw this unit away as you might be able to find a working one at a garage sale for a very low price and once you heard it, wouldn't want to use it for anything.
                        • quattro alex
                          • Mar 2012
                          • 92
                          It is a mechanical buzzing that starts as soon as I turn on the unit. It gets progressively louder over about 25 mins and then stays at that level.
                          Questions:
                          1. I have desoldered the transformer, now should I remove the outer strip of metal and copper section to reveal the core?
                          2. If I do need to apply lacquer does it have to be of a certain spec?
                          3. If I am looking for replacement transformers what are the key specs to check?
                            Do you get hum if you just have the primary side hook up to power only?
                            • quattro alex
                              • Mar 2012
                              • 92
                              Budm would you mind pointing out which connections I should disconnect to carry out this test?
                                I need good picture of the bottom side of the the board as shown on post #13 picture #3, and the other side of the transformer of th pic #1 in post 13 (the picture #1 seems to be showing the secondary winding of the transformer).
                                • 999999999
                                  • Sep 2006
                                  • 774
                                  Questions:
                                  If there is a sufficient gap somewhere so you can use a spray varnish with sprayer nozzle that has a straw, you may not need to remove anything. Otherwise, you may... dipping the entire thing upside down is the typical approach but that may or may not be enough.
                                  Electrical lacquer or varnish can be found at electronics supply house, here are a few from a UK supplier as an example:
                                  http://uk.farnell.com/jsp/search/bro...atchallpartial
                                  Since this transformer has a plastic frame on it, you should probably avoid any varnishes that need to be baked rather than air dried.
                                  The hardest part in finding a replacement would be that it's the same form factor given it is mounted on the PCB. Otherwise you could remotely mount the transformer and connect it with wire to the PCB. Key specs are the same voltage and the same or higher current rating, or at least close (depends on how loud you want this to be capable of).
                                  Measure the voltage to determine if you are dealing with +/- rails of the same value and ground (for example +18V/0V/-18V) or dealing with a single higher voltage rail like +18V and a second lower voltage rail that powers various lower voltage components on the board(s) rather than the audio output stage. Based on its physical size I doubt it is rated for more than a couple amps current on the highest voltage rail(s), if even that.
                                  To hook up the primary side alone to see if it buzzes then, it appears all you need to do is connect an AC electrical cord to the primary winding pins, the two on the side of the transformer closer to the AC outlet. By that I mean a leftover/salvaged power cord from something that you cut the product end of the plug off of and striped back insulation and modestly soldered to the transformer pins, if you don't have a more secure way of using aligator clip ended jumper wires or similar. Either way be careful working with HV AC, and confirm which pins are the AC primaries by looking at the back of the PCB to confirm those solder pads trace to the AC power socket.
                                  • quattro alex
                                    • Mar 2012
                                    • 92
                                    Hopefully these are ok, unfortunately too late for daylight shots so I've bumped the ISO up a bit.
                                      This transformer has mutiple windings on the primary side, There is a black recetacle and then there is also a balck cord (with Blue and Brown wires) iwth female IEC at the end of it. Can you tell me where that black power cord goes to and the black receptacle is for?
                                      • quattro alex
                                        • Mar 2012
                                        • 92
                                        There is a black recetacle and then there is also a balck cord (with Blue and Brown wires) with female IEC at the end of it. Can you tell me where that black power cord goes to and the black receptacle is for?
                                        The black recepticle is the mains AC input for the unit. The black cord I think is for the CD player section or turntable which my colleague hasn't given me.
                                        • zombie.guitarist
                                          Reading Serial Midi data with an oscilloscope
                                          by zombie.guitarist
                                          Hey all, I have one last thing I'm looking to fix with my Synthaxe. This time, the schematics I have are actually the same as the PCBs I have.
                                          The Synthaxe, works as its a guitar midi controller hooked up to a floor pedal. Thats the most basic way of using it, and it has a midi output. You also can connect a console to it, that stores your tunings and other things. The console has 8 midi outs, as well as a midi in and midi thru.
                                          When I first got the unit, I thought I was using it wrong, but it turns out its just broken. The 8 midi ports on the console don't output...
                                          07-05-2023, 09:29 AM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
                                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 04:40 PM
