Desk fan interferes with amplifier's right channel
  • markiemrboo
    • Mar 2006
    • 44
    Here's an odd one.
    My friend bought the same amp as me, Cambridge Audio A5, to replace his Logitech computer speakers. He's really impressed with it.... BUT:
    He has a desk fan pretty much on the other side of his room to his amp. When he turns the fan on, the right channel on the amp gets this horrible low frequency buzzing noise, clearly audible over music. This only happens when he turns the fan on, it doesn't disappear when he turns the fan off. It doesn't disappear if the amp is turned off. It will only disappear if you nudge the balance knob on the amp back and forth a tiny little bit, multiple times. Then it's fine again until the fan gets turned back on!
    It's really quite amazingly strange. Any idea's what might be causing this?
    EDIT: Forgot to add, turning the volume all the way down so no music can be heard... this strange humming is still there.
  • arneson
    • Sep 2005
    • 1267
    Re: Desk fan interferes with amplifier's right channel
    Look around the room for lights on the same circuit as the fan.
    Pay attention to flourecent, high intensity, and mood lights.
    Turn on amp, turn on fan, start turning off lights.
    This is just one of many possible things.
    Jim
    • markiemrboo
      • Mar 2006
      • 44
      He says there's no lights plugged in to the same socket as the fan. Try turning off..... anything, one at a time?
      • japlytic
        • Oct 2005
        • 2086
        The most likely fix for this problem is to install a heavy duty line filter on the fan, and then on the amplifier if the filter on the fan alone does not fix this problem.
        • arneson
          • Sep 2005
          • 1267
          I've seen corrosion in outlets do this kind of thing.
          Also a fire risk from aluminum wire in house?
          Jim
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • spleenharvester
            Reverse engineering of 18650 4-channel tester
            by spleenharvester
            Hi friends
            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
            05-04-2025, 02:43 AM
          • dicky96
            American Audio VLP1500 Distorting on one channel
            by dicky96
            Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
            Protection and Clip LED are off
            There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
            I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
            The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
            07-13-2022, 05:25 AM
          • dicky96
            Hitachi V19B01922 Channel Tune problem
            by dicky96
            Hi Guys
            I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
            He also has an LG TV, so three screens in the bar
            I installed three Satlink ST-6503 DVB-T Modulators
            This model https://www.aliexpress.com/item/32916553905.html
            These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
            02-09-2023, 09:20 AM
          • sima112
            Marantz pm 6005 right channel not worknig
            by sima112
            Hi guys,
            I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
            01-30-2023, 12:11 PM
