JVC RX-6042 5 secs then shuts off
  • S2udio
    • Feb 2012
    • 16
    Re: JVC RX-6042 5 secs then shuts off
    The schematic is here.
    http://www.eserviceinfo.com/download.php?fileid=34224
    Ovewrite PT 0 with PT 1 ...its an update
    AT least 3-5 ? logic switches to get this beast powered up ?
    Disconnect the psu and simulate the power up sequence ....check and monitor the PSU first
    With a 60w bulb for load on the Power tx output.
    Or use a variac
    Depends on OPs experience with the iron ?
    Then move on.
    Most of the time things ain't what they seem to be
    • scampo77
      • Dec 2010
      • 233
      #42
      I can't find these parts anywhere can someone possibly help me with replacement parts that are easier to find?
      • 999999999
        • Sep 2006
        • 774
        2SD637 is available on ebay with worldwide shipping from some sellers.
        The QAD0012-202 can be replaced with another 2kOhm thermistor of the same form factor and current capacity (physical size). There might be a few options on http://www.digikey.ca searching for thermistor then using the filters to narrow the search.
        • duane_steel
          • Apr 2012
          I apologize if this is a Hijack, I certainly don't intend it to be! I happen to be working on the exact same receiver and came across all this great information and it's been a great help to me.
          I hope its ok to ask a couple questions (not related to the OP's questions) but on the same gear since you've all become familiar with it!
          1. The receiver I'm working on has burn marks and other obvious signs of overheating around the main voltage regulator transistors for the +12v and +5v (Q1435, Q1405, Q1434, Q1404, Q1401, etc)
          Is it reasonable to just replace these parts or is it likely that there's a problem somewhere else that led to so much overheating on these parts?
          2. I'm new to amplifier design and wondered if anyone could explain the purpose of the pri_+B, pri_-B, inputs to each of the 5 amps. I assume B+/B- are the positive negative input but what are those separate inputs?
          Thanks! and again sorry if this should be in a new post.
          • scampo77
            • Dec 2010
            • 233
            #45
            im not sure if anyone is still following this but i finally figured out where all the parts came from, thermostor that weird transistor etc.. i put amp #4 all back together and the thing hand gernaded again. SIGH!!!!
            the transistor was like 12$
            i am really ready to throw this thing in the garbage.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Give it one last shot. Check all the resistors, transistors, and diodes.
              Muh-soggy-knee
              • scampo77
                • Dec 2010
                • 233
                #47
                it is another shorted darlington pair. i hate to do it but this will be the 3rd pair i will be replacing. i even tried the lightbulb thing and it cooked anyway. i cant throw any more money into this thing.
                it is still has an option for "casstte tape" so i guess its lived long enough. ill go spend the 99$ to replace it.
                thanks to everyone that helped me in this thread
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Hmm, did you touch the trimpot at all?! That sets the bias, if you set it wrong then it can blow the output transistors.
                  Muh-soggy-knee
                  • abrsvc
                    • Aug 2012
                    Try turnong the unit on without the output transistors installed at all. Measure each pad to ground and post those voltages here. If the outputs have blown right away, you are probably missing a voltage or have a shorted driver transistor. The voltages present without the outputs installed should provide a clue. If that appears OK, then install the outputs without the center pin connected. This should present the correct voltages WITHOUT any current draw and thus won't blow the outputs.
                    Post your progress here.
                    Dan
                    • scampo77
                      • Dec 2010
                      • 233
                      #50
                      my last post was just to thank everyone for their help. in order for me to try another stab at this thing i need to spend another $40-50 in parts and wait another few weeks for everything to arrive. i dont want to throw good money after bad (if i havent already). this thing is super old and although i hate to see it go and i love the challenge, i just cant in all good sense put anymore time or effort into it.
                      thanks again for the response and thanks to everyone here, i CAN take from this project a lot of knowlede and even that new nifty light bulb trick. so its not a loss at all
                      thank you again to everyone.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5085
                        • New Zealand
                        #51
                        You might be able to regain some money if you sell it to someone who is willing to keep trying
                        -David VanHorn
                        • Shobos
                          Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
                          by Shobos
                          Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
                          So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
                          NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
                          Any help is welcome. Thanks !
                          07-29-2025, 03:53 PM
                        • limxrich
                          ASUS X560UD - shuts off after 3-5 secs whenever RAM is present
                          by limxrich
                          Working on an X560UD. Unit turns off whenever RAM is present. Tried multiple known good memory sticks, but still, unit shuts off after 3-5 secs. When RAM is removed, unit stays on, but of course, do not POST.
                          Happens on any o the two slots, 1.2V present.
                          Any clues?
                          08-10-2022, 07:17 PM
                        • chopduel
                          Bad mains power causing TV malfunctions?
                          by chopduel
                          I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
                          Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
                          • TV would randomly turn off then back on.
                          • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
                          • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
                          12-29-2024, 03:20 AM
                        • huzo
                          HP Omen shuts down when loading OS
                          by huzo
                          The model is 15ec-1061nm
                          Board number is DAG3EDMB8D0​
                          SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                          10-29-2024, 12:05 AM
                        • Giggle2562
                          Lenovo V15-IIL motherboard swap (in V15-IKB) shuts down when internal display is connected
                          by Giggle2562
                          I have a Lenovo V15-IKB that had a damaged motherboard. I replaced it with a motherboard from a Lenovo V15-IIL.
                          The board powers on, but it shuts down after about 10-15 seconds. This only happens when the internal display (LCD panel) is connected.
                          Here's what I've tried so far:
                          • When the internal display is disconnected, the laptop works perfectly fine via HDMI.
                          • The laptop shows an image on the internal display for a few seconds before it shuts down.
                          • I tried swapping the LCD panel with a known good one.
                          • I tried swapping the LCD cable
                          11-06-2025, 12:36 PM
