I can be an idiot sometimes
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    I've been looking for the longest time for some nice rack mountable cases for my amplifier projects, but haven't found anything really cheap, most of them are $30+ which isn't worth it when most of the amp is made from scrap parts.
    Now, i desperately need a case to house some amp guts for next weekend, but more on that later. I have one that would fit, but it has no rear vent holes (and i'm going to need some), and it's lacking the bottom panel.
    ....... while all this time i've had several minitower cases (PIII era) lying around, and they come with lots of vents (just take out all the slot covers), are easy to drill for pots and stuff, have screw holes and standoffs all over the place AND they've got space to mount a power supply too. I feel like a complete moron. Sure, they're not rack mountable, but they definitely are a lot easier to work with than the random old amp cases i got.
    A working TV? How boring!
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: I can be an idiot sometimes
    An amplifier in a computer case?
    The idea sounds funny, but I like it. Post some pics when you're done.
    By the way, I am an idiot every day, so don't worry (or do?). I can't really help it so I just roll with it.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      how about small server cases?
      in a few short years severs depreciate to near scrap value.cheap rack cases!
      • ipman
        • Jul 2011
        • 159
        Not here unfortunatelly.
        • Jack Crow
          It's a CLASOB!
          • May 2008
          • 823
          U,
          Look at old 'rack mounted' lab power systems.
          Old and failed Lambdas or HP's, have covers, vent holes, and all that stuff.
          Might have to cut a new front panel, but that's no big deal.
          Most guys never thing to re use dead and dying test gear for another activity.
          Best of all it's cheap. Not many guys can fix this stuff, so it goes for the price of scrap aluminum.
          Enjoy
          Jack Crow in Virginia
          "You are, what you do, when it counts"
          The Masso
          "Gravity, the quickest way down"
          Mayor John Almafi
          "You ever drop an egg, and on the floor you see it break?
          You go and get a mop so you can clean up your mistake.
          But did you ever stop to ponder why we know it's true?
          If you drop a broken egg you will not get an egg that's new?"
          MC Hawking
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Originally posted by Jack Crow
            U,
            But...
            • ipman
              • Jul 2011
              • 159
              Jack, me and Th3_uN1Qu3 are living in a east-european ex-comunist country.
              In the former comunism times Lamba and HP were ... let's say "enemy".
              Afther the fall of comunism, everything made here was tought to be bad and scrapped right away in the early 90's. Afther that they found out that they don't have enough money to buy modern ones.
              And ... sad end of story.
              • Jack Crow
                It's a CLASOB!
                • May 2008
                • 823
                Guys,
                I was on the other side of the iron bar and lacked those kinds of issues.
                Stuff like what I was talking can be had for cheap as surplus.
                Thinks are not all sweetness and light here in the west. Been mostly un employed since April 2010. Running out of money and have a host of related issues.
                If I think of something will let you know. Need to think of something for me too.
                Be well there.
                Jack Crow
                The Masso
                Mayor John Almafi
                MC Hawking
                • ipman
                  • Jul 2011
                  • 159
                  Did you mean "iron curtain"?
                  Nowhere is heaven, of course. Europe is more expensive than US, especially eastern part, but we have lower wages here.
                  The real problem is that we have no surplus, nothing ...
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Erm, more accurately, all surplus is quietly taken away by the "whiz kids".
                    Anyway, i should be finishing the thing by the end of this week. The 600W power supply is 100% completed, wired and assembled including full range thermal fan controller. From "off" to "overdrive". It feeds the original fan of the supply which was a 12v, 120mm and roughly 2400rpm (judging by the noise) unit, and runs it from 3 to 15 volts depending on the temperature. By previous experience i know it's unlikely that it gets past 10v tho... this is a supply of significantly higher voltage and lower current compared to regular PC units, so efficiency is greater, so less heat has to be evacuated.
                      Rack mounted ECB-A10H plus several buck converters set to different voltages with a 12 and 24 volt switching power supply
                      by sam_sam_sam
                      Last night when I was doing a Google search on the internet I was searching for empty rack mounted enclosures and I found this website where I found some 5u enclosures for a reasonable price these enclosures are being discontinued so for this reason until I place an order I not going to post the website link because I need to make sure that we are working Saturday if we are going to work Saturday then I will place the order tonight and I will post the website for them
                      I want to reuse my rack mount cart that I have not been using sense I have do my projects in my new shed but I going...
                      09-13-2024, 06:47 AM
                      Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                      The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                      Securing a good thermal interface between...
                      10-07-2024, 04:35 AM
                    • FallenOne008
                      Asus G712L No Screen Backlight
                      by FallenOne008
                      Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                      The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                      03-31-2025, 08:27 PM
                    • Spork Schivago
                      Identification of two round holes on top of rack.
                      by Spork Schivago
                      Hello!
                      I've searched the internet, skimmed through a lot of HPE PDFs, all searching for the answer to a simple question. On the top of my HPE H6J77A Advanced Series rack (36U), there are two round holes on the front top of the rack. What are those holes for?
                      Here is a picture of the holes that I'm talking about. I know what the square on the back is for.
                      I originally thought fans, but no, the fan kit is for the middle of the top of the rack. Then I thought maybe duct work for cooling, but that doesn't make sense with both being on the top there. I looked...
                      10-27-2018, 04:50 PM
                    • Felipe_Serra_83
                      US Audio Mix-8 Line Mixer - Tº while idle
                      by Felipe_Serra_83
                      Hello all.
                      I have a US Audio Mix-8 Line Mixer, rack mountable. I changed the fuse and powered on with a current limiter (lightbulb thingy).
                      I noticed that the voltage regulators (could be 7818-7918 - not sure because the heatsinks covers them) get hot, even though I'm not connecting lines in nor speakers. They get up to 52ºC in a couple of minutes after powering on.
                      My question: is this normal? My gut tells me it isn't, and I'm thinking about some faulty component pulling too much current. But I have investigated and can't find nothing.
                      Thanks...
                      09-06-2024, 11:32 AM
