SONY car audio
  • Hondaman
    • Sep 2008
    • 1089
    SONY car audio
    The Sony (low-end AM/FM/CD) I put into my dashboard is having problems (about 4 years old).
    A few months ago, the display went dark for 20 minutes or so (on a long interstate night-time drive). When it came back on, the clock, radio station presets, etc. were all preserved.
    When it happened a couple more times, I hit the latching button so the front face would flip downward (as if I wanted to insert/eject a CD). When I flipped the face back upward, the unit worked fine again.
    Last night it went dark and is staying dark. I assume car wiring is good. Does anybody know how car stereos usually fail? If I want to open it up, apply power and check voltages, is there anything I should watch out for?
    (Right now I think I'll go back to the factory radio.) Thanks in advance!
  • delaware74b
    • Apr 2009
    • 628
    Re: SONY car audio
    Is the clock display on a flip-down panel? If so, the contacts between the face plate and head unit need to be cleaned. My older Pioneer P3600 does this about twice a year. Quick wipe down with alcohol on cotton swab fixes the problem.
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: SONY car audio
      on non detachables the ribbon cable goes bad.
      seen most often in those goofy kenwoods with all the crazy screensavers.otherwise yes the contacts get fouled.
      • UserXP
        Vintage SONY Digital Clock Radio ICF-C12W no audio
        by UserXP
        Dear all,
        I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
        i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
        My question is, do you know of this brand of capacitors and how bad are...
        07-21-2025, 08:35 AM
      • samson7point1@yahoo.com
        Help troubleshooting an audio problem with an RCA SGT-250 CED Player
        by samson7point1@yahoo.com
        The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
        The player processes the audio signal using two different reference frequencies. The "R"...
        04-30-2024, 11:22 AM
      • mikey5791
        Sony CFS-5000S radio cassette player no FM reception
        by mikey5791
        Hi forum members,
        In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
        Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
        I opened the casing inside and checked for any dry solder, burned component or loose wires...
        02-24-2023, 03:48 AM
      • shelby5041
        clock radio / radio lifespan?
        by shelby5041
        hi
        ive got a modern digital clock radio approx 15yrs old
        my question is how long can a clock radio or a simple radio last ss farcas operating hours?
        since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
        the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
        it uses very little power just a few watts i would imagine that may have something...
        09-14-2024, 03:30 AM
      • praveenramavath
        Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
        by praveenramavath
        Hello All,
        I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
        https://www.hifivision.com/threads/m...-screen.98243/
        Troubleshooting Summary: Majority Internet Radio - Flash Chip
        04-26-2025, 09:08 AM
