Bosch WTA100 Dryer repair
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hi guys ,
    I "bought" this nice looking Bosch dryer for a 6 pack beer.
    It has the problem that it is not heating anymore. ( Fan is working ).
    I measured the thermostats inside and they are all ok. It has 1 thermo with the fuse that can pop out but its still fine.
    So i got down to the heating element and it has no continuity/endless ohm so i know its bad.
    I got a question , can i make this element work again temporarily? I got continuity on the outer part of the element but not on the pins itself. If i look closely on the pins i notice that there are 2 small pins inside the element. So i guess something on the inside is broken.
    What happens if i solder the pins to the outer part of the element?
    Anyone have experience with this type of dryer?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Bosch WTA100 Dryer repair
    This is the element up close.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Solder might melt with the hi-temp. Probably get someone to MIG/TIG weld it back and that could probably work temporarily.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Will the element get so hot that it melts the solder? I think the best thing is to get a new heating element.
        • CapLeaker
          Leaking Member
          • 8193
          not even silver solder is going to last in this application.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Ok , thanks for the help! I will get a new element and that will fix the problem. Only $40.
            Little maintenance on the rest of the parts and it will last a few more years!
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              you can buy elements in straight lengths and bend to shape .just get correct rating .
                • 31063
                remove the brass core from a terminal-block and clamp it down on the element
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Sorry STJ i don't understand what you are trying to say.
                  I got the new heating element and cleaned the inside of the dryer. Used a tiny bit of WD40 in the motor area ( for the fan ).
                  Its working perfectly right now!
                  • CapLeaker
                    Leaking Member
                    • 8193
                    Don't forget to clean and put a little lube on the 2 rollers the drum rides on.
                      • Jul 2011
                      • 6040
                      Also make sure that the duct hose that goes to outside of the house is clean otherwise you have this problem again
                      WD40 should not be use to oil the motor you should use motor trubine oil which made for that
                      One note you can fix heating wire with high temperature terminal crimps (crimp the hole terminal end not just in one spot) just cut off the end that you do not need and solder each end of the terminal end
                      I have done this before with about 85% success rate
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        Thanks for the tips! I cleaned the duct hose so that will be ok.
                        I used only a little WD40 , not like normal use. I will buy the oil.
                        • NeedsMoreFlux
                          • Oct 2017
                          • 121
                          • California
                          Before you replace the element: check that you are actually getting 220volts to it! (BE CAREFUL!!! AND HAVE SOMEONE NEARBY WATCHING READY TO UNPLUG IT, IF YOU GET ZAPPED!!!)
                          I had a dryer with a bad thermo switch. voltage would flow through the element and terminate on both ends of the thermo switch, so it seemed that everything was good there. It wasn't until I unplugged the pigtail off the last of 3 thermo switches and tested either ohms on it, or tested if voltage was coming out of it that the problem was revealed!
                          And some times elements do have super high resistance. I tested a brand new heating element for a water heater, in the highest ohms setting, on my harbor freight meter. It showed open line!
                          Good luck!
                          Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
                          I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
                          Some of the things I've fixed:
                          60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
                          • NeedsMoreFlux
                            • Oct 2017
                            • 121
                            • California
                            Oh, never-mind. I skipped ahead. Forget my last post. lol.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              Haha thanks for the tip! Much appreciated , i tested the element in continuity mode and no beep so i knew enough!
                              • CapLeaker
                                Bosch Nexxt 500 dryer blinking start button - no start fix
                                by CapLeaker
                                My Bosch NEXXT 500 dryer quit today, press start nothing happens and the start button just keeps blinking. Not cool. Reset the dryer, same thing.
                                Even so the buttons feel good, my problem was the start button smd tactile switch on the PCB. Cleaned the switch with alcohol followed with Deoxit and the sucker runs like a champ again.
                                I like these easy evening fixes!
                                12-07-2023, 04:38 PM
                              • mariukonie
                                Bosch WDU28560GB/02 washer-dryer - time jumps, blocked door, codes E60 and -09
                                by mariukonie
                                Bosch WDU28560GB/02 washer-dryer. After selecting the spin program, the clock jumps from 0:13 immediately to 0:05 and counts down the minutes to zero. The pump turns on and the door locks, but nothing else happens, the drum doesn't spin. After the countdown ends, it does not open the door, it can only be opened by pulling the emergency handle next to the filter. No error is shown. When I select spinning and hold my finger in the lower left corner of the screen, after 5 seconds E60 and -09 are shown alternately. What could be the problem? Is it possible to turn on the service mode so that the washer-dryer...
                                12-04-2023, 04:01 PM
                              • flysky
                                Gigabyte H610M S2H V2 help to identify the element.
                                by flysky
                                There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
                                Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
                                01-23-2025, 07:21 PM
                              • corrize
                                Where to find a very small fpc connector 0.3mm between 2 pins ?
                                by corrize
                                Hello, I search this connector (oxydated).
                                It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                Do you know how to find this connector please ? What is the exact name for find it ?
                                08-06-2024, 05:25 PM
                              • Petr0x
                                Bosch 12V and 18V chargers modification
                                by Petr0x
                                Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                05-24-2024, 01:00 PM
