Samsung washing machine no power to discharge pump
  • Wackyracer
    • Mar 2015
    • 23
    Model WF328AAW/Xaa. Original problem is the machine will not discharge the water. No power to the pump, I can run the pump off 120v, The circuit board is encased in what looks like silicone. The look to be some scorching on the board in a couple spots.
    I have ordered what is supposed to be the replacement main controller board as per the parts people at several . I had to source it via ebay as my orders with reputable online suppliers were cancelled do to the part being NLA.
    Both replacement boards were listed as NEW, both boxes were beat to death in the mail. Both boards throw a error code E3 which indicates a motor issue (motor hums and moves a tiny amount before erroring out) but both boards run the discharge pump. With the original board there is no motor issue or E3 error. I suspect these 2 boards part # DC92-00240A are not correct for this machine even though every parts website I contacted claims they are and several also claimed it was in stock but cancelled my order for NLA.
    So, I want to try and fix the original board that won't run the discharge pump. I have a donor board from one of the suppliers who told me to keep it.
    I will attach the service manual with board schematic and a picture of the back of the original board (asap) and the replacement/donor board.
    Right now my biggest obstacle is the "silicone"...how do we remove it without destroying any parts including the plastic housing?
  • Wackyracer
    • Mar 2015
    • 23
    Re: Samsung washing machine no power to discharge pump
    Service manual and donor board pic are attached
      • Jul 2011
      • 6040
      Please take a very good photo of that area so see where that is
      What part is under the heat sink
      Can you trace where the pump wire go to get power to run also dose this pump motor have a run cap
        • Jul 2011
        • 6040
        So what this mean is that the relay that operates the coil for the pump down is NOT getting power
        How good are following the traces on a board
        ( in the manual that you posted there is a photo of the controller board and box that shows you where the relay is )
        Here what you need to find on that relay that controls the power to the pump down valve is the COIL contacts
        See if the relay has what voltage the coil is it probably 24 volts could higher or lower voltage
        Here where you need to be careful this board also has the power for the servo motor for the machine on this board and sensor that tell the controller if motor is moving or not
        Take two wire and solder it to the coil ----->>>
        ( or you can unsolder the relay and check
        [ you need an adjustable power supply to do this test you also need a volt meter to check conditions of relay <---> contacts this should be done with a load would be better ]
        the coil and contact on the relay to see if it works the way it should )
        <<--------- on the relay that powers the pump down valve you need to make sure that you have power to this relay when it in pump down portions of the cycle if you do not then your controller has issues
        Now if you have power to the coil of that relay the issues with the relay
        One note look very closely at the relay contacts that have the power to supply this valve and it powers something else for brown or black spots around the pads of the contacts on the board where there are no traces ---->
        If you have any contacts like that remove the solder and do not be surprised if the pad dose not come of with the solder too
        If this case then look on the relay there should be a part number on it google that part number or take a photo of it and I will see what I can find some thing about it for you
        Please be very careful doing what I post above I do not want to see you get hurt
        Or you fry the board more than it is now
        I work on machine controller that have servo motor many times before and repair the board as well and this is how I would trouble shoot this problem
        I hope this helps you with this problem that you are having with this machine
        • Wackyracer
          • Mar 2015
          • 23
          I have extracted the donor board from the plastic housing, however it is still encased in silicone.But at least I know how to get the other board out without damaging it.
          I can trace it out, I also have the schematic (it's in the service manual) and can solder use a DVOM have a scope, esr meter and more.
          The pump is small (fist sized) 120v pump with no capacitor on it. The pump runs fine with 120v connected to it. The voltage from the board at the pump fluctuates from approx 12v to 19v. The #5 relay that runs the pump says it is 12vdc/3a 250vac relay.
            • Jul 2011
            • 6040
            Can you take a photo of this pump
              • 31084
              the doner looks like it may have some bad solder joints that have cooked under the resin.
              • redwire
                • 3910
                The drain pump circuit is MCU driving one relay, from 15VDC/220R series reistor to make 12V for the relay.
                It might be worn relay contacts, I would replace the relay.
                With coated PCB's a heat gun can help peel it off. Not super hot to cook/melt plastics though.
                The donor board has black spots in many places, around IC9 D18 R18 so it might be lightning damaged?
                • Wackyracer
                  • Mar 2015
                  • 23
                  Just to give an Update....I had to bail on the repair for several reasons, further inspection of the machine found worn shocks, excessive play in the shaft bearings and something is broken off between the drum and the tub and floating/rubbing on occasion. The back of the original board showed more burned areas then the front. The cost in parts alone was more then the new machine. So, I bought a new machine and it wasn't a samsung.
                    Man, how old is this machine and how much was it when it was new? I talked to lots of repair guys and they all basically told me to stay away from Samsung and LG appliance or re-badged Samsung/LG.
                    • kaboom
                      "Oh, Grouchy!"
                      • Jan 2011
                      • 2507
                      Did it go "thh-bump, thh-bump" when ramping up on spin? If so, bad/broken "spider." They used cheep pot metal here to couple the shaft to the wash basket, which isn't up to semi-caustic conditions of detergent; it doesn't matter if you use "he" detergent or not. The alloy is unsuitable for contact with water over long periods of time as far as I'm concerned, let alone alkaline conditions.
                      Oh but they sure upsell that stainless steel tub & basket. The chain's only as strong as its weakest link...
                      And damn, those things are/were overpriced, especially if you include the "optional" pedestal/base.
                      Just a scam to make inroads to the US market, to be used as a wealth transfer device.
                      A complete insult, to think after such "agitation" people would blindly come back and stupidly buy another.
                      They're highly efficient, though, at taking your money...
                      /rant
                      The only remotely good LG front loaders were from the early-mid 2000's, and were Bosch-derived/inspired designs. "Tromm" series or something, they had small portholes in the door, which served their purpose while not being tacky. The junk at bLowes and Home Despot (the former having worse models) may as well be up on ivory towers with their huge, tacky, oversized windows, the damn doors probably weigh 25-30 pounds themselves!
                      Oh well, better to keep the machine in one place when that spider breaks!
                      "pokemon go... to hell!"
                      EOL it...
                      All style and no substance.
                      guilty,guilty,guilty,guilty!
                      guilty of being cheap-made!
                        • 31084
                        any opinions on bosch??
                        because in europe there arent too many "premium" brands - and you just covered most.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          There's Bosch/Siemens and Miele. Only most Miele machines look like they have their design stuck in the 70s. Bloody heavy too. Built like tanks though. Common fault is won't rinse. It's a fuse and a relay.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            Whats peoples thoughts on beko washing machines? ive just just brought one as was in the price range i could afford at the time.
                              • 31084
                              beko is actually very reliable,
                              i'm on the second - first one ran till the brushes wore out, and i could have put new ones in, but there was rust at the bottom of the frame and i wanted one with a display.
                              all the machines i'v had suffer from rust on the lower frame eventually.
                              just remember to check your pump filter every few months.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                Thanks stj and yes will keep a eye on the filter and yes my old hotpoint washer was suffering bad rust issues and the bearings failed but did last me a good 5 years i guess and was a old machine then as was second hand.
                                  • 31084
                                  i suspect most of these Italian / Turkish machines are from the same factory - just different names on them.
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    It might be a little out of date but
                                    http://hubys.co.uk/news-information/...ashing-machine
                                    • jondoe
                                      • Nov 2016
                                      • 547
                                      I'm into my 5th year on a Beko, all that it's needed in that time is a heater element, which was very easy to change and inexpensive. it benefits from a regular service wash and filter clean, other than that it just gets used.
                                      • llonen
                                        • Sep 2014
                                        • 495
                                        • hampshire
                                        I suppose out of all the machines I get call outs to repair Beko are quite low in numbers, with Hotpoint, Indesit, logik and Candy being quite high, I am not sure if that is anything to go by or if its just a reflection of my customer demographic and base.
