Jet AFS-1000B Air Cleaner
  • elmo
    • 21
    I have a Jet AFS-1000B Air Cleaner. It has a three speed blower and a remote control. It has a CP8112B-L8SN24 controller and BT139X-600F triacs on the output to the blower. I usually run it on the lowest speed. Recently, it started shutting off after running for only a few minutes. If I restart it immediately, it will run for only a few seconds. If I wait a while, it will run for a few minutes again before shutting off. Could a failing triac cause it to operate this way? The remote control and all the speed and timer functions seem to work fine. The control board is powered up all the time even when the blower is off.
    • 31086
    Re: Jet AFS-1000B Air Cleaner
    got some pcb foto's??
    • fzabkar
      • Mar 2009
      • 772
      Is there a thermal cutout?
      Here is the datasheet and application circuit for the controller (CP8112B-L8SN24):
      http://pdf.icpdf.com/download.asp?id=1650964_201185
      • fzabkar
        • Mar 2009
        • 772
        JET AFS-1000B Operating Instructions:
        6.2 Overload protection
        The fuse switch (C, Fig 4) will pop out in case of overload. Wait 5 minutes and push the fuse back in.
        • elmo
          • 21
          Thanks for all your responses. I don't have any photos yet but will post them as soon as I do. There is a thermal overload switch on the unit but it is not tripping. I did find a data sheet and circuit diagram for the controller IC but it may not be the same one you are referring to. The one I have is at .
          I found someone on another forum who was having the same problem. He solved his by replacing the whole circuit board. I was hoping to be able to repair the one I have since it seems to be in good shape. I think the controller IC is working since I can select all the different speeds and times with the remote control. That is why I thought the triac might be failing. I haven't been able to check the -5V supply yet but it seems to be adequate to power the controller IC and the remote control.
          • fzabkar
            • Mar 2009
            • 772
            The externally resettable overload switch is most likely a current overload. The motor probably has an additional thermal cutout embedded within it.
            I would remove the PCB and connect the motor directly to AC using each of the L,M,S windings in turn. It would be advisable to include the external current overload switch in the circuit.
            • elmo
              • 21
              Sorry to be gone for so long. I have not had much time to work on it due to other pressing problems. I did manage to remove the control board and jumper the motor directly to power. It works fine in this mode so I'm thinking the problem is in the board.
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                Yes.
                Half shorted or leaky triacs will impose a DC component to the voltage fed to the motor.
                An induction motor such as the one you're dealing with will not tolerate this. The stator will saturate- motor draws excessive current and pops the breaker/overload.
                "pokemon go... to hell!"
                EOL it...
                All style and no substance.
                guilty,guilty,guilty,guilty!
                guilty of being cheap-made!
                • elmo
                  • 21
                  Kaboom
                  Thanks for the suggestion. However, the overload is not tripping. It almost seems as if the controller was getting a shutdown command. But the operation is not random. It is very consistent.
                    Still no pictures of the boards?
                    • elmo
                      • 21
                      Sorry about the photos. I thought I had uploaded then earlier.
                      • kaboom
                        "Oh, Grouchy!"
                        • Jan 2011
                        • 2507
                        If C3 is bad/fake/questionable, the micro gets bad power and resets- unit appears to then be "off," since powerup state for micro is to default to fan off.
                        This is a capacitive divider power supply- C2, 2.2u (10%) if decreased in value will cause strange symptoms- things like micro dropping out upon driving triac gates (for instance).
                        I'm suspecting C3- replace with good 105 degree low esr unit, such as for an SMPS. Extreme ripple into that micro will wipe its programming, seen this with cheep "tower" fans and crock pots. Use PW, HE, FR, FC, or equivalent.
                        EOL it...
                          • 31086
                          the original soldering is a joke, most of it is only touching the pins and not binding to them.
                          it almost looks like they used the wrong type of flux on the production line.
                          specially the large connector.
                          • Longbow
                            • Jun 2011
                            • 623
                            Originally posted by kaboom
                            Half shorted or leaky triacs will impose a DC component to the voltage fed to the motor. An induction motor such as the one you're dealing with will not tolerate this. The stator will saturate- motor draws excessive current and pops the breaker/overload.
                            Since triacs are used in AC circuits, I can't see how a bad one would impose a DC component to the load. If the triac becomes shorted, your motor runs all the time. If the triac has turned into a resistor, then the motor gets lower AC voltage than it is used to. The motor might not start or may get hot, but the triac will get even hotter. So far, no evidence of thermal problems. The controller would be the next best choice.
                            Is it plugged in?
                              Do you have the pictures of the blower motor?
                                Is this the blower motor?
                                http://www.ereplacementparts.com/motor-p-446851.html
                                It has AC caps for the motor.
                                • kaboom
                                  "Oh, Grouchy!"
                                  • Jan 2011
                                  • 2507
                                  That's a multispeed PSC motor- exactly the same as a common furnace blower motor. Four wires=three speed taps, plus neutral/common.
                                  If more than one tap is energized at the same time, you get smoke and a dead motor.
                                  EOL it...
                                  • elmo
                                    • 21
                                    Thank you all for your suggestions. I can't see the motor, but I presume that is the correct one since it is the replacement part for the AFS-1000B. I think the motor is all right since I ran it for over an hour with the board jumpered out. I just measured the -5V power supply voltage. It does indeed measure 5 volts with about 60 mV of ripple. Of course this is with no load on the board. This may not be surprising since the blower always ran when started. It just does not run for long when powered by the board. I, too, am suspicious of C3 since the top of it is bulged out somewhat. I guess the only thing to do is to replace it and see if that helps. It seems that most of you think Panasonic makes good capacitors but are not Nichicon, Rubycon, Kemet,ans Vishay good brands too?
                                    • Longbow
                                      • Jun 2011
                                      • 623
                                      Other possibilities, taking into consideration all of your observations: the 32 KHz clock crystal used in this circuit is a type widely used in lots of gear. If possible, check the waveform on the osc pins, or if test equipment is unavailable replace it next time you place a parts order (they are very easy to find and inexpensive). Also check the resistor on pin 2 of the controller. This resistor sends zero crossing information to the controller, and it may have changed value. That would upset the firing on the triacs.
                                      As mentioned before, the soldering on your board is terrible. Heat and vibration will create miniature cracks that can hardly be seen. I would run small tinned bus wire along any of the AC traces starting with the board AC connector pins. The points where the connector pins solder to their traces are of special interest. Same goes for the legs of the triacs.
                                      Is it plugged in?
                                      • kc8adu
                                        • Nov 2003
                                        • 8832
                                        • U.S.A!
                                        half a triac equals a diode.
                                        • piipo
                                          Old Privileg 5.1 speakers remote control question
                                          by piipo
                                          Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                                          09-18-2024, 01:55 AM
                                        • hemant_2222
                                          Schematic for Denon Remote Control RC1156
                                          by hemant_2222
                                          Hello Everyone,
                                          Hope everyone is enjoying their repairs at hand!.
                                          I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                                          I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                                          Please refer to the attached picture, i think the voltage divider is missing...
                                          10-06-2023, 02:05 AM
                                        • dfear
                                          hitachi 75hl16t64u - not responding to remote control
                                          by dfear
                                          I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
                                          It came in for a power issue which I have finally resolved by replacing the power supply.
                                          The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
                                          Anyone have a clue how to fix TV?
                                          FYI: I have checked the remote work s by pointing it at my camera on my phone....
                                          09-02-2024, 12:15 PM
                                        • wolf1976
                                          wireless receiver for 6 speeds fan control with remote control
                                          by wolf1976
                                          hi i have a receiver that is destroyed from the overvoltage i guess
                                          my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                                          the motor fan has not label
                                          i have an other receiver operational
                                          In your opinion can i measure the voltage at the output ?
                                          what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                                          thanks in advance...
                                          07-23-2025, 03:12 PM
                                        • t4796
                                          Fujitsu Aircon remote control
                                          by t4796
                                          I managed to drop this recently. It fell flat and square onto the floor from about 1.8m. Can't remember if face up or face down.
                                          The remote still kinda works but the display is blank and only shows up if I repeatedly flick the little silver crystal/oscillator looking thing on the board.
                                          Not sure if this part is the culprit or if flicking it is moving something else, but it seems localised to that component as far as I can tell.
                                          Having trouble working out the value of it since it doesn't seem to have anything other than a brand name printed on the side of it....
                                          01-03-2025, 11:24 PM
