Hotpoint FFA47X Fridge Freezer
  • Rhothgar
    replied
    Re: Hotpoint FFA47X Fridge Freezer
    I am just checked over all the lead type resistors in the board and they are all fine.
    Just noticed that the reed switch appears closed. Reading back through the topic stj states it should be open. This may be why the fans and lights are now not coming on perhaps?
    EDIT: reed switch fine continuity when magnet near and loses continuity when magnet removed.
  • Rhothgar
    replied
    WOW! Now I'm confused.
    I'll take some more detailed photos of the board. Part or whole? That is the question.
    I had a fright earlier and am concerned I am wasting my time and everyone else's.
    The wiring from the PCB to the display had broken through. I repaired this temporarily and bought a replacement.
    I need to check chronology of when that cable arrived. I'll explain why.
    I ordered the wrong cable and it didn't fit. It's s bit difficult to order the correct parts when you don't have a parts diagram. As of yesterday, I now have a parts diagram.
    I therefore needed to do a more permanent repair in the PCB to display cable.
    I plugged in the cable today and realised it was the wrong way around.
    The worry now is did I actually blow the display when the PCB exploded.
    I've got it plugged in now and the fans aren't working. Did I perhaps not Okug it in correctly before?
    When I say plugged in wrong I mean the colours at intermediate connector is wrong. Perhaps it makes no difference.
    If the triacs power the fans, and the fans aren't working, why?
    At what point do I throw the towel in and give up?
    replied
    in series - yes.
    but with both contacts.
  • Rhothgar
    replied
    Originally posted by stj
    triacs are for driving the fan / lights.
    that 10k that read 0 on the board - sounds like something in parallel with it may be shorted - follow the tracks and see what's there.
    If I follow the tracks wouldn't that be in series?
  • Rhothgar
    replied
    Originally posted by budm
    Using ESR meter to check the resistance is not going to work, for example, if there is cap connect in parallel with resistor, what do you think the the ESR meter is going to show?
    Absolutely no idea other than not the right figure and that's an educated guess based in the fact that you are highlighting it to me.
    I am new to this so I have no idea how I would know if something is in parallel on a PCB.
    I assume if in series the components would be on the same track.
    replied
    replied
  • Rhothgar
    replied
    Damn!
    Just desolder end the one which measured 1000 Ohm on the board and it measures 10000 Ohms off.
    So it would seem that the reason the display does not light up anymore is nothing to do with those resistors.
    As the triacs were higher rated, are we absolutely 110% sure that they couolld not be causing the display to light up?
    I'm at a serious crossroads now. Missus is back off holiday and she's looking to buy a new fridge! Don't know how much longer I can convince her that I can get it working again.
  • Rhothgar
    replied
    now looking at the wiring diagram,
    there are 2 thermal fuses - but it does not say if they are self-resetting or if they have a button on them.
    so check those just incase.
    and now i know the wiring i'll have another look at the pcb foto's
    No way of checking them. They are sealed in a block but interestingly I get no continuity but not sure which wires to be checking. Two yellow. Two blue. Manual States two yellow two brown I think.
    Got resistors from RS. The 103's are marked as 1002's so I guess they are the same if you add two zeros into 100 it gives 10000 and they measure 9.96 on 20K scale.
    replied
  • Rhothgar
    replied
    that's fine.
    the peak ESR meter is only designed to read upto a couple of ohms - after that any capacitor is considered totally fucked.
    the maplin meter is working fine.
    the resistor is 10k
    the 20k scale gave you 9.96k which is within the 1% spec.
    the 2k scale wont work because you cant read a 10k part with the meter set to only read upto 2k
    btw, i just grabbed the manual - so i'll start reading through it.
    re-upped for others to read.
    I thought my obs were right but needed reassurance as I am new to all this.
    That's the correct file that you have 'upped'. I may be worth sequesting to another area of the forum also for future reference and also grabbing all the models it covers - not just FFA47X.
    Useful resource, eh?
    Bamboozled by the resistor as it read zero on the board whereas the other 103's read 10,000 Ohms!
    It's getting swapped out now it is off for a new one this afternoon.
    replied
    Originally posted by Rhothgar
    On the board it measured open circuit user Peak Atlas ESR+ 70.
    Off the board, the Peak states 10.0 whereas my Precision Gold PG017 DMM states OL if set on the 2K scale and 9.96 on the 20K scale.
    that's fine.
    the resistor is 10k
  • Behemot
    replied
    The only theoretical exmplanation I can think of is the resistor has huge parasitic capacity so it lowers the ESR with high-frequency current applied.
    But as Occams razor dictates, it most likely just measures BS.
  • Rhothgar
    replied
    The crux of this issue appears to be my measurement instruments.
    I found an online manual for my multimeter and it doesn't explain the scales but to my mind if it doesn't read on a low scale but does in the high scale then it must be over the lower value.
    Does anyone have a similar meter and can confirm?
    The resistor is not 10 x (10*3). The code stands for 10 with 3 zeros after it according to a website alled mds975. After it all it amounts to the same but it is an easier way to think of it.
  • keeney123
    replied
    Just managed to desolder a 103 SMD resistor. It gives 10 Ohms. Shouldn't it be 10,000 Ohms?
    10 x (10*3)?
    Yes it should be 10000 ohms. If this board was made in China they could of gotten it wrong in two ways. They could of mis-marked the resistor and installed them anyway or the resistor is the wrong resistor and it should be a 10K ohm. I have run into this problem with color coding where the resistor color code was different from what the resistor was. The resistor was actually correct but had the wrong code marking.
  • vinceroger69
    replied
    10 x (10*3)?
    I thought 103 was 10k ohms?
  • Rhothgar
    replied
    10 x (10*3)?
    replied
    pm me the details to get the manual.
  • Rhothgar
    replied
    Guys. I've found the technical manual online for the fridge. It's taken a lot of rooting around and I have managed to find a login and password for indecent, ariston, etc. service site.
    However, I do not want to post copyrighted material if it breaks the forum rules.
    What to do?
    Having read through some pertinent pages in the manual, it seems that neither the freezer or fridge air sensors are replaceable. So if I happen to have blown them when the PCB blew up, then I need to end my quest here rather than continue to waste time on it.
    The SMD ceramic resistors, still didn't arrive today, so thank you RS Online for letting me down two days on the trot.
    From the tech manual, I can see that J3 on the PCB receives the information from the 3 sensors. Presumably this is just a case of metering for Ohms here so see if I get a reading that looks relevant?
  • Rhothgar
    replied
    Originally posted by keeney123
    Most likely the problem will be on the board as that is more fragile then wire with insulation on it.
    It's good to know that the wiring may be unaffected but I take it you didn't look back at Post 71 as previously suggested!!!
  • CG2
    Liebherr Fridge Freezer KGT 3456 not working
    by CG2
    To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
    01-25-2023, 02:12 PM
  • mikey5791
    Help repair Panasonic fridge not cooling
    by mikey5791
    Hi all forum members,
    Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
    After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
    07-16-2025, 02:01 AM
  • tmcw
    Fridge - Gram
    by tmcw
    Have this fridge, laboratory grade unit, not working fully.
    It's designed with a chilling unit at the top, on the inside, and a fan just below that. When the door is closed, the fan blows the cold air down through the fridge, and when the door opens, the fan switches off, presumably so that it doesn't blow all the cold air out.
    The fan isn't switching on, so in addition to not having uniform cold throughout the fridge, the chilling tubes tend to ice up. I took the lid off the top, electronics are in the lid, and when the door is opened and closed, I can hear the relevant...
    10-10-2023, 05:00 AM
  • unimatrix93
    Replacement transformer for Samsung fridge
    by unimatrix93
    Dear forum
    My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
    No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
    The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
    My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
    07-14-2025, 02:16 AM
  • lapfix
    Dell latitude 5320 South peak 13 not power on.
    by lapfix
    Hello friends
    Got this laptop dell 5320 not power on , just a fast and a dim blink amber light at the power on led indicator.
    motherboard south peak 13 mb 213252-1
    i'm using schema and Bvd similair to this motherboard. https://www.badcaps.net/forum/troubl...-latitude-5320
    i don't have a type-c meter for the moment , so i m taking the voltage using his original charger.
    As i undestand from many topic here ,...
    04-29-2025, 06:22 AM
