Re: Hotpoint FFA47X Fridge Freezer
I am just checked over all the lead type resistors in the board and they are all fine.
Just noticed that the reed switch appears closed. Reading back through the topic stj states it should be open. This may be why the fans and lights are now not coming on perhaps?
EDIT: reed switch fine continuity when magnet near and loses continuity when magnet removed.
WOW! Now I'm confused.
I'll take some more detailed photos of the board. Part or whole? That is the question.
I had a fright earlier and am concerned I am wasting my time and everyone else's.
The wiring from the PCB to the display had broken through. I repaired this temporarily and bought a replacement.
I need to check chronology of when that cable arrived. I'll explain why.
I ordered the wrong cable and it didn't fit. It's s bit difficult to order the correct parts when you don't have a parts diagram. As of yesterday, I now have a parts diagram.
I therefore needed to do a more permanent repair in the PCB to display cable.
I plugged in the cable today and realised it was the wrong way around.
The worry now is did I actually blow the display when the PCB exploded.
I've got it plugged in now and the fans aren't working. Did I perhaps not Okug it in correctly before?
When I say plugged in wrong I mean the colours at intermediate connector is wrong. Perhaps it makes no difference.
If the triacs power the fans, and the fans aren't working, why?
At what point do I throw the towel in and give up?Last edited by Rhothgar; 07-07-2015, 10:17 AM.
in series - yes.
but with both contacts.
Originally posted by stj View Posttriacs are for driving the fan / lights.
that 10k that read 0 on the board - sounds like something in parallel with it may be shorted - follow the tracks and see what's there.
Originally posted by budm View PostUsing ESR meter to check the resistance is not going to work, for example, if there is cap connect in parallel with resistor, what do you think the the ESR meter is going to show?
Absolutely no idea other than not the right figure and that's an educated guess based in the fact that you are highlighting it to me.
I am new to this so I have no idea how I would know if something is in parallel on a PCB.
I assume if in series the components would be on the same track.
Damn!
Just desolder end the one which measured 1000 Ohm on the board and it measures 10000 Ohms off.
So it would seem that the reason the display does not light up anymore is nothing to do with those resistors.
As the triacs were higher rated, are we absolutely 110% sure that they couolld not be causing the display to light up?
I'm at a serious crossroads now. Missus is back off holiday and she's looking to buy a new fridge! Don't know how much longer I can convince her that I can get it working again.
Originally posted by stj View Postnow looking at the wiring diagram,
there are 2 thermal fuses - but it does not say if they are self-resetting or if they have a button on them.
so check those just incase.
and now i know the wiring i'll have another look at the pcb foto's
Got resistors from RS. The 103's are marked as 1002's so I guess they are the same if you add two zeros into 100 it gives 10000 and they measure 9.96 on 20K scale.
Originally posted by stj View Postthat's fine.
the peak ESR meter is only designed to read upto a couple of ohms - after that any capacitor is considered totally fucked.
the maplin meter is working fine.
the resistor is 10k
the 20k scale gave you 9.96k which is within the 1% spec.
the 2k scale wont work because you cant read a 10k part with the meter set to only read upto 2k
btw, i just grabbed the manual - so i'll start reading through it.
re-upped for others to read.
That's the correct file that you have 'upped'. I may be worth sequesting to another area of the forum also for future reference and also grabbing all the models it covers - not just FFA47X.
Useful resource, eh?
Bamboozled by the resistor as it read zero on the board whereas the other 103's read 10,000 Ohms!
It's getting swapped out now it is off for a new one this afternoon.
Originally posted by Rhothgar View PostOn the board it measured open circuit user Peak Atlas ESR+ 70.
Off the board, the Peak states 10.0 whereas my Precision Gold PG017 DMM states OL if set on the 2K scale and 9.96 on the 20K scale.
the resistor is 10k
re-upped for others to read.Attached Files
The only theoretical exmplanation I can think of is the resistor has huge parasitic capacity so it lowers the ESR with high-frequency current applied.
But as Occams razor dictates, it most likely just measures BS.
The crux of this issue appears to be my measurement instruments.
I found an online manual for my multimeter and it doesn't explain the scales but to my mind if it doesn't read on a low scale but does in the high scale then it must be over the lower value.
Does anyone have a similar meter and can confirm?
The resistor is not 10 x (10*3). The code stands for 10 with 3 zeros after it according to a website alled mds975. After it all it amounts to the same but it is an easier way to think of it.
Originally posted by Rhothgar View PostJust managed to desolder a 103 SMD resistor. It gives 10 Ohms. Shouldn't it be 10,000 Ohms?
10 x (10*3)?
10 x (10*3)?
10 x (10*3)?
pm me the details to get the manual.
Guys. I've found the technical manual online for the fridge. It's taken a lot of rooting around and I have managed to find a login and password for indecent, ariston, etc. service site.
However, I do not want to post copyrighted material if it breaks the forum rules.
What to do?
Having read through some pertinent pages in the manual, it seems that neither the freezer or fridge air sensors are replaceable. So if I happen to have blown them when the PCB blew up, then I need to end my quest here rather than continue to waste time on it.
The SMD ceramic resistors, still didn't arrive today, so thank you RS Online for letting me down two days on the trot.
From the tech manual, I can see that J3 on the PCB receives the information from the 3 sensors. Presumably this is just a case of metering for Ohms here so see if I get a reading that looks relevant?
Originally posted by keeney123 View PostMost likely the problem will be on the board as that is more fragile then wire with insulation on it.
