Problem with power inverter emc18aecn1 of washing machine AEG L6FBA674
  • stomanata
    • Apr 2016
    • 82
    • Bulgaria
    on my previous post with help from this forum i found short circuit GIF5CH60TS-X
    I replace it but again give me error for current over 16A.
    I measure again and found short circuit between #15 and #16 (Cin and GND).
    On PCB i remove R121 to check in which direction is short circuit. But this pin goed
    to big copper piece on back side.
    So i try to measure over every resistor and capacitor
    But i can`t find any short circuit,
    On example circuit of GIF5CH60TS-X is labaled that Cin can goes to GND in some cases:
    1. Through CSF (i don`t know where is he)
    2. Through RSF and Rshunt
    3. Through RSF and MCU/op-amp
    4. Through RSF and Rshunt and then C4 or Cvdc
    Any help?
  • CapLeaker
    Leaking Member
    • 8188
    Maybe there is something wrong with the motor?
    • stomanata
      • Apr 2016
      • 82
      • Bulgaria
      no, no.
      I have short circuit with everything disconected - only this PCB from attach and still
      there is short circuit
      • CapLeaker
        Leaking Member
        • 8188
        Originally posted by stomanata
        no, no.
        I remember this case now… this was a no spin, right? You may have gotten a bad motor drive controller IC, or there is something else broken. Measure the resistance between CIN pin 15 and the low side output pins 18, 19 and 20.
        • stomanata
          • Apr 2016
          • 82
          • Bulgaria
          Yes, case with no spin.
          I replace GIF5CH60TS-X, but after again error i start to measure again and notice short circuit
          between Cin (pin #15) and GND (pin #16).
          This i why i desolder 1 resistor and notice that short circuit come from other line, but
          it is big Cu plate on PCB and is connected to too much elements. So i try to measure
          all resistors and capacitors but no luck...
          • CapLeaker
            Leaking Member
            • 8188
            So you are getting that E57 (over current) error? Since nothing is shorted, all I can think of is maybe a through hole is bad, or a resistor changed value and it went high in resistance / open and thus is out of spec.
            • stomanata
              • Apr 2016
              • 82
              • Bulgaria
              Biggest question is how to find defective component?
              Stupid solution is to desolder component by component until
              short is gone
              • CapLeaker
                Leaking Member
                • 8188
                All depends on your capabilities. Your way is the long, complicated way. For shorts you need a meter that can reads resistance below you regular DMM. There are things like a Leakseaker 89 too. Thats how I figure out complicated shorts. But not everyone has such a thing. Like I said, it could be a short, but the problem could be also a resistor went open or higher that it should be. There is also a thermal camera to spot something hot, when feeding power to the shorted line. Another way to find a short is using 99% rubbing alcohol, douse some components and feed the shorted line power with the CV / CC bench power supply and see what gets hot. The alcohol will vapour off quickly. Most times I use the alcohol method, even so I got all 3 options to my disposal. This being said, if going gets tough, my Leakseaker 89 finds it every time.
                What did you come up with the resistance measuments suggested in my post #4?
                • stomanata
                  • Apr 2016
                  • 82
                  • Bulgaria
                  Yes, removing components will waste a lot of time.
                  Why i need device that can reads resistance below my regular DMM?
                  I have short circuit between 2 pins.
                  I measure with my DMM in "diode" condition every resistor, capacitor and 3 transistors.
                  But i can`t find component that has low resistance. There is 6-7 resistors with low
                  resistance but they are OK.
                  I think that thermal camera or alcohol method will be not usable, because
                  electronics try to start but i read error and stop.
                  • CapLeaker
                    Leaking Member
                    • 8188
                    Because it gives you more resolution and you can tell if you are going the right way looking for the short.
                    For example: if your resolution is 0.01 Ohm, it's a short. But you find it everywhere on that trace, because there is no lower resolution. Now if you can measure in milliohm or microohm, resistances will be different. in that scale. On the same trace further away it will be a higher microohm reading than there where the short actually is. Resolution is king and fault finding technique is king.
                    If you inject voltage on that shorted trace only the bad component gets hot, unless it is Vcc for certain chips. That means you have to remove the IC or cut a trace.
                    A good head scratching example of a short using the alcohol and voltage inject method in a power supply I did is here: https://www.badcaps.net/forum/troubl...-output-repair
                    There is also a Feeltech/Kuman repair where I used this technique. I am not powering the whole thing. I only force fed power to the shorted trace. Just be careful and stay withing the voltage range in that trace.
                    Technical discussion for power supplies. This covers PC supplies, and any other related power supply issue. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                    • stomanata
                      • Apr 2016
                      • 82
                      • Bulgaria
                      Thank you. Now i understand. I didn`t know that we talk for even microohm resolution
                      So what current to try to apply between pin #15 and GND?
                      May be 0.5A to don`t burn some copper track - 5VDC with 10 ohm/2W resistor?
                      • CapLeaker
                        Leaking Member
                        • 8188
                        You need a constant voltage / constant current bench power supply. Not just some regular power supply. Before you use this method, try it on a junk board so you get a feel for it. On how much voltage and current to use. I'd start with 3 volt and just rack up the current from 0.5A to to be safer. For one volt I used 5A before. If you use more voltage than the circuit is designed for, you have to take voltage sensitive components out. Sometimes it takes a few minutes for it to get hot. All depends on the component and the heat sink.
                        • jdbird613
                          Power Inverter Replacement Circuit Board Question?
                          by jdbird613
                          So my Ampeak 2000 watt power inverter will receive power from a 12 volt source, and also has a display screen that displays how many volts the inverter is currently using...However, the plug outputs are not producing any power outward...The display screen on the inverter also shows how many volts an item that is plugged in is currently using...Which stays at 0 and no items will power on...I opened the inverter casing and discovered there is some charring and burned areas on one end of the circuit board...What I am trying to figure out is if I can purchase/obtain a new board exactly like the board...
                          02-27-2020, 08:37 AM
                        • Astonished
                          Fixing the Charge Circuit of the Batteries of the DC Motor
                          by Astonished
                          Hi friends of electronics
                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                          Please help me fix this circuit.
                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                          01-28-2025, 06:24 AM
                        • Soulzink
                          Samsug washing machine. Power supply DC41-00189a board issue
                          by Soulzink
                          I am trying to fix a samsung washinmachine power supply main board.
                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                          The power supply board reference is the following: DC41-00189a
                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                          04-19-2025, 06:26 AM
                        • x_orange90_x
                          by x_orange90_x
                          01-29-2025, 09:24 PM
                        • Tarot Superstars
                          Short Circuit tester
                          by Tarot Superstars
                          Hello.
                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                          Link
                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                          https://www.youtube.com/watch?v=0eixDdCpiO4
                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                          09-25-2023, 09:11 AM
