HOW TO TEST MIFLEX X25 HELP!!!
  • NConstantinou
    • May 2017
    • 340
    • Cyprus
    Dear all
    i have Elecrolux dishwasher with no power light on display. i found on control board R67 and ic burn which i replaced.
    i do not get 230v ac on control board. i removed power in connector and i varified that.
    i started with the main plug and the wire goes to this miflex component. on miflex i do get 230vac. how do i test the output!
  • NConstantinou
    • May 2017
    • 340
    • Cyprus
    the capacitance reading between L&N is 0.05μf
      • 21117
      Post pictures of both sides of the board,and the miflex component with the part numbers
      • NConstantinou
        • May 2017
        • 340
        • Cyprus
        This is the component. I will take a picture of board tomorrow.
        thanks
          • 31077
          it's a noise filter - you dont need it to test the machine
          • NConstantinou
            • May 2017
            • 340
            • Cyprus
            Picture of control board
            • NConstantinou
              • May 2017
              • 340
              • Cyprus
              i have noticed that are no fuses on board. can i apply 230v ac directly on board!
              on this board r67 and u2 7 pin ic was burned and replaced.
              what voltage should i get on main capacitor
              thanks
              • NConstantinou
                • May 2017
                • 340
                • Cyprus
                Further troubleshooting. Since I got 230v on filter capacitor, then I checked Ntc brown component I do have 230v but on L and N on control board only 13v, no display.
                  • 31077
                  whats the numbers on chip U2 ?
                  • NConstantinou
                    • May 2017
                    • 340
                    • Cyprus
                    Was LNK362gn
                    • NConstantinou
                      • May 2017
                      • 340
                      • Cyprus
                      By unplugging connections and connecting back now on unplug connector of control board I get 230v.
                      if I plug connector no display
                        • 31077
                        data sheet
                        https://www.power.com/products/links...gn?langcode=en
                        • NConstantinou
                          • May 2017
                          • 340
                          • Cyprus
                          i already changed the ic but still no display. by checking the components on control board i didn't find anything else wrong.
                            • 31077
                            the datasheet has example schematics
                              1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                              by sam_sam_sam
                              I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                              This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                              12-29-2024, 07:18 AM
                            • chth96
                              How Can I test PWM DM0365R?
                              by chth96
                              Hello
                              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                              06-18-2025, 04:14 PM
                            • khelane
                              test active pfc power with lamp test
                              by khelane
                              Hello
                              I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                              Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                              Is there a way...
                              06-03-2025, 01:00 AM
                            • chronic519
                              Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                              by chronic519
                              Hello.
                              GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                              Found issue with a RAM block
                              Replaced, green lines gone.
                              Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                              Used a good card to test and same results low errors 32+.
                              I am just search for some form of command to do a full test on the GPU.
                              I just ran the mats command with my good GPU and passed after roughly 40 min.
                              The repaired one, ran...
                              05-20-2025, 07:56 PM
                            • Yanleb
                              LG 60PK550 Logic Control Board EBR63450301
                              by Yanleb
                              Hi all, I just want to share the repair of my 60PK550-UA TV set.
                              The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                              But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                              All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                              C57: 3.30V
                              C61:...
                              07-20-2023, 12:38 AM
