EUFY RoboVac X8 hybrid error S1
  • tehmatix
    • Nov 2012
    • 174
    I have this cleaning/moping robot working fine for 7~8 months with not any problems. Now its coming with "error S1" and I don't know what to do.
    What I done since now is to check the battery which is ok, I replaced it with other battery and its doing same thing, I checked to see if anything is stuck or block, I did a hardware reset and connecting back to my wifi.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8328
    I think an error S1 is related anything to charging, not only the battery. By that I mean it includes the adapter, the charging base and the metal connections between the base and the robot itself.
    • tehmatix
      • Nov 2012
      • 174
      It's doing that even without charging base, and the battery is fully charged. I will check again the power adapter.
      Can you tell what is doing the micro-usb port next to the battery?
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • drscoot
        HP X360 convertible battery blown fuse error, not charging
        by drscoot
        HP Modelnumber: 14-dh0061nb​
        This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
        The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
        I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
        And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
        All these 3 batteries are charging...
        12-15-2023, 05:54 AM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        09-14-2023, 11:10 PM
      • ferah831208
        by ferah831208
        03-18-2025, 01:18 AM
