um...dishwasher?
  • kiddznet
    • Jul 2010
    • 176
    um...dishwasher?
    Anyone worked on a auto dishwasher board with any degree of success?
    They is too expensive to replace.
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
  • seanc
    • Nov 2008
    • 1319
    Re: um...dishwasher?
    'Auto' dishwasher...?
    Is this just a standard kitchen dishwasher?
    What board, what's wrong with it? Make & model, PICTURES!
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      I recommend marriage counseling. Divorces are expensive, you're right there.
      Ludicrous gibs!
      • bluto
        • Oct 2007
        • 560
        try www.partselect.com or
        www.repairclinic.com or
        www.appliancepartspros.com
        for parts.
        There use to be a whirpool site that had all their brands' service manuals available for free. But alas the b*%tards made it paid subscription only starting oct 1. I won't help them out by linking to it.
        • kiddznet
          • Jul 2010
          • 176
          Its a Simpson Silencio 972
          It wont progress past pre-wash just sits looking dumb with a a light cycling.
          I had the door cover off just a simple looking board, will take a photo later
          • seanc
            • Nov 2008
            • 1319
            The dishwasher is trying to tell you something! My Googleing didn't get my far though.
            I found manuals for the 850, here: http://www.cs.usyd.edu.au/~jstavrak/simpson_dishwasher/
            You can try contacting Simpson, but if they're anything like Hotpoint, they'll tell you to look at an FAQ that doesn't help. They might give you a manual!
            In the case of my Hotpoint washing machine - the filter was blocked, resulting in the mini load and reduced crease light flashing, because the pump couldn't move the water.
            • kiddznet
              • Jul 2010
              • 176
              Thank you seanc. My machine appears to be close to the 980
              Here is dishwasher central. I love to know what them wires lead to....
              • seanc
                • Nov 2008
                • 1319
                There's two boards, with an intermediate board, connected with resistors? Interesting.
                All I would do at the moment is check ESR of caps and solder joints.
                I'd be more interested in finding the meaning of the flashing light - it means something.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  This might help a little:
                  SIMPSON SILENCIO 972 DISHWASHER => Model: 52B972WE*01
                  - from: http://spares.alliedappliance.com.au...4_3_10_73.html
                  Parts houses will probably use 52B972WE*01
                  No luck on a drawing.
                  I'm kind'a thinkin' bad transistor, or one not working due to bad supporting part.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    talking about work like we do sometimes. that kind of stuff has some potential. most plumbers/home techs i know their abilities dont extend to board repair. get a few of them as client and bingo.
                    • NxB
                      • Feb 2009
                      • 1595
                      Are you sure the physical parts are OK. It might not progress because something else is wrong. The board does show corrosion. Check all connections and then transistors.
                      • Junk Parts
                        Court Jester
                        • Jun 2006
                        • 8953
                        I'd look at the interlock safety switches. Next I'd look at the pump. What about the stain on the choke there? Is it fried?
                        "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
                        Mark Twain
                        "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
                        John Paul Jones
                        There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
                        Rod Serling
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          I agree.
                          The was a blurb in the sketchy manual that said the door safety switch would stop it.
                          Can't think of why a flaky switch would stop it at exactly the point in the cycle every time though...
                          - Dr Seuss
                            • 31046
                            99% of the time with these types of gear it's not the board.
                            check the pump filter and any pressure sensors - if they have small hoses linking them you need to check the hoses arent blocked by crap or scale.
                            i'v done some washing machines and it's always some sensor or other mechanical part.
                            • Quasar
                              • Sep 2010
                              • 132
                              Originally posted by PCBONEZ
                              I agree.
                              Don't want to sound like "me too", but both these are right on track.
                              A bad or blocked line when it goes to pump out will kick it into shutoff. A door switch or interlock would prevent it from even working. A failure in the "brain" is not usually picky and would not let it even begin to function correctly.
                              Listen to it and see if you can detect what it tries to do when it fails. Does the motor do the first cycle then stop then start again and shutdown? That would usually point right at a blocked or restricted drain, and a sensor has prevented that. These reverse motor direction to pump out.
                              I had one where a screw came loose and was in the pump. Cycled fine until pump out. Then it sounded like a coffee grinder.
                              You'll figure it out eventually, but I don't think you are having a control board problem.
                              Or, you'll call the repairman...
                              Q
                              • kiddznet
                                • Jul 2010
                                • 176
                                Thanks everyone for your help
                                I got a day on it tomorrow will check everything I can that you have suggested
                                I rescued it from the tip was on neighbours frontage awaitin collection, I think it will make a half decent home brew bottle steriliser
                                Meantime putting together latest board, Fatal1ty AN8 SLI 939 with an Opteron 165
                                BTW I went over some soldering on caps on an EPOX board with my big bad boy iron. Not only did it start without faffing about, but the CPU runs 20C cooler
                                • kiddznet
                                  • Jul 2010
                                  • 176
                                  Well now to add to my problems the Fatal1ty wont start. In fact it does not do much. No LED display only little red winking LEDS near the GURU pins I took out the 24 pin connecter and hooked it up to a tester and the board lights near the VRM came on with the 4 pin plug still in. The PSU tested fine but no life from the board
                                  Oh...when I unpacked it someone had left off the CMOS jumper. I put another one on cleared this and put in new battery
                                  Just out of curiosity would this board run with that jumper missing?
                                  AN8-SLI 939 socket
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    Yes it will run with the jumper missing. You have another problem.
                                    A working TV? How boring!
                                    • kiddznet
                                      • Jul 2010
                                      • 176
                                      Thank you Th3.
                                      I will try another PSU today but I dont like the look of it
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        I don't think modding you dishwasher with a motherboard will get the dishes any cleaner.
                                        - Dr Seuss
                                        • classicandy
                                          Lenovo G50-80 Auto Power On when AC is detected
                                          by classicandy
                                          Hi Everyone,
                                          I have a Lenovo G50-80 that auto powers On when AC (Charger) is connected. I have checked the BIOS settings and there is no option to turn On or Off that feature as it is in some HP EliteBooks. I did update the BIOS and still same.
                                          I then flashed the BIOS with a different bin file I downloaded here, It worked (didn't auto power on) for some time (after testing up to 5 times) but has now started again to auto power on when AC is connected.
                                          The CMOS battery voltage is 3v. I have also tested with two main batteries as well. I would be glad if anyone...
                                          03-21-2024, 05:48 AM
                                        • shouri
                                          Dell latitude e5490 auto restart
                                          by shouri
                                          Hi guys, can someone help me?
                                          I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                                          Board model is dm70 la-f401p rev:1.0 2017-09-20.
                                          At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                                          After a few days test, is seems ok.
                                          Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                                          12-10-2024, 09:27 PM
                                        • dumblejd
                                          rtx 2080 GPU capped at 60 degree
                                          by dumblejd
                                          My friend has a evga rtx 2080 super, and with liquid cool backplate. I installed for him. 4 month ago it runs good, and recently idk if he played with msi afterburner or not, the gpu slow it's core frequency when it's over 60 degree. I reset setting in msi afterburner, still the same.
                                          here is a video of it running stress test, the usage is always 100% for sure, but core frenquency drop to 300mhz (should be over 1600mhz normally), when it hit 60 degree.
                                          https://imgur.com/a/gLMfJid
                                          at very beginning of stress test, the frequecy can reach 1600+, but as...
                                          12-11-2022, 11:17 PM
                                        • zomi
                                          Manual cof bonding success rate ?/ feedback wanted
                                          by zomi
                                          Just wanted to get some feedback,
                                          whats peoples' success rate with cof bonding repairs.....
                                          09-23-2024, 12:45 PM
                                        • akwky
                                          by akwky
                                          Hi!
                                          04-14-2025, 01:56 PM
