How to fine control a brushless dc motor
  • delir66
    • Aug 2022
    • 7
    • Spain
    Hi, I'm building a pottery wheel for my wife.
    Since it needs to reverse direction and have a nice control over rpm, I decided to pick a diy electric scooter motor.
    It operates at 48v and comes with a controller.
    It has three wires for speed control
    -5v
    -gnd
    -signal.
    The problem is that if I use a 100k pot, motor starts spinning when 1.4v and will get to max revolutions at 3.4v. With this 2v range, the potentiometer is not really ideal, as it will change suddenly rpm with the slighlest touch.
    I need something that is more accurate and have a longer travel. I would like to use a lever to change rpms...
    I tried with a Hall effect sensor, but again the distance from 0rpm to 600rm (full) is too small to be controlled....
    I thought that something like an adjustment pot would do, but something difficult to manipulate, need the actuator to be a lever/pedal....
    Only idea left is pinting gears for the potentiometer, but that's something i'd like to avoid....
    Thanks!
    • 31294
    Re: How to fine control a brushless dc motor
    100k?
    try a 4k7 or 5k pot with the 5v and ground on the outer pins
    5k is the usual size for analog inputs like that.
    • delir66
      • Aug 2022
      • 7
      • Spain
      Thanks for your reply.
      No, that doesn't seem to do the trick.
      Really not an expert, but unsure if this is a regular analog input. The thing is that it has a really defined start/max rpm)stop voltages. Starts spinning at lowest rpm when 1,30v and maxes at 3,40v (600rpm), if 3,50v will stop.
      Looking for a 0 to 250 rpm working range, so my voltage is between 1,35v and 1,60v aproximately.
      I attached my laboratory supply and giving that voltage straight to the signal cable, no pots.... With the fine knob from the suply I can get the aproximate range I want.
      Thought about building an resistor switch that gives 1.30, 1.40, 1.50, etc.. but I think easiest will have a cheap DAC connected to the pwm of an Arduino, so I can get a power supply that operates from 1,35v to 1,60v in a full pot turn, if that makes sense...
      Thanks!
      • redwire
        • 3912
        For safety, a scooter motor control board has a lot of "deadband" for the throttle. You don't want the throttle stuck... so they waste a lot of the 5V range.
        Can you post a picture of the board?
        You can make a restricted range potentiometer to give the 2V span but it still is a bit delicate.
        • ut-norm
          Driver brushless motor
          by ut-norm
          Hi everyone, I have a brushless motor, of which I am attaching a photo mounted on a DEWALT battery saw that has a faulty controller driver but with the windings ok. I would like to feed it with another controller driver (after having obviously removed the broken one mounted on the base of the motor ) but I don't have clear ideas about it. I've seen many controllers on Aliexpress but I don't know which one to get. It should have a locking system like the original one in case of engine jam.
          Can you help me?
          Hello everybody....
          04-06-2023, 09:09 AM
        • Dannyx
          AC Fan motor speed control ideas
          by Dannyx
          Good day folks. What I'm trying to achieve may seem pretty simple and although I found lots of discussions on the topic, it's hard for me to settle on a definitive answer, so I thought I'd ask for more opinions.
          I have a small inline duct fan which looks like this, which I want to slow down, the reason being overall noise. I have no idea what type of motor this is, because I can't exactly take it apart to inspect it without ruining it, but perhaps we can work it out by examining its behavior.
          Two things I've tried: a variac and a cheap light dimmer (triac+diac inside...
          06-17-2021, 10:44 AM
        • Bushcat
          Pioneer PL-X9 motor speed control wobble
          by Bushcat
          I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
          Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
          BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
          05-24-2023, 03:36 AM
        • juergenb
          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
          by juergenb
          i am asking for some Help.
          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
          The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
          So i got a few of these from Banggood.
          I swapped the motor and now i have a new fault condition.
          In a working Frother you would press the start button, it will light red and work for a few minutes.
          If you press longer it will light blue and just mixup the milk.
          With the new Motor it just starts...
          03-23-2021, 11:24 AM
        • d00m178
          Philips toothbrush 4100 (HX369BK) - motor getting hot
          by d00m178
          trying to fix Philips toothbrush 4100 (HX369BK)
          The battery started draining quickly.
          After disassembling it, I discovered that the motor gets very hot when brush is off, which is apparently causing the battery to lose charge.
          The motor is connected to contacts M1 and M2.
          When I turn on the brush, 0.4V appears on these contacts, and the motor starts running as expected.
          But when I turn off the brush, the voltage changes to 3.8V—exactly the same as the battery.
          The motor gets so hot you can't touch it. And after 5 minutes, the battery drains to 0V.
          (To...
          11-12-2025, 03:11 PM
