Grounding
  • keyboardcowboy
    • Apr 2006
    • 73
    Grounding
    i have managed to ground my pc..now whenever i connect something like my monitor to the VGA port or the printer to the parallel port i can see very tiny sparks, is it normal or did i grounded the system wrong?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Grounding
    It is because your other devices are not grounded, so they use the cables you connect them with as grounding cables
    This can be very bad and damaging depending on the type of cable and how many thousand volts are crossing it (with static electricity a visible blue flash it at 8000 volt, electronic components like processors can be damaged by just a 30v static discharge
    A discharge of below 2000v I think it is wont even be felt...)
    Oh, and how exactly did you ground the system to begin with?
    Atleast in Sweden it is illegal to install only one grounded outlet in a room, all outlets must be grounded
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      Re: Grounding
      its funny i've handled soo many processors by hand without screwing up a single one from static electricity
      • larrymoencurly
        • Oct 2004
        • 960
        Re: Grounding
        The voltage is probably caused by the pair of 0.005uF RFI filter capacitors (tan disks in the photo) that each connect between line and case ground (yellow/green wire in photo) and the monitor's AC power socket. When the case ground isn't connected to earth ground, the caps split the 120VAC voltage to 60VAC at the ground pin.
        • keyboardcowboy
          • Apr 2006
          • 73
          Re: Grounding
          What exactly should i do to fix the problem??
          The Monitor and the system are both connected to the same earth wire
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Re: Grounding
            No current should be flowing if both devices are connected to a grounded outlet
            Get the outlets checked, either those or the cable to the monitor or the monitor itself will probably have a break in the grounding cable somewhere (or the computer)
            The reason you ground stuff is so that all devices have equal potential
            That means if you touch the refrigerator and dish washing machine with your hands at the same time you wont get a chock! (Same issue you see with your PC and monitor)
