BAUER 20V Brushless Cordless Air Compressors modifications that I am doing
  • CapLeaker
    Leaking Member
    • 8296
    Re: BAUER 20V Brushless Cordless Air Compressors modifications that I am doing
    Why are you not converting the compressor to fit for example the big Milwaukee battery and use the Milwaukee charger?
      • Jul 2011
      • 6058
      I am but because this battery pack was a available and this battery pack has twice the amp hour capacity and I want to see if I could get the buss bar cut with out damaging the tabbing or any of the battery cells
      On this battery packs I not using a tool battery charger because I am using a BMS balancing protection board so I fast charge this battery pack because it was made for it
      • petehall347
        • Jan 2015
        • 4434
        • United Kingdom
        wondering what the duty cycle is for the compressor .
          • Jul 2011
          • 6058
          Good question because I have no idea but I guess I going to find out shortly after I get the BMS balancing protection board wired up but this is another day
            • Jul 2011
            • 6058
            I can not hook up this battery pack to Milwaukee battery charger because the 12 amp hour battery packs make the battery charge run extremely warm and I really do not want to push it much more than a 12 amp hour battery pack
              • Jul 2011
              • 6058
              I do have a couple of Milwaukee defective chargers enclosure that are not worth fixing them so I going to eventually turn them into the same thing that I did with the HERCULES charger but unfortunately Milwaukee does not have a dual charger base so I will have to mount two of them to a cutting board to keep them together
              • CapLeaker
                Leaking Member
                • 8296
                Well, I guess that depends on what Milwaukee charger you have. I've got now 2 Milwaukee tools, one has a fast charger, the other one does not.
                  • Jul 2011
                  • 6058
                  I have both versions as well and I use the faster charger but even this one gets extremely warm when charging the 12 amp hour battery pack so this is the reason I really do not want to use it to charge this battery pack and I have a feeling that this charger might error out like the other two ( brand ) battery chargers have trying to charge a much bigger battery than it was designed for ( you would have to reset the battery charger a couple of times to completely charged )
                    • 31161
                    i'm surprised you dont have a programamble charger like a B6 clone.
                    those can charge upto about 24v
                      • Jul 2011
                      • 6058
                      I have both the original and the clone but I prefer the original one because it allows you to plot it on your tablet or computer
                      But there is an issue with how long the BMS protection connection wires are and if you can find the longer wires for the BMS the connector does not fit the B6 balance connector so this is an issue that I have not so far found a good solution for this issue
                      The ones that I have found on eBay for the B6 battery tester balance wires are very short and some have the red / black wires in the wrong place and you have to change them around so you do not hook it up wrong
                        • Jul 2011
                        • 6058
                        Well I have made progress on this project I finally put battery packs in the one enclosure and I finally hooked up the BMS balancing protection boards now I have to work on charging system for these two battery packs to charge at the same time which is going to be a real challenge to do and I have not quite figured this part out yet stay tuned for updates in the future
                          • Jul 2011
                          • 6058
                          Today I had a chance to run the battery operated air compressor and what a difference a big enough battery pack makes for operating this device it does not take very long for the air pressure to come up and cycle off
                          But I have an issue with one of BMS balancing protection board when you are charging it it becomes very warm at 4 amps and when you run the air compressor it also becomes very warm very quickly the other BMS balancing protection board stays cool when charging and running the air compressor I going to buy two more of them and return the BMS board because of getting warm while charging and discharging it which is what is not suppose to happen
                          I still have to work on the charger system for this battery packs and make the wiring harness for the battery packs I just have it temporarily hooked to see if the concept would work and if was doable and if anything needed to be changed for it to work correctly
                          I have a battery operated lawnmower that also has a battery pack issue that I going to modify it battery pack as well using the same battery pack that I bought from Battery Hookup I just have to figure out how I am going to hookup the battery wires to the lawnmower and also the charging system as well
                          I did some pim
                          Stay tune for more to come
                            Bauer tool battery pack charging with a HERCULES charger modification
                            by sam_sam_sam
                            The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                            Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                            05-06-2023, 12:17 PM
                          • flat-earther
                            Hoover FM216LI cordless vacuum refuses to charge
                            by flat-earther
                            I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                            I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                            5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                            So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                            06-06-2025, 03:14 AM
                          • spleenharvester
                            Cordless Dremel 8220 rotary tool power fault
                            by spleenharvester
                            Hi all
                            I bought this Dremel several years ago (8220 + 880 2.0Ah battery). After about a dozen light uses it developed a power fault. I asked Toolstation to start a warranty claim for me and they just refunded me in full without asking for it back instead. Would be nice to fix it instead of consigning to the dustbin.
                            It is complete luck of the drawer whether it powers on or not. Sometimes it will be completely dead, no lights no response. Switching power on and off repeatedly and/or removing and reinserting the battery will eventually make it spring to life. After that...
                            04-13-2025, 02:10 PM
                          • ut-norm
                            Driver brushless motor
                            by ut-norm
                            Hi everyone, I have a brushless motor, of which I am attaching a photo mounted on a DEWALT battery saw that has a faulty controller driver but with the windings ok. I would like to feed it with another controller driver (after having obviously removed the broken one mounted on the base of the motor ) but I don't have clear ideas about it. I've seen many controllers on Aliexpress but I don't know which one to get. It should have a locking system like the original one in case of engine jam.
                            Can you help me?
                            Hello everybody....
                            04-06-2023, 09:09 AM
                            LED Solar Flood Light Dusk to Dawn Security Wall Street Yard Outdoor Lamp modifications are in order
                            by sam_sam_sam
                            I bought one about a month ago from an eBay seller who now is out of stock however I found another eBay seller that has the same version of this device so I think about buying a few more of over a period of time
                            Awhile back I bought some A123 brand 18650 battery cells that are 3.2 volt battery cells that I am going to use in this device for more running time in a florescent bulb fixture that I gutting out the tube sockets and turn it into a solar powered LED lighting fixture instead
                            Pictures will come later when I have the lighting fixture gutted and have the battery...
                            08-11-2024, 11:10 AM
