Cordless Dremel 8220 rotary tool power fault
  • spleenharvester
    • Mar 2010
    • 921
    Hi all
    I bought this Dremel several years ago (8220 + 880 2.0Ah battery). After about a dozen light uses it developed a power fault. I asked Toolstation to start a warranty claim for me and they just refunded me in full without asking for it back instead. Would be nice to fix it instead of consigning to the dustbin.
    It is complete luck of the drawer whether it powers on or not. Sometimes it will be completely dead, no lights no response. Switching power on and off repeatedly and/or removing and reinserting the battery will eventually make it spring to life. After that it continues working perfectly until it is switched off again. Then once again it is luck whether it turns back on or not. This does not seem to be related to the battery charge level.
    I am guessing it is a fault on the PCB, which appears to be p/n 2610021281, but there are no UK sources available for it and I doubt there will be in the future as it's been superseded by the 8240 series. Anyone encountered this before?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 921
    PCB pics
      • 31254
      resolder the big mosfets and wipe the speed variable with contact cleaner - see if that helps
      • spleenharvester
        • Mar 2010
        • 921
        Cheers will give that a go. Sod's law it's working perfectly fine now that I've got it on the bench. Will update
        • spleenharvester
          • Mar 2010
          • 921
          Found the fault, it was a fractured trace adjacent to the positive wire to the motor. Very very subtle, I only noticed it with a magnifying glass. Unfortunately I made such a mess of the board in the process of doing this that I really can't be bothered to fix it, so I think I am going to sell the parts and treat myself to a Milwaukee instead. :-)
          On the pic attached it's the blue circle, the two sides of the trace were tinned before this photo was taken
            • Jul 2011
            • 6070
            You could probably fix it if you remove all the solder from the traces where the wires going to the board and shorten the wire leads a little bit and just clean it up a little bit unless you really damaged the board traces then this is a different story but depending on how bad it is you used solid wire and even fix the broken traces
            It looks bad but it might not be that bad if you wanted to spend a little bit more time on it
            • spleenharvester
              • Mar 2010
              • 921
              It probably is fixable by a pro, not by a guy with a tremor haha. I managed to find a brand new replacement mainboard for £40 so I'm just going to go for that instead.
              • spleenharvester
                • Mar 2010
                • 921
                Update, replaced the PCB, it worked perfectly for about a dozen uses now it's doing it again. Think I am just going to treat myself to the Milwaukee rotary tool instead.
                  • Jul 2011
                  • 6070
                  Be aware that sometimes the m12 battery packs have issues with charging them after they have some age on them and depending on where the battery cells are manufactured Canada made battery cells are used in a lot of them seem to have this issue
                  • Rictech
                    Panasonic SA-MAX770PU SMPSU board fault....
                    by Rictech
                    Hello everyone. 😀
                    As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                    Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                    Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                    This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                    There are no devices that have exploded or otherwise show signs...
                    08-26-2024, 01:05 AM
                  • howardc64
                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                    by howardc64
                    • Prior owner tried a replacement main board. No difference.
                    • Samsung 2x red blinking standby LED = panel fault
                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                    07-19-2025, 10:54 PM
                  • spleenharvester
                    Dremel 8220 turns on when it feels like it
                    by spleenharvester
                    I've got a Dremel 8220 here that's had maybe an hour's use on it tops from brand new, so the brushes are definitely fine.
                    The fault is it just doesn't switch on sometimes. This can be after you've just used it or from cold. If you pull the battery and re-insert it will fire up straight away, every time, so it doesn't seem to be a physical issue with the power switch. Once on it works perfectly until you switch it off again, then it's pure luck whether it fires up again or not without pulling the battery.
                    I've not really worked on these kinds of tools before so would appreciate...
                    06-02-2024, 12:47 PM
                    ESR meter came to the rescue again today with a PLC I/O card fault
                    I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                    I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                    One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                    12-18-2023, 08:17 PM
                  • thaphatmaster
                    Dremel Li-Ion Charger Stopped Working
                    by thaphatmaster
                    This is my dremel charger for one of the Dremel / Bosch 10.8v (3s1p) Li-Ion packs. There are many like it, but this one is broken.
                    It stopped responding the other day. No light when a battery is inserted, no voltage at the output when tested.
                    The dremel itself and its battery are fine and working.
                    Looking online, many people just replace this type of charger with an Aliexpress version. However most of the through hole components look straightforward enough to replace if they are broken.
                    I'll do some basic poking about (continuity checks etc)...
                    01-29-2025, 10:39 AM
