I had bought one of them about a year ago and the one thing that I do not like about it is that the battery made for dose not have very long running time even though it has two 5 amp hour battery packs which the battery packs do test at 5 amps each it is that this air compressor takes a lot of power to run ( Harbor Freight I will post a website link if anyone is interested in buying one and doing the same thing )
JX9 Multi Wire VTOL Pro Connector w/ Servo Extension Plug Signal Wire Is the second picture this can be found on EBay if anyone is interested in this connector I will post the website link for them
The third picture is the battery pack and they did come with the enclosure but now Battery Hookup does not sell them that way anymore so I will will not list the website link it but they still sell them however they are in lots of 40 and you have to bid on them ( I have to modify this battery pack from 48 volts to two 20 volt battery banks )
The four picture is the other battery connector that I going to use from the air compressor to the battery pack ( this item can also be found on EBay as well
I have wanted to build a battery pack for this battery operated air compressor and in another post I mentioned it but could not find a connector that I could link the BMS protection board to the battery charger until today when I found this battery connector this just what I was looking for now I can make the battery pack for this air compressor
I have used this air compressor a few times where to find a AC outlet would have been a challenge to complete the job I was doing on my sons semi truck and his tires and repair his air conditioning system
I will post some pictures of these modifications when I am completely done with this project and have it worked the way I want it to work
