12v 1uo941243c Relay repairable?
    • 31090
    Re: 12v 1uo941243c Relay repairable?
    well - bohaboha will know what it does - because that function wont work now it's been removed
    • petehall347
      • Jan 2015
      • 4427
      yes that will be a big give away as to what its job is .
      • bohaboha
        • Nov 2012
        • 1015
        • sweden
        think those relays are also used for dash lights
        I'm lost because I don't know which relay belongs to which function there is absolutely nothing in the car that shows. the manual only shows fuses. and I don't think this relay has to do with doors because I locked the car after I removed this relay
        • petehall347
          • Jan 2015
          • 4427
          try everything and see what wont switch on .
          • petehall347
            • Jan 2015
            • 4427
            i can see if i have a wiring diagram later .. where abouts in the car is the relay from ?
            • bohaboha
              • Nov 2012
              • 1015
              • sweden
              #26
              it was under the dashboard
              • petehall347
                • Jan 2015
                • 4427
                #27
                what year is the car ?
                  • 31090
                  it's possible that it's just what we see.
                  it reminds me of the circuit used with trailer sockets.
                  @bohaboha - do you have a tow ball and socket for a trailer on the car?
                  • petehall347
                    • Jan 2015
                    • 4427
                    #29
                    making me wonder why the relay was removed in the first place
                    • bohaboha
                      • Nov 2012
                      • 1015
                      • sweden
                      #30
                      it
                      is 2004
                      • bohaboha
                        • Nov 2012
                        • 1015
                        • sweden
                        #31
                        no nothing
                        • bohaboha
                          • Nov 2012
                          • 1015
                          • sweden
                          #32
                          was thinking itbelongs to the problem i have with this car
                          • petehall347
                            • Jan 2015
                            • 4427
                            #33
                            it would help us help you if you let us into the secret of what the problem is
                            • petehall347
                              • Jan 2015
                              • 4427
                              #34
                              does the relay plate hold 14 relays ?
                              please post a picture of the relay plate
                              • redwire
                                • Dec 2010
                                • 3910
                                OP doesn't give us the clear pictures, car year or wiring diagram or symptoms it's impossible to really help him
                                The diode trace has a run that goes nowhere... then I realized the trace is looking zapped.
                                One description is "relay for the instrument panel lighting controller, for vehicles without a central alarm". Another said with central alarm.
                                The 6-pins do not seem to have numbers so impossible to know what pin is overloaded and we don't have the car wiring info or a symptom.
                                • bohaboha
                                  • Nov 2012
                                  • 1015
                                  • sweden
                                  #36
                                  I'm just in the same situation because I don't know any more and I just have the fuse box information which is not so good. even for this relay after i train away it everything works so it's equally dark for me
                                  • bohaboha
                                    • Nov 2012
                                    • 1015
                                    • sweden
                                    #37
                                    No it has only 7 relays
                                    • bohaboha
                                      • Nov 2012
                                      • 1015
                                      • sweden
                                      #38
                                      The car starts but no spark so I thought it has to do with the fuel pump but I still don't know therefore I tried to find the fuelpumps relay.That's the problem and it's not solved but now I know which relay is for the fuelpump Hooray Hooray
                                      • petehall347
                                        • Jan 2015
                                        • 4427
                                        #39
                                        is it on the far right of the relay plate ?
                                        • bohaboha
                                          • Nov 2012
                                          • 1015
                                          • sweden
                                          #40
                                          it is the third on the plate and it has a big number 309 about the midle of the plate in the leftside driver side (european car)
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                          • valvashon
                                            Repair Success! Middle Atlantic UPS2200R-IP
                                            by valvashon
                                            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                            02-06-2024, 12:54 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • Crystaleyes
                                            LCD TV Power Supply Board question
                                            by Crystaleyes
                                            First off,
                                            Happy New Year everyone!
                                            Someone recently asked me to look at their Philips 42pfl4508g/78 TV which had stopped working.
                                            A quick visual check of the PSU revealed a ceramic cap with a hole burnt through it, and that the output voltages were wonky. The 5.2v Standby was only 3.2v. The 24v - 19.1v and the 12v - 11.2v. We found a cheap 'guaranteed working' replacement PSU online, which they bought and installed but it still the TV didn't switch on, and when I went back to test the new PSU board, it showed the same kind of low output voltages....
                                            01-01-2025, 09:40 AM
                                          • Nikolai Danylchyk
                                            Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                                            by Nikolai Danylchyk
                                            Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                                            Thanks in advance!...
                                            05-08-2025, 06:18 AM
