12v 1uo941243c Relay repairable?
    • 31260
    Re: 12v 1uo941243c Relay repairable?
    well - bohaboha will know what it does - because that function wont work now it's been removed
    • petehall347
      • Jan 2015
      • 4446
      • United Kingdom
      yes that will be a big give away as to what its job is .
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        think those relays are also used for dash lights
        I'm lost because I don't know which relay belongs to which function there is absolutely nothing in the car that shows. the manual only shows fuses. and I don't think this relay has to do with doors because I locked the car after I removed this relay
        • petehall347
          • Jan 2015
          • 4446
          • United Kingdom
          try everything and see what wont switch on .
          • petehall347
            • Jan 2015
            • 4446
            • United Kingdom
            i can see if i have a wiring diagram later .. where abouts in the car is the relay from ?
            • bohaboha
              • Nov 2012
              • 1017
              • sweden
              #26
              it was under the dashboard
              • petehall347
                • Jan 2015
                • 4446
                • United Kingdom
                #27
                what year is the car ?
                  • 31260
                  it's possible that it's just what we see.
                  it reminds me of the circuit used with trailer sockets.
                  @bohaboha - do you have a tow ball and socket for a trailer on the car?
                  • petehall347
                    • Jan 2015
                    • 4446
                    • United Kingdom
                    #29
                    making me wonder why the relay was removed in the first place
                    • bohaboha
                      • Nov 2012
                      • 1017
                      • sweden
                      #30
                      it
                      is 2004
                      • bohaboha
                        • Nov 2012
                        • 1017
                        • sweden
                        #31
                        no nothing
                        • bohaboha
                          • Nov 2012
                          • 1017
                          • sweden
                          #32
                          was thinking itbelongs to the problem i have with this car
                          • petehall347
                            • Jan 2015
                            • 4446
                            • United Kingdom
                            #33
                            it would help us help you if you let us into the secret of what the problem is
                            • petehall347
                              • Jan 2015
                              • 4446
                              • United Kingdom
                              #34
                              does the relay plate hold 14 relays ?
                              please post a picture of the relay plate
                              • redwire
                                • 3912
                                OP doesn't give us the clear pictures, car year or wiring diagram or symptoms it's impossible to really help him
                                The diode trace has a run that goes nowhere... then I realized the trace is looking zapped.
                                One description is "relay for the instrument panel lighting controller, for vehicles without a central alarm". Another said with central alarm.
                                The 6-pins do not seem to have numbers so impossible to know what pin is overloaded and we don't have the car wiring info or a symptom.
                                • bohaboha
                                  • Nov 2012
                                  • 1017
                                  • sweden
                                  #36
                                  I'm just in the same situation because I don't know any more and I just have the fuse box information which is not so good. even for this relay after i train away it everything works so it's equally dark for me
                                  • bohaboha
                                    • Nov 2012
                                    • 1017
                                    • sweden
                                    #37
                                    No it has only 7 relays
                                    • bohaboha
                                      • Nov 2012
                                      • 1017
                                      • sweden
                                      #38
                                      The car starts but no spark so I thought it has to do with the fuel pump but I still don't know therefore I tried to find the fuelpumps relay.That's the problem and it's not solved but now I know which relay is for the fuelpump Hooray Hooray
                                      • petehall347
                                        • Jan 2015
                                        • 4446
                                        • United Kingdom
                                        #39
                                        is it on the far right of the relay plate ?
                                        • bohaboha
                                          • Nov 2012
                                          • 1017
                                          • sweden
                                          #40
                                          it is the third on the plate and it has a big number 309 about the midle of the plate in the leftside driver side (european car)
                                          • Dvsr
                                            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                                            by Dvsr
                                            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                                            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                                            After replacing the caps I started testing out the speaker. It seemed...
                                            09-10-2025, 10:20 AM
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                          • valvashon
                                            Repair Success! Middle Atlantic UPS2200R-IP
                                            by valvashon
                                            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                            02-06-2024, 12:54 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            by sam_sam_sam
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
