12v 1uo941243c Relay repairable?
    • Jul 2011
    • 6045
    Re: 12v 1uo941243c Relay repairable?
    First you need to know if you have a short circuit on any of those circuit because if it does it might not let it activate this relay for safety reasons
    • bohaboha
      • Nov 2012
      • 1015
      • sweden
      #142
      I am, but I'm thinking in the wrong way
      • bohaboha
        • Nov 2012
        • 1015
        • sweden
        #143
        Hi petehall347,redwire,sam_sam_sam,stj and everyone else who helps and helped with this thread. No it's not solved yet because the engine can't communicate with the ECM and I'm trying to solve it to move forward.Now thought maybe petehall347 c an help me with more info or any diagrams that can ease the search
        • petehall347
          • Jan 2015
          • 4427
          #144
          the diagrams i posted are the only ones i have for that car .
          • bohaboha
            • Nov 2012
            • 1015
            • sweden
            #145
            thanks it's great i made a single sheet of it so to have a total view and i think the solution is there. i was thinking you might have something more on your autodata. because i see more specific shema for ECM
            • bohaboha
              • Nov 2012
              • 1015
              • sweden
              #146
              Re: 12v 1uo941243c Relay repairable? SOLVED
              Hi everyone who helped me with this problem. Well after 3 and a half months of search and support from various mechanics and friends the problem is solved and I think you need to know what was the error and of course the solution .
              At first I changed the speed sensor but it didn't solve the problem. two days ago i decided to change lambda sensor i inserted my hand behind the engine to see if i could reach it with a tool quite crowded there and guess ? it was loose trying to get it out it didn't go so i screwed it back into place with my fingers and then thought let start the car to see and what happened ? yes yes yes it really started an incredible story
                • Jul 2011
                • 6045
                Yea that would probably be the case if it completely failed this would make sense I caution you that you need to make sure that this sensor is tight before you start driving the car because if not you will destroy the the treads in the manifold and you will have more problems than you need
                You might have to use a line wrench or a box end wrench to tighten if you not use anything else
                • caspian
                  What Zener Diodes on a Linear Power Supply
                  by caspian
                  Dear members,
                  I have a linear variable power supply with unknown brand name that I used for voltage injection.
                  Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                  In addition, I discovered that its zener diodes are defective.
                  I can replace the burned transistors.
                  But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                  Therefore, I cannot replace the zener diodes.
                  I do not want to test the zener diodes in a test circuit to discover their model or value.
                  no schematics are available...
                  05-26-2025, 12:38 PM
                • valvashon
                  Repair Success! Middle Atlantic UPS2200R-IP
                  by valvashon
                  Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                  Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                  02-06-2024, 12:54 PM
                  Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                  I was working on this CNC machine today found no keyboard functioning no control relay powering on
                  The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                  Found shorted diodes on main controller relays there are 3 of them that...
                  01-07-2023, 05:43 PM
                • Crystaleyes
                  LCD TV Power Supply Board question
                  by Crystaleyes
                  First off,
                  Happy New Year everyone!
                  Someone recently asked me to look at their Philips 42pfl4508g/78 TV which had stopped working.
                  A quick visual check of the PSU revealed a ceramic cap with a hole burnt through it, and that the output voltages were wonky. The 5.2v Standby was only 3.2v. The 24v - 19.1v and the 12v - 11.2v. We found a cheap 'guaranteed working' replacement PSU online, which they bought and installed but it still the TV didn't switch on, and when I went back to test the new PSU board, it showed the same kind of low output voltages....
                  01-01-2025, 09:40 AM
                • Nikolai Danylchyk
                  Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                  by Nikolai Danylchyk
                  Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                  Thanks in advance!...
                  05-08-2025, 06:18 AM
