12v 1uo941243c Relay repairable?
  • bohaboha
    • Nov 2012
    • 1015
    • sweden
    #81
    Re: 12v 1uo941243c Relay repairable?
    Originally posted by redwire
    First you would troubleshoot and fix the blowing fuses problem, why are you now suspecting the relays? Look for the short circuits instead of wasting time here.
    thanks but after the fuse was blown I no longer have any power through so I can't find the source and then it would be good to know that those relays are working properly. what I understand from your post the relays have nothing to do with the fuse or am I wrong
    • diif
      • Feb 2014
      • 6978
      • England
      #82
      Check the connector to the ECU that's behind the battery.
      • bohaboha
        • Nov 2012
        • 1015
        • sweden
        #83
        The ECU on this car is located with the wiper motor I took out and it looks almost like new even inside. Don't you guys know how to test these multi pins. relay? Because with all the help that petehall347 has contributed I still have some relays that I don't know their purpose just because supposedly they handle multiple things at the same time
        • petehall347
          • Jan 2015
          • 4427
          #84
          i wouldn't be messing with all that stuff . instead i would be getting it running then see if anything isnt operating properly .
          did you fix the rpm sensor yet ?
          • bohaboha
            • Nov 2012
            • 1015
            • sweden
            #85
            it's right what you say but when I don't get power to the sensor and ignition coil and also not to the fuses 28,32and 34 which all have ignition to do then I go crazy
            • diif
              • Feb 2014
              • 6978
              • England
              #86
              That rules out the direct connection to the ECU but I don't think it's a relay causing your fuse to blow and three error codes.
              I think there is a large connector behind the battery check that.
              • bohaboha
                • Nov 2012
                • 1015
                • sweden
                #87
                they do not blow anymore now there is no more power flow and it 3fuses
                • petehall347
                  • Jan 2015
                  • 4427
                  #88
                  f34 .. Y102 Intake manifold air control solenoid
                  f32, Y3 Injector
                  f28,, M12 Fuel pump
                  looking like a crushed or burnt loom somewhere . cant see those 3 being shorted at same time .
                  those fuses get power from K20 Fuel pump relay . so that is at least partly working and probably just fine . .
                  • bohaboha
                    • Nov 2012
                    • 1015
                    • sweden
                    #89
                    f32, Y3 Injector
                    f28,, M12 Fuel pump
                    then maybe relay k20 not working properly which is 7 pins relay that i do not know how to test just to eliminate it. do you know how to test it
                    • petehall347
                      • Jan 2015
                      • 4427
                      #90
                      k20 will be fine .its providing power to the fuses that are blowing . somewhere i suspect there is a short inside the wiring loom . or the fuse box is somehow shorting to the chassis .
                        • Jul 2011
                        • 6045
                        Look at the relay it should show up the pins are with numbers on it tell you what is common normally open normally closed and if has more than one set of contacts
                        I am not trying to be mean but you should know how to test a relay and what the symbols are for a relay because if you do not you are going to have a very hard time trying to get this car running again
                        By me saying that if you have all the skills that you need it difficult enough troubleshooting issues like this to being with in the first place so you have to get the minimum amount of skills first before you can even being to troubleshoot this issue
                        Like Peterhall347 said in the post above you are going to have to find out why this fuse is blowing before you even being to figure out why this is happening
                        And I can tell you that unless the relay is shorting to ground it is not going to be the relay however you need to make a test light jig so you power the output side of the relay to see where you do not have power anymore
                        The first thing I would do is unplug everything that is on that circuit that is blowing fuses ( then remove the fuse and use the test light jig ) and plug in one device at a time and when your test light is very bright then you more than likely have found part of your problem but you might have more than one problem
                        When you can put a fuse in that does not blow and you have power across the fuse then you have made progress on the issue at hand
                        I hope this helps you with your issue that you are having
                        • petehall347
                          • Jan 2015
                          • 4427
                          #92
                          i do this work to put food inside me . its good to have the wiring diagram . mostly i have to work without . some things can be fixed in 5 minutes even after someone else tried for hours first and they are fully trained on the machine . . i know i keep doing it . saying that it has to be totally stock to fix quickly or it can be hours to put things back where they go and finding the original broken wire etc .
                          • bohaboha
                            • Nov 2012
                            • 1015
                            • sweden
                            #93
                            it's the 3 from the right on picture 2 on post 79 maybe you can figure something out to tip me off thanks
                            • bohaboha
                              • Nov 2012
                              • 1015
                              • sweden
                              #94
                              they are not blowing anymore because no power to them
                                • Jul 2011
                                • 6045
                                PN = negative side
                                50 Z = is your control power
                                50 A = is your positive side
                                • petehall347
                                  • Jan 2015
                                  • 4427
                                  #96
                                  ok so the 50 amp is blown . f5 .. or k20 missing .
                                  • bohaboha
                                    • Nov 2012
                                    • 1015
                                    • sweden
                                    #97
                                    then why only those 3 fuses if the box is shorting to the chassis? note fuses are not blowing they get no power
                                      • Jul 2011
                                      • 6045
                                      You got a serious issue if you blew a 50 amp fuse
                                        • Jul 2011
                                        • 6045
                                        Because you have to go back to where those fuses get power from this a common practice to have a high amp fuse then have smaller fuses down steam
                                        Like I said earlier you need to have basic troubleshooting skills to able to do this troubleshooting
                                        One note if this power is going through a relay there is a possibility that the contacts could be damaged because of the short that you seem to have
                                        • bohaboha
                                          • Nov 2012
                                          • 1015
                                          • sweden
                                          #100
                                          where are those high amps fuses location d int se any this week realy funny
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                          • valvashon
                                            Repair Success! Middle Atlantic UPS2200R-IP
                                            by valvashon
                                            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                            02-06-2024, 12:54 PM
                                            Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                            I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                            The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                            Found shorted diodes on main controller relays there are 3 of them that...
                                            01-07-2023, 05:43 PM
                                          • Crystaleyes
                                            LCD TV Power Supply Board question
                                            by Crystaleyes
                                            First off,
                                            Happy New Year everyone!
                                            Someone recently asked me to look at their Philips 42pfl4508g/78 TV which had stopped working.
                                            A quick visual check of the PSU revealed a ceramic cap with a hole burnt through it, and that the output voltages were wonky. The 5.2v Standby was only 3.2v. The 24v - 19.1v and the 12v - 11.2v. We found a cheap 'guaranteed working' replacement PSU online, which they bought and installed but it still the TV didn't switch on, and when I went back to test the new PSU board, it showed the same kind of low output voltages....
                                            01-01-2025, 09:40 AM
                                          • Nikolai Danylchyk
                                            Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                                            by Nikolai Danylchyk
                                            Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                                            Thanks in advance!...
                                            05-08-2025, 06:18 AM
