what is the number of this transistor
+ More Options
Posts
  • mazloum
    • Sep 2012
    • 503
    • Lebanon
    hello can any one please tell me what is the number of this transistor:
    • 21444
    Re: transistor
    Give more info, what PCB is it on,make/model/part number etc .
    • mazloum
      • Sep 2012
      • 503
      • Lebanon
      Re: what is the number of this transistor
      it is solar inverter
      156-050058-01ga
      next II-3.2k
        • 31144
        it may be a 3v regulator
        • lotas
          • Jan 2016
          • 4708
          • Russia
          2sd1624
          • sikocan
            Lenovo X1 Carbon 9th Gen Black Screen
            by sikocan
            I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
            SN: PF3G1REP
            MODEL: 20KW-00J1AU
            PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
            Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
            06-24-2025, 09:01 PM
          • Devonavar
            Vizio M43-C1 - How closely do I need to match the mainboard number?
            by Devonavar
            I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
            I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
            Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
            So, I've ruled out the PSU for now.
            The reboot loop...
            08-14-2022, 08:46 PM
          • matyx
            My macbook pro a1708 is under MDM and DEP and i wanted to change the serial number and Main Logic Board number
            by matyx
            i dont know what im doing I have CH341A programmer and SPI programming cable from chipsetpro.com the curent serial number is FVFWQ1CJHV2F and the MLB number i dont know and the motherboard id is 820-00840-A
            Can somebody please help.
            I dont know how to uplode the .bin file
            02-20-2025, 02:26 PM
          • Friend33
            Updating Serial Number on EliteBook x360 1030 G3
            by Friend33
            I have an EliteBook x360 1030 G3 and after a motherboard replacement, I want to change the serial number and the FeatureByte. None of the known methods work. MPM is locked and cannot be unlocked via EFI.
            Therefore, I read out the two chips and adjusted the serial number, FeatureByte, and Born Date using a hex editor. Now the system won't start anymore. I think I did something wrong with the FeatureByte, as there was a message indicating that the file size was changing.
            My serial number is: 5CD849BL7Q
            FeatureByte:
            3X476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAd6dUdpdq
            06-20-2024, 03:55 PM
          • Friend33
            Changing BIOS Serial Number After Motherboard Replacement on EliteBook x360 G3
            by Friend33
            I have an EliteBook x360 G3 where I had to replace the motherboard. Everything is working fine and there are no errors during boot. However, I have the issue that the serial number in the BIOS is incorrect. When I run the DMI tool under Windows, I get an error stating that I am not in Unlocked Mode and therefore cannot make any changes. I was able to change the Asset Tag directly in the BIOS. Now I am wondering, can I simply read the BIOS chip, change the serial number with a hex editor, and write it back, or what other options do I have? The old motherboard did not work at...
            06-16-2024, 03:13 PM
