what is the number of this transistor
  • mazloum
    • Sep 2012
    • 503
    • Lebanon
    hello can any one please tell me what is the number of this transistor:
    • 21889
    Re: transistor
    Give more info, what PCB is it on,make/model/part number etc .
    • mazloum
      • Sep 2012
      • 503
      • Lebanon
      Re: what is the number of this transistor
      it is solar inverter
      156-050058-01ga
      next II-3.2k
        • 31249
        it may be a 3v regulator
        • lotas
          • Jan 2016
          • 4787
          • Russia
          2sd1624
          • bruce35
            HP 600 G3 MT serial number change please
            by bruce35
            HP 600 G3 MT
            SERIAL NUMBER MXL8301K1C Serial number in the file in bios
            SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
            Thank you very much...
            09-24-2025, 02:32 AM
          • sikocan
            Lenovo X1 Carbon 9th Gen Black Screen
            by sikocan
            I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
            SN: PF3G1REP
            MODEL: 20KW-00J1AU
            PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
            Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
            06-24-2025, 09:01 PM
          • acerRI
            Gigabyte MB missing serial number in BIOS
            by acerRI
            We have in company to custom PCs with Gigabyte B760 GAMING X (1.0). When i export hwhash for enrolling PC in azure, i got computer name as MMDEFAULTSTRING.
            PCs wiht this name are not compliant with company policy, number should be MMDxxxxxx (xxxxxx is serial number of mb).
            I have found that is possible to embbed in BIOS serial number so when i exporting, it will get proper computer name.
            Does anyone have know if somehow do that, maybe with some hexeditor, because i have found that some specialized tools are needed.
            Any help will be...
            09-23-2025, 05:26 AM
          • Devonavar
            Vizio M43-C1 - How closely do I need to match the mainboard number?
            by Devonavar
            I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
            I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
            Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
            So, I've ruled out the PSU for now.
            The reboot loop...
            08-14-2022, 08:46 PM
          • matyx
            My macbook pro a1708 is under MDM and DEP and i wanted to change the serial number and Main Logic Board number
            by matyx
            i dont know what im doing I have CH341A programmer and SPI programming cable from chipsetpro.com the curent serial number is FVFWQ1CJHV2F and the MLB number i dont know and the motherboard id is 820-00840-A
            Can somebody please help.
            I dont know how to uplode the .bin file
            02-20-2025, 02:26 PM
