SMD diode with Red-orange-blue
  • koektrommel
    • May 2010
    • 12
    Or blue-orange-red.
    Anyone any idea? I need to replace one, but i really have no idea what knd off diode it is?
    It's probably a switching diode, but i need it's specifications so i can find one to replace
    It's ZD6, just below and to the right of the circle.
    See this picture, which is made by another member who had the same problems!
    https://www.badcaps.net/forum/attach...chmentid=13706
  • smason
    • 1652
    Re: SMD diode with Red-orange-blue
    That's a Zener diode, probably 6.3 v but don't take my word for it.
    • Wizard
      • Mar 2008
      • 2296
      yes, 6.3V zener, red denotes cathode. Did the location marking on the PCB say Zxxx, ZDxxx or ZVxxx, or crooked line touching the triangle? If it says Dxxx or like or with straight line touching a triangle is diode.
      http://www.google.ca/#hl=en&source=h...dc6da03facde11
      Cheers, Wizard
      • koektrommel
        • May 2010
        • 12
        You can see the diode on the picture at the link. It's marked as ZD6 on the psu, so i think it's indeed an Zenerdiode.
        But, what's strange is that on a similar PSU, there's on position ZD6 a diode with only a yellow stipe on.
        I'm thinking this red-orange-blue is not good anymore: when using the digital multimeter in diode testing mode, it's measuring 45 and 45 out of circuit. Is it correct, that that diode is not good anymore?
        The diode at the same position on the working PSU gave different measurements: 1 and 7-800 which is what it should be. That makes me think the red-orange-blue diode needs to be replaced.
        (On the board, one transistor Q1 was shorted and bulged. Replacing it didn't work, so that's what makes the diode suspect for me, even because of the two different measurements of one and the same diodes on the same position of the PSU)
        Do you think this diode is faulty?
        • Wizard
          • Mar 2008
          • 2296
          Measure cathode side of the zener to the ground, carefully when plugged in. If 6.3V, it should be appox 5.8V to 6.2V. Rememeber this is on hot side ground.
          Cheers, Wizard
          • mbates14
            • May 2005
            • 169
            yea i know all about that hot side ground crap. just make sure the multimeter you use isnt a AC powered one. things explode.
            • koektrommel
              • May 2010
              • 12
              Thanks for the replies. I really appreciate it!
              I'll try to check the voltages if that's possible. I found out that according to the colours it should be 6.3V or 3.6V
              • japlytic
                • Oct 2005
                • 2086
                It is most likely to be a 3.6V device, because there are no 6.3V devices (6.2V is the closest but no match) according to the E24 values.
                • humango
                  • Feb 2011
                  Did you ever find the right zener diode (ZD6), because i have the same one blown on my psu 17" ALS Imac, and I want to try and replace it, thanks.
                  • torgeson5kqs
                    • Mar 2011
                    • 116
                    I have the same one as well on several power supplies. When I go to mouser I"m lost on what the package size should be, current, temerature, etc. Does anyone have an exact part number, Digikey would be fine too.
                    • asr
                      Finding replacement diode iPad Pro 3rd gen A1701
                      by asr
                      Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                      Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                      07-09-2024, 06:24 PM
                    • iMuhtaseb
                      A2681 Keyboard, trackpad and sleep?!
                      by iMuhtaseb
                      Wow it's been a while since I posted!
                      This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
                      A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
                      It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
                      Tested another locked logic board on customer's top case and it posted with keyboard and...
                      05-22-2025, 09:59 AM
                    • duwane
                      MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                      by duwane
                      Hi All.
                      I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                      Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                      After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                      Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                      10-17-2023, 07:48 PM
                    • NicRac
                      monowheel repair,Is the diode the problem?
                      by NicRac
                      Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                      First of all, I am new here. Therefore I will shortly introduce myself.
                      I am Nico and currently I study Physics.
                      In my freetime I like to build and repair stuff. Especially big battery's.
                      A few years ago I got myself an electric unicycle, monowheel or however you call that.
                      The battery bms was broken so I replaced and resolder that. Nothing big.
                      I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                      07-26-2024, 06:13 AM
                    • mrcliem
                      CM V700 no +5vsb, ICE2QR4765 low VCC in... Need guidance please...
                      by mrcliem
                      Hello...
                      I got my self a dead CM V700 PSU, with nothing on +5vsb
                      I have tried to fix it for the past 2 week, and I'm stuck... so i guess i post it here to get some pointer before i scrap it..
                      As you can see in photo, the psu still pretty clean, no visible damage or bulging cap.. when i got it, it still has CM seal on it
                      The +5vsb system use ICE2QR4765, I have trace and measure the voltage on ICE2QR4765 and the only voltage reading i got is in VCC 4.8v, Drain 310v and FB 3v.
                      I have read the datasheet and and still can not...
                      06-29-2023, 08:18 AM
