A2681 Keyboard, trackpad and sleep?!
  • iMuhtaseb
    • Jan 2017
    • 125
    • Palesine
    Wow it's been a while since I posted!
    This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
    A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
    It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
    Tested another locked logic board on customer's top case and it posted with keyboard and trackpad functioning..
    Anybody experienced such issue with the logic board?
    No signs of liquid on board, so signs of blown caps or resistors or chips.. everything seems intact..
    PPBUS_AONSW_IPD_F diode reading ok
    PP5V_S2_KBDLED_F diode reading ok
    PP1V8_AON_IPD_F diode reading ok
    PP1V2_S2_IPD_F diode reading ok
    PP1V25_AWAKE_IO_F diode reading ok
    PP1V8_S2_IPD_F diode reading ok
    PP3V3_AON_IPD_F diode reading ok
    PP1V8_AWAKE_F diode reading ok
    PP3V8_AON_IPD_F diode reading ok
  • mechfixer
    • Aug 2025
    I'm having a similar issue with a device, did you ever find a fix for this one?
    • SuperAman
      PS5 HDMI port diode reading?
      by SuperAman
      I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
      02-03-2024, 10:16 PM
    • rynr
      MacBook Air M2 A2681 no Trackpad
      by rynr
      I have been following the posts in the forum for some time now and have learned a lot. I would first like to thank you for this and hope that it will continue for a long time.
      I received the MacBook in DFU. The recovery always failed with error 1. After some search, I was able to find a defective inductor (LT202).
      After replacing the component, I was able to successfully complete the DFU restore. Unfortunately, the trackpad and keyboard where still without function.
      So i measured all voltages and diodereadings on the JT400 connector. ...
      11-04-2024, 09:56 AM
    • abajor
      A2141 PP3v3_G3H_RTC_X Diode Reading .104V Voltage 3.39V
      by abajor
      Have an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
      PPBUS_3GH diode: measures good .45V
      PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
      The weird so far is
      PP3v3_G3H_RTC_X diode: .104V (WTF?)
      PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
      Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
      Not sure what any of this means...
      03-18-2025, 10:27 PM
    • tommy97
      MacBook A2681 - Problem with trackpad
      by tommy97
      I do have problem with MacBook A2681 every time i close the lid, when re-open trackpad does not work, i need to close it again and the re-open and it's come back to normal, i've tried software reset, inspected the board, replaced screen angle sensor (from Apple), nothing changed, any ideas?
      04-06-2024, 04:16 AM
    • ronaldopdias
      A3113 corrosion to LAS = No keyboard, yet screen and trackpad work fine
      by ronaldopdias
      Hi All.
      I have a A3113 MacBook Air 13" (M3) that had minor liquid damage. The screen remains on if the lid is closed, the keyboard doesn't work, but trackpad and Touch ID does.​
      The LAS was corroded, but I have tested it on an A2681 (M2) and it functions fine. Anyway, I ordered a new one and replaced it and calibrated it with Apple.
      I have checked the main voltages going to the daughterboard and they are present. Diode mode reading on the LAS line which goes direct to the SoC is also correct, no short.
      So then I replaced the daughterboard, and...
      06-16-2025, 03:12 AM
