leakseaker
  • insomnia
    • Jan 2010
    • 17
    leakseaker
    hi does anyone know if the leakseaker meter is any good
  • Huckfinn
    • Jan 2009
    • 43
    Re: leakseaker
    Leakseeker testers work well for locating shorted components on a pc board when one does not have a strong suspicion of any one component or group of components being shorted. In that case, unsoldering large numbers of parts would be impractical. The Leakseeker can point to the offender rather quickly. This type of tester is more useful for locating bad semiconductor components such as ICs, transistors, diodes, etc... that happen to fail in a shorted mode. capacitors can and do also fail that way, but not very often [ in my experience].
    Huck
    • insomnia
      • Jan 2010
      • 17
      Re: leakseaker
      hi thanks for the reply do you know an a good place to buy one also would they be suitable on a smd component
      • PlainBill
        • Feb 2009
        • 7034
        Re: leakseaker
        Interesting device. Yes, it should work on any component that is loading down a power, signal, or data line. It doesn't matter if it was SMD, through-hole, or even point-to-point wired. I can think of hundreds of times this would have saved a lot of time and trouble.
        One thing I saw the was a little alarming (if it wasn't a typo) was that it uses an 8 volt source. If that isn't a typo, it could do serious damage to most ICs on the line.
        PlainBill
        • Krankshaft
          • Jan 2007
          • 2328
          Re: leakseaker
          A better voltage would have been 3.3V much more IC friendly.
          • insomnia
            • Jan 2010
            • 17
            Re: leakseaker
            PlainBill
            ye my brother had me to look at some mobo,s for him and it is very puzzling with the smd components i put in 8 hours one evening messing with this board to find noting to much to go true so i thought it might be handy how about using this is it hard to use
            • JohnLWG
              • Jul 2012
              • 15
              Re: leakseaker
              PlainBill, I purchased one yeserday after asking the manufacturer about your concerns (which concerned me too). Here is his response to the question of 8 volts cooking chips:
              "NO, as the manual describes, it is current limited. Theο»Ώ 8 volts drops down to 5 to 10 millivolts even on high shorts, and down to microvolts on near-zero shorts. In 20+ years that LeakSeeker has been available, there have been zero reports of any problems caused."
              I know this is an old thread, but I thought this might be useful
              • multimeter
                • Jan 2011
                • 739
                • united kingdom
                Re: leakseaker
                anyone have experiance with this tester?,is it any good?
                fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                • JohnLWG
                  • Jul 2012
                  • 15
                  Re: leakseaker
                  I bought one about a week ago. The build quality is very good. It seems to work fine, but i pretty much only have multilayer laptop boards to practice on. apparently it still works on multi layer boards, but the process is more complex. I'm stil llearning to use it, and hope to have some actually useful input soon!
                  • hifihifi
                    • May 2011
                    • 18
                    Re: leakseaker
                    Where can you buy it?
                    Are there different shops?
                    I find only one.
                    • reessi
                      Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                      by reessi
                      Hello:
                      I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                      I started on the ACER:
                      Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                      All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                      I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                      10-29-2024, 11:31 AM
                    • Yanleb
                      Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                      by Yanleb
                      Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                      I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                      D608, good
                      D618 RF101L4S, good (See warning 1 below)
                      D619 RF101L4S, good (See warning 1 below)
                      D865 RF101L4S, shorted (See warning 1 below)
                      IC464 Inverter HA MC74HC1G14, shorted...
                      03-09-2020, 12:00 AM
                    • modtool
                      HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                      by modtool
                      Hi to all,
                      the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                      I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                      I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                      04-01-2025, 08:22 AM
                    • BalkanBoy
                      Dead Razer Blade 14 2022, shorted CPU?
                      by BalkanBoy
                      today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                      Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                      I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                      Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                      I removed coil and injected 0.7V, it draw around...
                      09-27-2024, 12:44 PM
                    • barry101
                      Apple 820-3662 VCore shorted to ground.
                      by barry101
                      Hi, Would appreciate some help.
                      I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                      Get charger light but no fan spin or chime. No liquid damage.
                      Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                      Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                      With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                      Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                      06-24-2025, 07:34 AM
